Question about Microsoft Computers & Internet
My computer beeps and suddenly freezes and there is a light on one of my disk drives that isn't flashing. I can't even restart it with the reboot button. The only way I can reboot it is through the I/O switch. I don't know much about computers so be easy on the terminology.
  • jnthnhng Jul 29, 2010
    Thank you for the quick reply. I'll definitely try to clean it up. This usually happens when I'm viewing flash videos like on youtube or I'm in a flash heavy website. Sometimes it just happens on other programs as well.
  • 48 Answers
Definitely, in all probability a heating problem. Try cleaning out your computer, thou make sure to not use anything that is conductive inside the computer.
Posted on Jul 29, 2010
  • Michel
    Michel Jul 29, 2010
    When you watch heavy flash content and/or are using programs which also it puts a lot of strain on you computer, especially your processor. So make sure your cpu cooler is dust free.
Starting freezes
Does it beep? Do you have any video on the monitor? What are your front panel lights doing? If it doesn't beep, check the memory. IBM is very particular about their memory. If your monitor does not have any illumination, the BIOS is not getting there. Again, indicative of memory. If the front panel lights do not flash, and your drives don't cycle, possible power supply problem.
Mar 15, 2014 | IBM Computers & Internet
Not detecting, beeping
This is likely a couple problems;
1. The hard drive is dying or is dead. You're looking at hardware recovery if this is the case. There are some tools such as Spinrite that might be able to recover the disk. (GRCHard drive data recovery software)
2. The power supply on the computer/laptop is not functioning as well as it used to. Try using another PC to see if there's any difference in results.
Nov 15, 2017 | Western Digital Computers & Internet
The Hardrive is now beeping and the blue light only flashes once. And my laptop isn't recognising it. Everything I have is stored on it?
click start control panel administration tools computer management device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
if this fails to fix the problem
type in run "regedit" then press ok then you can see registry editor then locate below key. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318} And remove upper filter and lower filter.
Then restart computer then check.
Also locate the below key and make sure it's value is 3 not 4. HKLM\system\currentcontrolset\services\usbstor make sure start value is 3 not 4
if still no luck
you might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap
hope this helps
Apr 24, 2012 | Buffalo Technology Buffalo MiniStation...
The light of the hd is blinking red and yellow and finally freezes at yellow. the disk does'nt mount on my computer.
actually, I was lucky that the hd suddenly worked again. i save alle the datas on it as quick as i can for i think that the drive has a serious damage.
Jan 09, 2010 | LaCie External USB 2.0 500GB 7200 RPM 500...
Can't format flash disk
Files on a flash drive can be corrupted if it is not removed from the USB port properly.
Before removing the flash drive click on the Safely Remove Hardware icon and then click on the flash drive you want to remove and then remove the flash drive when the computer message says it is Safe to remove.
To restore the flash drive you may need to format the flash drive, but you will lose the data stored on the flash drive.
If you need the data on the flash drive this program may help: -
Digital Photo Recovery
www.artplus.hr/adapps/eng/dpr.htm
Nov 10, 2009 | Electronics - Others
Ps3 says cannot start the correct hard disk was not found
try safemode
hold down the power button while the console is in standby. the light will go from red to green.it will beep once flash green beep again, and then beep a third time. after the third beep the light will turn red.
once the light is red, take your finger off the power button and place it back on the power button. the light will go from red to green, beep once flash and then beep twice quickly. after it does the double beep, take your finge roff. the light will stay green and you'll get a screen asking you to connect the controller.
after connecting the controller, try option 3, or whichever option is restore filing system. this can possibly correct media loading and will 95% of the time fix the console when it freezes before loading up your icons(the xmb)
Mar 24, 2009 | Sony Playstation 3 (PS3) Console
Red dot and beep
The problem is in most cases the Power Supply given is of too low of Wattage, at 1.5. After some time, it will no longer provide the drive the needed power, thus the red light.
Try another similar power supply of higher Watts (my Maxtor has it at 2.0 watts.
Try getting Higher power Supply from Radio Shack. Store Tech will Help you.
Lastly, inside the enclosure is simply a typical Hard Drive. Remove it and Slave it to your PC.
Jul 06, 2008 | Beyond Micro (BM120MD3U2) 120 GB USB 2.0...
Crossfire 160 GB external hard drive
Dear Crewchief Try deep freezing your drive, really, I mean freezing it for more than an hour, take it out and attach as a primary or secondary slave and see if it cycles up. Sure hope this helps.
Jan 16, 2007 | Smartdisk - Peripherals - HARD DRIVE,...
Computers & Internet Logo
100 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
