Question about Frigidaire Ovens
I own a frigidaire electrolux oven model glgf377cba and the oven doesn't get hot, it gets warm only. I've unplugged it a few times and it worked but now that doesn't work either.
  • 3,230 Answers
Well there are many reason for that problem you can please check them one by one -
1. Make sure the power cord is plugged in securely.
2. Test the electric outlet for current. (Power switch).
3. Inspect the connections to the terminal block, means properly check the power cable that not been shorted.
4. Make sure that you are not using a lengthy power cable (extension cord). It cause law AMP supply result to oven is not working properly.
Please post comments for further help or information......
Good Luck!!
Thanks
Posted on Jul 29, 2010
My Electrolux double oven goes from "bake" to "warm oven " after about 1 hour. I try to use the other oven and it will go start to "warm oven"
is the bake element getting hot?when you put the oven on bake both the broil and bake elements come on,if just the broil element is getting hot it might take it an hour to heat up.you might just have a bad bake element,if the bake element isn't hidden does is turn red? if not it's not getting hot.
Nov 14, 2017 | Electrolux Ovens
Frigidaire electrolux oven gallry series front right element won't turn off
What is the model number? Reset the unit by unplugging or turning the circuit breaker off and then retrying.
Aug 09, 2012 | Frigidaire Ovens
Oven not getting hot
I would recommend checking the circuit breakers, assuming that there is a 230 volt supply for the heater elements. If that is OK you might have a bad heater element.
Jan 13, 2012 | Frigidaire Ovens
The digital controls on my frigidaire stove do not work. It beeps continually and it flashes F1 on the screen. The oven doesn't work but the burners do. I've tried what it says in the manual to...
F-1 is a sub-code for a few different issues. A button could be stuck, oven cavity getting too hot, or the control has a memory failure. Any of those three failures would require a new control. But first, what happened to the range when it first failed? If you unplug it and try again, what happens?
Aug 29, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
I have a Whirlpool Electric Range GY399LXUS. The oven will not turn on. The top burners work, the only button that works on the keypad is the warm button.
I am an Appliance Technician...... and you need a new clock/ECM The part where the clock is & the oven controls... under there is a big circut board that is basicaly the motherboard for your oven. And I'm sorry to inform you that I just used your model number to look up the board and it is NO LONGER AVAILABLE.... that means they just don't make that part for your oven anymore. Whirlpool didn't use that design very long because they didn't sell well, they were expensive to produce, and they had a few too many problems out of em. So BAD NEWS is they don't make the part you need to fix your oven....GOOD NEWS is you get to go shopping for a Range!!! And BUY WHIRLPOOL!!!!!! DO NOT BUY LG,SAMSUNG, GE, FRIGIDAIRE, OR ELECTROLUX!!!!
Aug 05, 2011 | Ovens
Hi. My oven stopped getting hot (elements still get barely warm) right after the temperature sensor broke off. Could the broken sensor cause this? Thanks.
yes it can and ur element is probably bad shut off power take out 2 screws on side of it n pull ito ut to disconnect wires n put new one in !!
Apr 07, 2011 | Ovens
My electrolux EOD 3360 bottom oven is getting too hot. The oven temperature light stays on even at the lowest setting or defrost setting. The inside of the oven is literally roasting hot, and anything I...
1 . If your ELECTROLUXfan oven is getting warm but takes a very long time to cook or is burning thefood more on one side than the other, then you need to check if your oven fan motor isworking you will see the blade turning fast if it is ok. if the element isheating but the fan motor is notblowing the heat into the oven then you need To replace the oven fan motor is alittle more expensive and a bit more involved.
2 . If you have the opposite problem i.e. your ovenis over heating and burning everything then you will need to replace your ELECTROLUXoven thermostat
3. A quite common and easily overlooked answer isif your ELECTROLUX oven is not working at all i.e. noheat and no fan then the chances are that someone has put the oven timer into AUTOmode, simply put oven back to MANUAL mode and all should be working again.
Mar 22, 2011 | Electrolux Ovens
I have a frigidaire oven model # PLEB30S8CCB won't get above 290
The coils should glow red when working. If the lower (bake) element does not glow it may be burnt out. Some ovens cycle the bake and broil elements during preheat and that mey be why you are getting some heat.
Aug 27, 2009 | Ovens
Older Ceramatop GM Frigidaire oven stopped working-stovetop works
If it has a timer of any description, make sure it is set to manual, refer to your instruction book.
Dec 10, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Ovens Logo
29 people viewed this question
Top Frigidaire Ovens Experts
Oloyede Monsuru
Craig Butler
Craig Butler
Starnley Johnwells
Starnley Johnwells
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
