Question about Dell (E210882) Motherboard
Dell Dimension 9200 flashing orange light
About 1 week ago, when I tried to turn my computer on...power button just flashed orange ....I then called Dell support, we tried to fix this over the phone, but this could not be fixed, diagnosis from Dell doctor was to replace motherboard.....:(.
Unfortunately, I can only use computers not fix them therefore I need some advise as to how I can bring my Dell back to life... ?
Any help is much appreciated !
Dilya
Hahaha are you serious? flicking that switch on the power supply is the best way to fry something. Usually your power supply but your motherboard and other parts are at risk too... Under NO circumstances do it!
Posted on Jan 11, 2010
    Problem Solver:
  • 32 Answers
It sounds as if the power is fluctuating or is not at the right voltage, see if there is a red switch on the back of your computer where the cable plugs in, if so switch it and see if that works. If not then switch it back then try putting a new cmos battery in the motherboard or test the one you have, it looks like a watch battery.
sorry i wasnt signed in when i posted
Posted on May 09, 2008
    Scholar:
  • 61 Answers
My first suggestion would be to completely remove the power from the PC. Wether you remove the cable form the back or switch of at the wall shouldnt make a differenence. Go out shopping for a while plug it back in and give it another go. Sometimes giving it time alone to itself can rectify a lot of issues.
If the pc is still under warranty try and get it looked at under the warranty agreement. If it is out of warranty you will probably need to get an IT store to look at it for you. I wouldnt be surprised if Dell has installed a special screw that requires a special screw driver bit to remove it.
Posted on Apr 24, 2008
Orange flashing light on a dell dimenson 5150 computer won't start up
The orange flashing light on the power button is an indication of power supply failure.
Your Power supply unit needs to be replaced.
Aug 11, 2010 | Dell Dimension E510 Dual Core 2.8 Ghz...
Power button if flashing orange and nothing else works
It's likely that your power supply has started to go out. There are several different leads with varying voltages & amps. If your computer is getting enough power to make a light flash yellow or orange then this often means that there is something wrong with one or more of the voltages from the power supply. Sometimes it means that something is wrong with your motherboard. Like: burned out capacitors, resistors, & etc.
Jul 06, 2010 | Dell Dimension E310 PC Desktop
My Dell Dimension begins to boot then sits there as if asleep
It sounds like it's probably the power supply. Computers require more power to boot up than they do to keep running, so if it's fine once it gets going, the power supply may just be dying. If you have a multimeter and know what you're doing, you can test the power supply connectors to see if any of them (especially the ones leading to the motherboard) are not giving the proper voltages.
How old is the computer?
May 27, 2010 | Dell Dimension 9200 PC Desktop
Computer wont turn on orange flashing light on the power button
Here is a web site that may help solve your problem.
http://www.randomfix.com/2007/04/19/dell-dimension-%E2%80%93-flashing-orange-power-light/
Oct 23, 2009 | Dell Dimension E510 PC Desktop
The power light keeps flashing orange when trying to switch my pc on i only get an orange flashing light no other life in it whatsoever........
It means to say that it is not getting enough power on the computer, check the power cable at the back of the tower and make sure the power cable is connected tightly. You can try taking it out and then putting it back in again to make sure it is connected firmly.
Jun 02, 2009 | Dell Dimension 9200 PC Desktop
Dell Dimension 5150 automatically turns off
That flashing amber light is usually a sign the power supply is failed or is failing. I would suspect the power supply is the problem in yours. It is the better of the two problems connected with the flashing amber light..the other is motherboard is failing. Arrrr!
hope this helps (it takes a standard- oh say 350 watt 20-24 pin power supply unit.)
Hope an answer helps.
Please leave rating, thankyou
May 05, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell Dimension 9200 keeps shutting down and won't start up
the key issue on the uncommanded shutdown is the POWER LED. If upon shutdown, the power LED Flashes AMBER, then the power supply is suspect.
If no flashing amber indication, then the next think I check is the heatsink (Processor overheating) remove, clean and apply arctic Silver heat transfer paste, see if the issuje goes away
Last but not least if the system is failing to boot, and displays a 3 4 diag LED code, then you may have a RAM module that is bad or may just need reseating. Running diags off of the Rersoujrce CD is something to look at too
Mar 28, 2009 | Dell Dimension 9200 PC Desktop
Dell Dimension 5150c
The flashing orange light is an error code. Dell tech support can tell you exactly what the code means. Hope this helps.
Jan 25, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Does not power up
Is the amber light flashing on the monitor?
If so, you should get your power supply checked.
Jun 11, 2008 | Dell Dimension 2400 PC Desktop
Dell (E210882) Motherboard Logo
1,252 people viewed this question
Alun Cox
