Question about Samsung WF203ANW Front Load Washer
Hi Where is the drain tube locates? - Samsung WF203ANW Front Load Washer
    Champion:
  • 274 Answers
Its in the back ,it needs to be at a 90degree angle to drain pipe
Posted on Jul 29, 2010
My Hi Super air conditioner is leaking into the house. What is the problem and how can I fix it?
It is just the condensation generated by the cooling which has to be drained from the unit via a drain tube. When the drain tube is blocked by debris (often by dust build up) the water cannot drain out and will overflow from the unit. Often these blockages will occur where there is a bend in the drain tube and sometimes these drains are not installed very well.
Open the front of the unit and locate the drain tube. You will need a long piece of strong wire or cable to run down the tube to try and free the debris and get the water flowing again. You can do the same at the other end of the tube also if need be. You may need to tip some water down the tube to help clear it also.
I think you will find it is fairly easy to resolve yourself.
Jan 08, 2016 | Heating & Cooling
WHERE IS THE DRAIN LINE LOCATED
This drain line you seek is in the freezer under the evaporator, behind the false panel. This clog can be found in the s curve of this tube behind the unit in the back by the compressor. Dust will collect in this tube and cause the slow drain or clog you seek. Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Oct 09, 2014 | GE Refrigerators
Frig-freazer. mannfactured 03 collecting water
The drain tube is attached to a tray at the base of the evaporation coils on the rear wall of the freezer section. You gotta remove the access panel to find and clear the drain. I recently worked on a frigidaire model and made a crude video:
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jul 17, 2013 | Frigidaire Refrigerators
Samsung rf265abpn ice forming behind Fresh food fan, ice filling up funnel under cooling unit, was told to hang a piece of coat hanger off heat coil.
Hi Mike,
You could have an outside airleak which would let in warm moist air into the freezer.OR the condensate drain tube is plugged up or frozen up. thats the drain tube that drains the melted ice from the freezer OR the condenser fan located buy the compressor is not running. Check all drain tubes and drain channels for clo-
ging or freeze-up due to improper and complete draining.
Oct 20, 2011 | Samsung RF265AB (258 cu ft) Bottom Freezer...
Smells when door is opened
Hi, this is most likely due to food waste stuck in the drain or the drain tube connected to the disposal. Remove bottom rack of dishwasher, then clear any debris from the drain located normally in the center. Be careful, many times I find broken glass in the drain. Next you want to check the drain line. Under the sink there is a flexible drain tube attached the the disposal or main drain stack for the kitchen sink. That is the drain for the dishwasher. Food and other things get stuck along the way and do not make it to the main drain and start stinking. Clean or replace the dishwasher drain tube.
Jun 23, 2011 | Neff 24 in. S5453X1 Built-in Dishwasher
Wet carpet (driver's side) in a 2002 Nisan Pathfinder
drain tube located under the holding tank replace tube will fix problem
Jul 22, 2009 | 2002 Nissan Pathfinder
Whirlpool Refrigerator Model # ET21PKXGN00
HI thanks for your question. the problem is with the drain tube, from freezer to the drain pan ,located at the back, by the compressor. to repair. turn fridge off, for 24 hrs. pull fridge away from the wall. clean all the coils. locate the drain tube, by the drain tray. get a small plastic hose, shove the plastic hose up the drain tube. and blow, to dislodge any debris clean the tube thanks the appliance doc.
Oct 15, 2008 | Whirlpool Refrigerators
Water Leaking
HI thanks for your question. the drain tube in the freezer is clogged, not allowing the defrost water to go down to the drain tray. to repair. turn fridge off , for 24 hrs. remove back panel from fridge clean all coils. locate the drain tube by the drain tray. use a small hose to shove up the drain tube And blow , to clear the debris from the drain tube. thanks the appliance doc. please rate my answer. thanks
Oct 14, 2008 | Frigidaire FRS26R4C Side by Side...
Lots of water in side fridge cannot reach lower pan gets past seal on to floor
hi thanks for the question the drain tube is clogged up pull fridge from wall remove back panel if any locate drain tube in the drain tray clean replace .try that thanks the appliance doc
Sep 28, 2008 | Whirlpool Refrigerators
We have ice in feezer and water dripping into refrigerator section. I think the drainage tube is cloged. How do I access and fix problem?
hi thanks for the question yes the drain tube is clogged . turn power off pull fridge from wall clean all coils locate drain tube in the drain tray let fridge thaw with doors open once thawed clean drain tube thanks the appliance doc
Samsung WF203ANW Front Load Washer Logo
79 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
