Question about Sharp AL-1642CS Copier
H4 error - Sharp AL-1642CS Copier
  • 1,110 Answers
To reset the H4 condition on just about any Sharp AL series copier press the following key's in sequence and as quickly as possible (with 4 seconds for the first 4 keys)
Press "C" then the far left key (exposure mode) then the "C" key then the far left again.
So in other words C, far left, C, far left
Some model's use 2 other initial codes, so you may need to use one of these 2 alternate codes to get your display to go blank. The rest of the procedure is the same.
Alternate codes are: #, * , C, * or pound,star,C,star and also
#, Interupt, C, Interupt
If done correctly the display should go blank.
Now key in 14 as if you were going to make 14 copies.
Now press the print button.
The machine should reset and the code should be gone.
9 times out of 10 this is a false code that pops up due to power surges or noise.
If the code comes back this means you have a heater lamp or thermal fuse (more common) failure in the fusing area and will need service.
Posted on Jul 30, 2010
Gree air conditiones H4 error code
Not answer my question is what is the solution for wall mounted unit Model number 18cith1 has error H4 this error meaning here mention system protection.
Apr 30, 2014 | Heating & Cooling
SHARP AR-M155 system error[H4-00]
H4-00,is a fusing troble.maybe the heater lamp is basted, or the thermistor and thermofuse are deffective.or try to cancel by a simulation 14
Jul 05, 2012 | Office Equipment & Supplies
Sharp ar 5516 printers error h5. h4
hi,I have error code L h on my coppier sharp 5516. your help please.
Aug 05, 2010 | Sharp AR-5316 Advanced Digital Imager...
My Photocopier displayed error H4 on the screen
Dear sir
H4 signal is fuser unite problem please call a technician they solve this problem.Just we serve problem location because i am not live your area.
Thanks
Tareq
Aug 12, 2009 | Sharp Office Equipment & Supplies
I have a sharp copier, model AR-285, H4-01
H4 error pertains to lamp errors.
that would either be the copy lamp or the heater lamp.
check both lamps.
with heater lamps,it's usually caused by either a broken heater lamp or a dirty thermostat on the heater roller assembly.
Jun 09, 2009 | Sharp Office Equipment & Supplies
Xerox pro 215, error H4 please help
H4 is a fuser error....not getting up to temperature.
Press [C] (Clear), press [Image Quality], press [C] (Clear) again, press [Image Quality] again.
If this doesn't bring it back to operations then the fuser lamp needs to be replaced.
Jan 17, 2009 | Xerox WorkCentre M20i All-In-One Laser...
Error h4
it is on you fusing unit of your copier, check the fuse maybe it is open already and need for replacement... H4 means that your heater lamp is not functioning
franklin
Jan 07, 2009 | Sharp AR-5320 Black and White Copier
SHARP AL-1216: HOW TO REMOVE H4 ERROR CODE
www.tinli.com.hk/PDF/AL1216.pdf
Hope this helps.
paul
Nov 01, 2008 | Office Equipment & Supplies
211 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
