Question about Acer Aspire 4315 Notebook
Wndows update get message "windows cannot currently check for updates because the service is not running you may need to restart your computer" the service is running and i just restarted the computer
    President:
  • 2,571 Answers
Check for virus/malware infection that may be blocking your security/OS updates
http://www.fixya.com/support/r5272277-secure_clean_computers
Posted on Jul 29, 2010
How do I fix Windows 10 update 0x800705b4 error code?
This error commonly occurs within the operating system at the time of windows updates. If this error is not fixed, it will lead your system slow or even corrupt it.
This error may arise for the following reasons,
1. windows defender update
2.
Damaged system files.
3.
Third-party anti-virus and malware.
Solution for the windows 10 updates 0x800705b4 error code:
Right here are a few solutions for troubleshooting 0x800705b4 error code,
Method 1: Uncheck the "get updates for other Microsoft products when you updates windows" option:
• Open the "Windows Update" and click "Advance Options".
• Uncheck the "get updates for other Microsoft products when you updates Windows" Option if it's marked.
• Now the update process should complete successfully.
• You may run this process continuously until you get the "your device up to date" message.
• Once this message appears, again check/select "get updates for other Microsoft products when you updates Windows" Option.
Method 2: Temporarily disable the "Windows Defender"
• In case, the above solution doesn't work, you can disable the" Windows Defender" for temporarily.
• Type Defender in the search box and open the Windows Defender Desktop app.
• Click "Settings" and turn off the Real-Time Protection and Cloud-Based Protection options.
• Close the setting window and now the windows defender appears in red.
Note: After that do all the steps in solution 1 again, hope the update process will be successful this time. Once this issue is fixed, you can turn on both Real-Time Protection and Cloud-Based Protection.
Method 3: Run the Windows Update in "Clean Boot"
You should login computer as an administrator for performing "Clean Boot".
Method 4: Run the "Microsoft Update Troubleshooter" and Restart the Windows Update:
Still, if you having update issue, download the "Windows Update Troubleshooter" and Run.
After this, restart the "Windows Update Service".
Follow these steps for Windows Update Service restart,
• Open the Command Prompt(CMD)
• Type "net stop wuauserv" then press "enter"
• Wait for the confirmation message.
• Then type "net start wuauserv" then press "enter"
Hope the above solution will fix the update issue.
Jun 12, 2017 | Computers & Internet
Tip
Checking for updates results in an error message (0x8024001D)
Running windows update, Express or Custom it does not matter, when checking for updates an error message (0x8024001D) saying “the page can not be displayed” occurs.
Rename the SoftwareDistribution folder:
Stop the Automatic Updates Service
Go to Start>Run and type in: services.msc
Click on OK or hit ENTER
In the right-hand pane of the Services window, right-click on Automatic Updates and then select Stop
Now, navigate to C:\Windows (C:\WINNT, if using Windows 2000) folder, locate and rename the SoftwareDistribution folder to SDOLD
Restart the Automatic Updates Service by re-opening the Services window,
right-click on Automatic Updates and then select Start.
Please note that a "side effect" of renaming (or deleting) the SoftwareDistribution folder is that you will lose your current Update
History listing.
Found solution here:
http://www.microsoft.com/communities/newsgroups/en-us/default.aspx?dg=microsoft.public.windowsupdate&tid=b5f7cbb5-4307-42a1-b3dd-8b259937525e&p=1
on Jun 26, 2010 | Computers & Internet
Tip
Checking for Windows updates results in an error message (0x8024001D)
When running Windows Update, Express or Custom, displays an error message (0x8024001D) saying "The page can not be displayed" error occurs.
The resolve is to rename the SoftwareDistribution folder:
Stop the automatics Updates Service
Go to Start>Run and type in Services.msc
Click OK or press Enter
In the right pane of the services window, right-click on Automatic Updates and then select Stop.
