Question about Dell Ethernet Card Network Adapter
Internet connection going on and off,on the computer icon that shows that i'm connected,it has a red X then a yellow triangle with and exclaimation point in it then after that a blue shield.......i was told by hughsnet it wasn't their a problem on their end but my LAN card was showing bad......so i replaced it and it's still doing the same thing....any ideas?
    President:
  • 1,851 Answers
The symptoms you refer also could be wrong cable (cable with loosy contacts). Have you tried with another cable?
Waiting clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Posted on Jul 29, 2010
I need manual instructions for my internet settings for infinix note 2 LTE
Most phones connect automatically using cell towers. If you want to connect to a router, you might slide your finger down from the top of the screen, tap on the icon that looks like a radio signal (or an upside down triangle with a curved top), select a connection, and enter the required password. When you tap the password prompt, your KB should show. You may have to go into settings, wifi to get results, tap the lower-center icon to bring up apps, slide right or left to find the Settings app.
Apr 01, 2018 | Internet Computers & Internet
How do i service data
Please try the following solutions:
1. Make sure that if there is a hardware wifi switch, or a keyboard command for it, that it is turned on.
2. If you can not connect to a wireless network at your house, try plugging it in to connect to the internet that way.
3. If your computer recognizes neither of these, and you do not see a network icon in the tray at the bottom of your screen, make sure the drivers are installed; right click 'my computer', click 'properties', and then click 'device manager'; any devices with missing drivers will show up with a yellow triangle with an exclamation mark next to them.
More information is needed before your problem can be solved.
Dec 10, 2013 | Computers & Internet
Connecting new HP desktop - hardwiring into CISCO Valet Plus. Internet will not come up. Take the cable and plug back into old computer; internet comes up just fine. Any ideas?
Make sure that the plug is in thr correct port of the router. The ethernet cable going from the modem to the router should be plugged into a port labeled WAN or Internet. Then, after that's done, unplug your modem for about 30 seconds or so to delete the MAC address saved in the modems memory. Modems can only "speak" to one device, and they always remember the address of the device they were "talking" to. You need to clear that memory out so that the modem can address the new device, which is the new router in your case. hope that this was helpful.
Mar 02, 2011 | Linksys by Cisco Cisco Valet Plus Wireless...
Exclaimation triangle red light is on - Electrolux CUU6174
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Jan 07, 2010 | Electrolux 3.53 cu. ft. / 100 liter...
Toshiba satellite wifi not working
Hello
You might have physically switched on the adapter, but in Windows it is still disabled.
In Windows XP, click the start button, look for CONNECT TO (don't go in the all programs menu), and click SHOW all connections. A window opens showing all the connections available. If the wireless connection icon displays a red X crossing it, it is disabled.
To reenable it,
Point the mouse cursor to the wireless connection and right click mouse button. Click enable or repair.
One question though. If your computer is toshiba, you must have installed the configFree software that came with it.
If so, look to the left right of the task bar and click the ConfigFree Icon. Choose Connectivity doctor. It will diagnose your connections. If one is disabled or has a problem, a yellow triangle with an exclamation mark ! will appear on the connection.
Use the device setting thumbnail, select your WIFI adapter . A button at the right bottom side, will show either Enable (if your adapter is disabled), or disable i(f adapter is enabled). With that button, you can toggle between enable and disable. After that click the close button, and hopefully you will be able to surf the web.
Hope it helps
Hope it helps
Aug 21, 2009 | Dell Inspiron 6400 Notebook
Can't connect to internet
You are using an air card AND a network card? If this is the case, it sounds like your cards(or more specific the software) are battling for who gets internet access.
Or do you mean your air card is a wireless card? If you just have a single wireless device attached then check with your device manager and make sure everything is detected(right click on my computer, go to properties, go to devices/hardware, go to device manager). If anything is missing, or has the yellow triangle exclaimation point, then there is something wrong with your drivers.
If everything is working, then it might just be a simple wrong network setting. By default it might be trying to connect to the wrong wireless network. click on your networking device, click on connect to a network and then make sure you are attempting to connect to the right network. If you can't see your network, then there might be a problem with your router or router's settings.
Jul 03, 2009 | D-Link Vonage-enabled Wireless Router...
