Question about Dehumidifiers
My Hampton Bay Model HB 50 Dehumidifier freezes over all the time. Basement temp. is 7o F. Basement is not very humid since we are in a sandy area. Sump pump never runs. I will run and freeze over on a setting of 2. I have flushed the colling fins from the front with water. No change. Fan is working properly. Manual says it should work with out freezing at 65 F.
    Problem Solver:
  • 10 Answers
You are low on the freon charge you need to take to a service shop
were they can charge it.
Posted on Jul 31, 2010
Hampton Bay HB30 is not working
its the fan thats not working mayby
May 17, 2014 | Dehumidifiers
I have a customer who has a model 1700 dehumidifier Connected to ductwork with a/c only air handler. Not Sure why this is needed or correct way to wire. Also There is no remote humidifier & unit is...
I have to agree with you. I don't see the need for the dehumidifier either. As the AC unit alone, does have some dehumidifying capability.
Your customer would be better served using an independent Low Temp dehumidifier in the basement. If that's the area they are trying to dehumidify because of dampness in the basement.. It certainly would be less costly to operate. But, any unit that is not a Low Temp unit won't work well in a basement.
I hope this helps and good luck convincing your customer of this.
Thanks for choosing FixYa.
Aug 24, 2011 | Aprilaire 1700 Dehumidifier
MY unit keeps on freezing up no problem with the filter dirty it gave me a problem after 3 months of use . i set it for 60% 50% it freezes up all the time i shut it off let it defrost and same thing all...
I think a part of the problem is that you have the humidity extraction level set to high. 50 to 60% is pretty much the humidity level throughout most of the year. Lowering it to 35%m should make a difference.
If you are using this in a basement application, the temperature at floor level can be 10 degrees cooler than at shoulder level. Most dehumidifiers don't work well at temperatures between 40 & 60 degrees F. Unless, they are Low Temp models designed for basement applications. Raising the unit up off the floor onto a sturdy table, counter top, etc. That can handle the weight of the unit, plus a full tank of water can resolve this problem.
If you can access the cooling coils, they may be dirty and need wiping off with a damp rag. Then flow with a dry clean rag to dry them. A light coating of WD40 helps to preserve the coils.
I hope this helps you to further troubleshoot and solve the problem. Thanks for choosing FixYa.
Jul 26, 2011 | Maytag M7DH45B2A Dehumidifier
I have a 2 year old Frigidaire dehumidifier model FDM7051 and this summer when I turned it on it runs continuously with the fan moving normal amounts of air. The air filter and coils are clean and I have...
Don, unless your dehumidifier is a Low temperature model, that very well may be the problem.
The air temp in a basement at floor level is colder than that chest level. Dehumidifiers don't work well at temperatures at 40 degrees F or less. Raising the unit up off the floor on to a sturdy table, counter top, etc, that is strong enough to handle it's weight, plus a full tank of water, will generally solve the problem. The higher up you can safely put it, the better. Also, lower the humidity extraction level to 35%. As 50% is just not low enough in a basement application.
Hope this helps you to solve the problem.
Jul 20, 2011 | Frigidaire Dehumidifiers
Unit is freezing up. i have unit on auto. please advise.
its low on refrigerant if you mean the refrigerant lines have frost on them,sometimes if you use them in to cool of an area with lots of humidity they will do this too
May 19, 2011 | Whirlpool Gold AD70USS 70 Pint Per Day...
Dehumidifier freezes up
Dehumidifiers2_bing.gif freezing up can be causes by a few different problems.
Here is a tip that I wrote to help people with the freezing dehumidifier2_bing.gif problem....
Dehumidifier is Freezing up and not working
http://www.fixya.com/support/r4662033-dehumidifier_freezing_up_not_working
heatman101
Jul 01, 2010 | Whirlpool Gold AD70USS 70 Pint Per Day...
When do you use the dehumidifier?
In areas with poor circulation and humidity over 80%.
If the room temperature is close to 60, the coils may be frozen (completely encased in ice). If this is the case, move it where the water can drain off - about 1 gallon which may NOT run into the drain bucket.
I out mine over the floor drain.
Turn off and it will defrost over night.
Only specially made dehumidifiers work below a room temp of 60 degrees (the temp of a basement in winter).
Does it need to be running? A digital humidity sensor from Radio Shack is cheap and may tell you the humidity is OK - only 50% or less.
Dec 28, 2009 | Whirlpool Gold AD70USS 70 Pint Per Day...
I just get a dehumidifier it was on all night and the bucket its dry u think theres something wrong with it and whats the % that i have to set it up
% is the % humidity you want.
This is a DEhumidifier for to take water out of air for moist areas.
Usually a setting of 50% or 60% is dry enough. If it is freezing outside, inside of home is probably alreadt below 50%.
If you place in basement below 60 degree, will freeze up. Place over floor drain or in tub and leave off overnight.
Dec 05, 2009 | Goldstar DH504EL Dehumidifier
Hampton Bay Dehumidifier Model# HB50
CHANCES ARE THE DUAL CAPACITOR HAS BLOWN APART...YOU WILL KNOW THIS IF THE SIDE WALL IS RUPTURED. THE CAPACITOR IS LOCATED TO THE RIGHT OF THE COMPRESSOR MOUNTED WITH 1/4 HEX SCREW..PART NUMBER WILL BE 50150115N001..AROUND $17-21.00.
Jul 27, 2007 | Maytag M7DH45B2A Dehumidifier
Dehumidifiers Logo
373 people viewed this question
Top Dehumidifiers Experts
Bill Long
Gil Shultz
jasbo
jasbo
Are you a Dehumidifier Expert? Answer questions, earn points and help others
