Question about Gateway /ton 160W Power Supply (6500582) Power Supply
Computer will not start up?
No green test light
  • Gateway Master
  • 27,725 Answers
Sounds like an electrical issue make sure you have power to your computer then test your PSU or just replace your PSU
Posted on Jul 29, 2010
Need help with wiring tail and brake light and tur
the 80 Honda cb750 I had was a custom chopper so it didn't have turn signals but my tail light brake light had 3 wires green green/yellow stipe and brown with your ignion on the brown or the solid green should be hot always a test light will let you know which the other is grown also use your test light to tell both turn signals grounds ground with brake/tail light your wire for your brake light will light up while test light grounded key on an pressing break peddle or handle either one wish I still had my manual so I could tell exactly what wire is what for you but it is simple with a 12v test light to find them
Jul 22, 2013 | Motorcycles
Green power supply light is flashing so power is getting to the computer, however the computer will not start from start button. Have removed case and tried ***** start button. Didn't work. Comput
Power getting to the computer/Power Supply?
Yeah.
Power Supply good? -> NO
A) IF ALL of the LED lights were on at once, they would use less than 1 Watt of power.
B) EACH fan uses 2 to 3 Watts of power.
C) A typical Processor can use from 51 to 125 Watts of power.
Just depends on what Processor it is.
HP Pavilion a810n Desktop PC?
Uses an AMD Athlon 64 3300+ processor,
(Operates Up To a frequency rate of 2.4GHz)
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=c00280647
http://en.wikipedia.org/wiki/List_of_amd_athlon_64_microprocessors#.22Newcastle.22_.28CG.2C_130_nm.29
Can use up to 89 Watts of power.
Your Power Supply doesn't even have enough power to spin fans, much less start the Processor.
Want to test the Power Supply? Have a multimeter?
No? Have a power supply you can borrow for a test unit?
KNOWN to be good, and Compatible?
For additional questions please post in a Comment.
Regards,
joecoolvette
Aug 05, 2012 | HP Computers & Internet
Im trying to connect a 3rd brake light to a 99 camaro is the green wire postive
Hi William, To begin, the usual color coding on American vehicles is black is ground. To test this, take a long length of cable and a test light. Connect one side of the test light to battery positive and and the other cable connect to the black wires one at a time. If the light comes on normally you have proved the ground connection, then do the same with the other. Next connect the test light to the green cable and the other cable to the black. Press the brake pedal and observe if the light illuminates. If all is well, connect the black cable from the third brake light to the black cable of your car and the red cable from the after market brake light to one green cable from your car an insulate the other. Then go ahead and mount the third brake light. Regards John
Jul 13, 2012 | 1999 Chevrolet Camaro
Where is the fuse for the cruise control
This is located on Passenger Compartment Fuse, under "ASC" tag label.
If this its OK, on the brake pedal shaft check with a test light to the pedal position sensor should be a green wire with white stripe make sure it has light on that wire and also on the green wire without the brakes pressed it should also light the test light if both are good there go check at the master cylinder switch the green wire with white stripe and also the green wire with yellow stripe both should light the test light.
Hope this helps.
Mar 21, 2012 | 2001 Ford Escort ZX2
I got dell optiplex 755 desktop computer in the power supply unit at the back there is a small button and a green light what are these for??
It help diagnose problems with your computer
A solid green light means the computer is operating normally.
A solid yellow:- the power is operating fine but your computer not processing data. This could mean there is a problem with the CPU or another component on the motherboard.
A blinking yellow light: power supply is receiving power from the wall, but not functioning properly. This generally means the power supply itself is bad and should be tested or replaced.
A blinking green light means the computer is in standby mode
Jan 29, 2012 | Dell Optiplex 755 Desktop Desktop Computer...
My KDS-55A2000 displays some shades of blue as green. It's not just one area of the screen but the entire screen. Flesh tones can be adjusted to look pretty normal but scenes with light blue sky look...
Your t con board is responsible for the image on your screen. Your colors are all there but they are f---ed up in certain scenarios.
That is the only board on your set that be causing this anomaly.
Apr 30, 2017 | Sony KDS55A2000 55" HDTV
Won't respond to computer, light on printer alternates flashing between green and yellow
  1. Start with the printer OFF
  2. Hold down RESUME button and then hold down POWERbutton
  3. release RESUME button
  4. press RESUME twice, then release POWER
  5. Let green light blink until printer is done futzing
Select function with RESUME press POWER to execute:
presses - light color - function Number of presses - light color - function
0 presses - green - Test print (or exit service mode on i960)
1 press - orange - EEPROM info print (plus grid nozzle diagnostic on i960)
2 presses - green - EEPROM initialize
3 presses - orange - Reset waste ink counter
Press 2 times for EEPROM reset.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Jo
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Feb 19, 2011 | Canon i850 InkJet Photo Printer
No reverse lights 1992 buck park avenue. Good bulbs and fuses. Please help
check your gear selector switch. the switch is mounted on the transmission where the shift cable attaches and looks like the picture below. Backprobe the connector terminal with the light green wire using a 12 volt test light. Connect the test light clip to engine ground and poke the light tip into the back of the connector at the light green wire. With the key on (engine off) and the transmission in reverse, the test light should come on. If not, replace the switch. If you have more questions, please let me know.
Nov 21, 2010 | 1992 Buick Park Avenue
Scanner stopped in middle of scan . green light in front went out. later red light came on. message on screen said that the carriage was locked. I tried turning scanner on and off and green light comes on...
test the power supply to the scanner also test the leads that attach from the power supply to the scanner if its connected to a computer you might have to uninstall it then reinstall it this applies the driver aswell you can do this control panel admistrive tools,computer management,device manager scroll down you should see a yellow question mark? right click to reinstall drivers or ports(com&lpt)ECP printer port right click update driver
hope this helps
Oct 27, 2010 | Computers & Internet
Computers & Internet Logo
62 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