Navigate to C:Windows (C:WINNT if using Windows 2000) folder, locate and rename the SoftwareDistribution folder to SDOLD
Restart the Automatic Updates Service by re-opening the Service window, Right-Click on Automatic Updates and then select Start
NOTE: Renaming the SoftwareDistrbution Folder removes your current update history listing.
Reference: http://www.microsoft.com/communities/newsgroups/en-us/default.aspx?dg=microsoft.public.windowsupdate&tid=b5f7cbb5-4307-42a1-b3dd-8b259937525e&9=1
on Mar 24, 2010 | Computers & Internet
I looking for window 7 64 bit window installer updater
try control panel - uninstall programs. there is an option to show updates. click on this and then remove the most recent update and try updating again. Suspect last update may be corrupt by removing it it will then re-download and install hopefully a not corrupted update. also check services in control panel an see if there is an update service and stop it and then restart it .
Mar 20, 2016 | Computers & Internet
I have Vista for Business on a computer. Suddenly the log on picture shows on the screen, but the computer says the user information is unavailable and won't let me log in!
This sounds like a failed update. Restart the computer and hit either F2 or F8 or possibly Tab or Delete once the splash screen comes up. This should give you a windows startup option for safe mode. Click Safe Mode with Networking and let the computer startup. This will bypass all current startup items and possible problematic services. Login and start up Task Manager. View startup items and look to see if anything is starting up that says "Windows Update" or if anything else stands out that shouldn't be there. Names that are random garbled letters, etc. Disable these for normal startup. Now click on control panel under start menu and go to windows update and see if any updates failed to install. If they did, disable install automatically in windows update.
After this go to "run" and type in msconfig. Click normal startup, hit apply, when the message that says "restart computer" pops up click yes and let it restart the computer normally.
Sep 09, 2014 | Microsoft Windows Vista Business Edition...
Many errors after installing a new HDD on samsung R480 laptop
HI , there ,
Did you back up your data ? if so just recconect your old hard drive if you didnt format it and run windows go to my computer right click and click properties scroll down the the bottom and you should be able to see your product key jot that down and reconnect your new hard drive install windows and enter the product key.
as for the windows updates look up the error messages , you might have to copy the folder and delete the old oneas sometimes the donwload folderr gets corrupt.
Hope this helps .
Dec 29, 2012 | Samsung R480 Notebook
Windows update stops working, check for updates failed
I've found that re-registering the dlls has solved quite a lot of windows update issues. have you tried this?
see method 5 here:
http://support.microsoft.com/kb/326253
Dec 22, 2012 | Toshiba Satellite X205 Notebook
When i downloadednero burnlite the msg is coming it can run only on specific wndows , mine is windows xp version 2002. tell me the nero that can run on my p c.
to my knowledge you need windows xp service pack 3 to run it, to check your current version of xp, go into control panel, system and should say on the screen.
if its service pack 1 or 2 u will need to do all the windows updates, then install the service packs.
Jun 19, 2012 | Ahead Software Nero 9 Full Version for PC
I can see whose online but cant see any messages sent or recieved. any ideas?
hello there
Go to Run -> HKEY-CURRENT-USER> Software ->Microsoft -> Windows -> CurrentVersion -> Internet Settings ->Zones -> Delete folder other than 0,1,2,3,4
if the problem is still exist your internet explorer having problem. try sfc /scannow.
thanks
Mar 05, 2011 | Yahoo Messenger
I have only just today received my brand new HP Pavilion dv7 4070eb and commenced installation straight away. There were no problems in the initial installation and I booted Windows for the first time...
I had the exact same problem.
As some nice fellow pointed out at HP forum, HP as a downloadable package that should fix this problem:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c02219204&cc=nl&lc=en&dlc=en&product=4213233
Kinda sucks thought that thoses folks at HP Support are not even aware of it...
Jul 08, 2010 | HP Computers & Internet
Acer Aspire 4315 Notebook Logo
87 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
