Question about Samsung Computers & Internet
The four little led's on the outsides of the
The four little led's on the outsids of the track pad light up for a second during startup but do not work any other time. I use the unit in low light and since track pad is the same colour as the unit it's really hard to keep on it. I have changed the bios setting to ''trackpad'' to no avail. Help me?! This is for a samsung r580e.
    President:
  • 567 Answers
Hi how long have you notice the light does not stay on?
Posted on Jul 31, 2010
  • 2 more comments
  • kwamebaffoe Aug 01, 2010
    I really can't tell you. I only noticed when the lights came on during startup that they would really make my life alot easier. Sorry if that doesn't help.
  • Hilton Bristol Aug 01, 2010
    Hi there thanks for replying,the four LED lights should respond each time you touch the track pad,if that is not happening this mean the four LED is having a power problem and it can be solve. Here is two options: if the computer is still under warranty you can let the manufacturer fix it ( thats the best idea ) here is the linkhttp://www.samsung.com/ae/info/contactus..., or i can give you the information on what to buy and the steps to follow. But if LED comes on each time you touch the track pad, your computer is fine,no need to do anything.
    I guess I'll get the info on what to buy to fix the thing and then I'll decide whether it is worth the risk of shipping for something so minor or if I want to open the thing up and possibly veto the warranty. Thank you for your help.
    Hi there, you will need to replace the track pad here is the link with the contact information http://www.samsung.com/us/info/contactus... i cannot give you a price because only them can do that.
How do i fix a problem of green power led continuously blinking in Hp compaq nc6320 laptop even when the battery is removed and the motherboard is outside the case?
HP Notebook PCs - Troubleshooting LED Blink Codes or ...
h20564.www2.hp.com/hpsc/doc/public/display?...na...
Hewlett?PackardHP Notebook PCs - Troubleshooting LED Blink Codes or Beep Codes During Startup or Boot ... HP Pavilion and Compaq Presario notebook computers built in 2009 or later use blinking LEDS to identify ... Press the power button to turn on the computer, and look for blinking LED lights on the keyboard. ... Continuous blink.Missing: green ‎nc6320
HP Notebook PCs - Computer Does Not Start and Emits an ...
support.hp.com/us-en/document/c01732674
This document pertains to HP and Compaq notebook computers. .... light next to thepower socket or the light on the AC power adapter and note its condition: off, blinking, or constantly on. ... Battery power LED off, and Caps Lock/Num Lock off.Missing: green ‎nc6320
HP 6735s won't boot, power LED blinks 7 times - HP ...
Feb 03, 2016 | HP Computers & Internet
Got a daikin ftksgvma 7kw. Got no led lights on the head unit or noise when I press on from the controller also won't turn on from manually. Force start from compressor will only turn on compressor but...
You can cycle the power from the disconnect outside. Leave off for 10 seconds or so. Sounds like you're on the right track with the board.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Aug 07, 2017 | Heating & Cooling
Dennon gets hot shuts off
how are your four outside speakers hooked up? If you have four speakers hooked up to only two output channels on the receiver, the receiver is sensing a short and shutting down to avoid damage to the amp.
Jul 20, 2013 | Denon AVR-3806 Receiver
Hp laptop synaptics touchpad light comes on and shuts off pointer
Had this problem before, very annoying! On mine the idea was double tap to disable the track pad and then double tap again to activate it... In reality tapping rapidly in the area around the LED until the LED shut off seemed to work.
In short; double tap the LED to reactivate the track pad. If that doesn't work tap several times in quick succession until the LED turns off.
Dec 18, 2012 | HP Computers & Internet
The narration track in Photo story 3 does not
On the "Narrate your pictures and Customize Motion" page, click the little microphone icon that fires off the Sound Hardware Test Wizard. Follow those steps and see that everything is working. Then try a test recording. Also: Test your mic outside of PhotoStory Test your speakers outside of PhotoStory
Hope this helps!
Feb 23, 2010 | Dell Computers & Internet
Train powers up,lights go go.Press forward and it just buzzes.Doesn't move. New Bright said it's the 'Tender Car ".
The tender car supplies power from the track to the entire trian.
Make sure the train will run with just the Loco and the tender. Make sure the tender is securely plugged in to the Loco and make sure the the brushes under the wheels on the tender (this is how power gets from the track to the train) are in contact with the track. Finally use a scotch brite pad (DO NOT USE STEEL WOOL) to clean up the track a little.
You can also take a volt meter and measure for DC between the rails. You should have about 10.5VDC on the track. (Inside rail is neg on mine and outside is pos) ...
Hope this helps..
Bob
Dec 05, 2009 | New Bright 384 Holiday Express Animated...
Waiting for a vaild GPS signal. three days. been
You essentially have to reset the GPS. You can do this by holding the power button down for at least four seconds to get the Tom Tom to fully shutdown. You will know you successfully did this if you hear the tom tom sound and a warning message appears during startup. It then seems to work just fine after that.
Apr 08, 2009 | Tomtom XL 330 Car GPS Receiver
I have just instaled my harman kardon ks200 and there appears to be a problem? i can hear the cd spinning louder when listerning to track 1 than i can when listerning to track 10 eg. should there be a...
* Tech Stuff *
Audio CDs do not spin at a constant rate. They are designed to be read (for music) at a "constant linear velocity" of about 1.25 meters per second. The data is written in a tight spiral starting at the inside of the CD. The CD spins the fastest when reading the inside tracks and slows down as it reads towards the outside edge. Imagine circles on the CD surface. The inside ones would be smaller than the outside ones, of course. So, if you are reading evenly-spaced bits on the lines of those circles, you would need to read fewer outside circles per second than the small inside circles.
* Basic Issue *
When the player is reading Track 1 the CD is spinning at about 500 rpm. During the last tracks of a (full) CD it only needs to spin at about 200 rpm. It doesn't work the other way around for compatibility reasons.
* More Info *
This is why you are experiencing the difference in mechanical noise at different tracks. It doesn't necessarily reflect a defect, but understandably, a consumer would prefer a quieter system, which does differ between manufacturers and models (I couldn't specs for a KS200 HK device) Yet, if the noise is substantial, it may very well be indicative of a problem, e.g. something stuck in the drive and being whipped around in a circle at high speed. I wouldn't say this is particularly likely.
* Possible Help *
What would normally mitigate this issue is not getting too close to the player while listening. Normally having the primary listening position several few feet away (across the room) would suffice to minimize noise heard from fans and spooling CDs.
May 14, 2008 | Televison & Video
My K750i Key pad Lights are not working
mine does that aswell i went into the o2 shop and they said that some little LED light had blown
Aug 06, 2007 | Sony Ericsson K750
Computers & Internet Logo
41 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
