Question about Canon BubbleJet i70 InkJet Photo Printer
When turned on my Canon i70 print head moves from its position to the left, then back to the right, and then about an inch or two back left. At that point it stops and the printer gives off a loud buzzing noise. Then the power light blinks green, then four yellow, then green again.
  • 3 Answers
SOURCE: Canon i70 LED
The problem is your wasted ink tank it either needs to be replaced or you need to reset the error code like this
Try This
1) Close the print head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button.
(Do not release the buttons. The LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button.
(Do not release the Power button.)
3) While holding the Power button, press the Resume/Cancel button 3 times, and then release the Power and Resume/Cancel buttons.
(Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.)
During initialization, the LED blinks in
green.
4) When the LED stops blinking and lights in green, press the Resume/Cancel button 4 times (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.)
After the function (menu) is selected, press the Power button. The LED lights in green, and the
selected function is performed. (When the operation completes, the printer returns to the menu selection mode automatically.)
*** 4 times Green Waste ink counter resetting Both the main and borderless print waste ink counters are cleared.
Posted on Jan 25, 2008
  • 8 Answers
SOURCE: canon i550 problem
The yellow blinking light is not reported in the code errors, take a look to service manual http://rapidshare.com/files/91114670/Canon_i550_i850_i950_Service_Manual.pdf.html
(hard to find but I did it ! )
I had the same problem and I solve it sending the clean head command from the settings of the printer driver (win XP)
I also reset the printer as it is explained in the service manual.
Posted on Feb 12, 2008
  • 6 Answers
SOURCE: canon mp-730 print head does not move
it seems you open or unscrew the printer.
this may happen if the mother board has no nigative pole.
you have to reset the mother borad.
cannot do that from the available options
the reseting procedure is to take the motherboard out and you have to shortcut the battary for 10 seconds.
re install it , and try it
Posted on Mar 26, 2008
  • 49 Answers
SOURCE: Ink Absorber Replacement for Canon i70 Printer
Not easy for most people to replace or clean ink pads, but this will reset
During initialization, the LED blinks in green.
After the function (menu) is selected, press the Power button. The LED lights in green, and the selected function is performed. (When the operation completes, the printer returns to the menu selection mode automatically.)
Posted on Jul 06, 2008
SOURCE: Canon i560 printer
I have similar problem. I found this solution that may help you. My problem insists tho.
>>> 5 flashes indicates a faulty printhead or possibly a problem with the p/head contacts. Try removing the head which is easier if you take the cartridges out first(no tools required) and re-seat it having checked the contacts for dirt.
If that doesn't work it may be that the waste ink tank is full. Try this ...
Canon S9000, S300, S400, i550, i560, i850, i860, i865, i9100, i9950, PIXMA iP3000 above,
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
Posted on Aug 12, 2008
How to manually unlock printer head position that is currently stuck in print head cleaning area.
if you see inside the printer there is a white gear in the left side . try to turn it front or back and move the cartridge
Feb 18, 2016 | Canon PIXMA Office Equipment & Supplies
I need to extract the printhead from a Canon MP540 printer in order to install a new one. I have just received an incomplete answer from FIXYA. When I turn on the printer and raise the cover, the...
The print head is not designed to be moved manually and damage may occur if you try to do so forcefully.
To center the print head to replace ink tanks and to replace/remove print head you should do the following:
1. Make sure power is turned on and open the Paper Output Tray gently. 2. Lift the scanning unit (cover) until it stops. Lift with document cover closed. The print head holder should move to the replacement position (center).
Do not force print head holder to move nor touch it while it's moving. These parts are very delicate and generally are made mostly of plastic.
IMPORTANT If the Scanning Unit (Cover) is left open for more than 10 minutes, the Print Head Holder moves to the right. In this case, close and reopen the Scanning Unit (Cover).
May 04, 2011 | Canon PIXMA MP540 All-In-One InkJet...
Print head stuck on the right hand side and lamp is flashing alternate green and orange
Found this today (and it worked):
canon waste tank reset for canon i70
Below is a procedure that in most cases should resolve a Canon i70 waste tank issue
Canon i70 InkJet Photo Printer
Feb 21, 2011 | Cannon i70 Printer
I have a Canon MP610 printer and am getting an error message 6A00. I have tried moving the carriage but nothing seems to help. Any suggestions?
1. Turn off the printer
2. Open cover
3. Print head and cartridges manually move to the left
4. on the extreme right is a white plastic cover is visible, which is attached to a spring
5. Clean the cover carefully (no chemicals, not wet) and gently push it back (it clicks) and remove any impurities -> the black collecting sponges for the storage of the print head can see
6. Print head and cartridges manually back to the right move
7. Turn on printer
If the above steps does not fix the problem, Click on the link below to check the forum for more details on resolving the issue.
Canon Mp610 Error 6A00
Regards,
Shawn
* Please rate this solution with Thumbs up and Testimony to help us improve providing support
Jan 05, 2011 | Canon MP610 Photo All-In-One Printer
My canon when it's powered on advanced 2 sheets of paper the pinter head moves to the left side then back to the right side as normal then back to the left stops and begings making a chattering sound. The...
press and hold the power button until it stops flashing - the printer is simply trying to tell you that there was an issue (out of ink, out of paper, or paper jam) and is trying to resume normal activity.
Mar 29, 2010 | Cannon i70 Printer
Canon i70 bubble jet printer : print head is stuck all the way to the right, will not center, green/amber light alternating continually. Help ?!
You Canon printer seems to have RETIRED when it does that. It is a common canon prblem and that is why the smaller canon printers are referred to as DISPOSABLE printers. The motherboard of the printer has got a problem on it and would cost more that the price of a new printer to have fixed.
Jul 06, 2009 | Cannon i70 Printer
Canon i70
Hi. Probably your printer need a general cleaning
Jun 08, 2017 | Canon BubbleJet i70 InkJet Photo Printer
Print Head
After opening the purple cover, the printer head will move to the center. There should be a gray tab on the left side of the forward facing opening (about the middle of lower cartridge). Gently push printer head to the right (1/4 to 1/2 inch) and a gray slanted tab will appear from behind housing. lift this tab and a metal lock will pop up. Tilt lock back and the printer head should be lying loose in its cradle.
Apr 11, 2008 | Canon PIXMA iP90 InkJet Printer
Canon i70 print head does not move to the middle
THERE IS A CODE THAT UNLOCKS THE HEAD. IT MAY BE THE SAME AS THE I80 PRINTER. DO NOT FORCE HEAD. THE CODE IS PUNCHED IN BY THE FEED BUTTON AT THE TOP. I WILL TRY TO FIND THE CODE AND REPOST.
Oct 11, 2007 | Cannon i70 Printer
Canon BubbleJet i70 InkJet Photo Printer Logo
370 people viewed this question
old marine
old marine