No internet connection
Internet connection solutions
  1. Restart the computer.
  2. Test the jack.
  3. Test the equipment.
    1. Try a different jack that you know works.
    2. Try a different cable that you know works.
  4. Check your computer settings.
  5. Renew your IP Address
    1. [x] Windows Vista
      1. Look for your Ethernet card:
        1. Right-click on My Computer from the Start Menu or on the desktop.
        2. Left-click on Properties.
        3. Click on Device Manager on the left side under "Tasks".
        4. Expand the Network Adapters and look for any yellow exclamation points. Make sure a card is listed.
        5. If there are exclamation points, or if there is no card listed, you need to reinstall the card.
      2. Set your IP address to configure Automatically (through DHCP):
        1. Go to the Control Panel in your computer (in the Start Menu).
        2. Go to Network & Sharing Center.
        3. Under "Network", go to Local Area Connection and select "View Status". In new window, choose Properties at the bottom.
        4. Scroll down "This connection uses the following items" list to Internet Protocol (TCP/IP).
        5. Select Internet Protocol (TCP/IP) and click Properties.
        6. Change to "Obtain an IP address automatically".
        7. After you have changed this, restart computer.
      3. Check to see if your network connection is on:
        1. Go to the Control Panel in your computer.
        2. Go to Network Connections. If you cannot see Network Connections, go to Network and Internet Connections and then go to Network Connections from there.
        3. If there is a red X through the Local Area Connection, or the Local Area Connection is grayed out, double-click on the X to enable.
    2. [x] Windows XP
        2. Left-click on properties.
        3. Go to the Hardware tab and click on Device Manager
        3. Right-click on Local Area Connection and go to Properties.
        4. Scroll down the "This connection uses the following items" list to Internet Protocol (TCP/IP).
        7. After you have changed this, restart the computer.
        3. If there is a red X through the Local Area Connection, or the Local Area Connection is grayed out, click on Local Area Connection and click "Enable."
    3. [x] Macintosh OS X (10.4 or "Tiger")
      1. Look for Network Cards:
        1. Go to the System Preferences panel from the Dock or Apple Menu.
        2. Open Network icon under Internet and Network.
        3. This shows your current network settings. Green lights for each device means it is connected and red mean there is no connection.
        4. Go to Show and then click on Built-in Ethernet.
        5. Under the TCP/IP tab make sure "Using DHCP" is chosen under the top option.
      2. Renew IP address. Hit "Renew DHCP" or change it to a manual address. Then restart and change it back to DHCP to renew the connection.
      3. Set your IP address to "Configure Automatically using DHCP". Under the Ethernet tab make sure that configure is set to "Automatically". Click OK until you are back to the main System Preferences windows.
      4. Check your privacy setting
        1. Go to Sharing under Internet and Network in System Preferences
        2. Under Services everything should be unchecked.
    4. [x] Macintosh OS X (10.5 or "Leopard")
        3. The left menu shows your current network settings. Green lights for each device means it is connected and red mean there is no connection.
        4. Select Ethernet from the left menu. Go to Advanced.....
        5. Under the TCP/IP tab make sure "Using DHCP" is chosen under the top option, "Configure IPv4".
      2. Renew IP address. Hit "Renew DHCP" or change it to a manual address. Click OK.Then restart and change it back to DHCP to renew the connection.
      3. Click OK until you are back to the main System Preferences window.
    // MAIN FUNCTION: new switchcontent("class name", "[optional_element_type_to_scan_for]") REQUIRED // Call Instance.init() at the very end. REQUIRED var bobexample=new switchcontent("switchgroup1", "div") //Limit scanning of switch contents to just "div" elements bobexample.setStatus('[x] ', ' ') bobexample.setColor('#674a80', '#3b5998') bobexample.setPersist(true) bobexample.collapsePrevious(true) //Only one content open at any given time bobexample.init()
  6. Make sure your computer is clear of all viruses, spyware, and adware.
Oct 03, 2008 | Computers & Internet
I have loaded the software for a WRT54G2 on the new desktop. As instructed the data for setting up my laptop was saved to a jump-drive and installed successfully on my laptop. When I try to get online...
The only problem here is the WEP/WPA key ios not correct , so better double check the key and try tp reconnect to the wireless network..
Hope that helps.........
Aug 29, 2008 | Computers & Internet
Dell Ethernet Card Network Adapter Logo
60 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
