Question about SNK Magnavox 42MF438B/27 42 in. LCD TV
I have a magnovox 42 inch tv model number 42mf438b/f7 and it has a built in screen shut of sensor for when the tv starts to get too hot. It is 16 months old and the sensor has been turning the screen of sooner and sooner over time to the point where it now goes off after about 15 minutes of play time. I did notice that when I unplug it for a while it takes significantly longer (over an hour) before the screen shuts off so the tv must be retaining some heat when it is plugged in and turned off or there is some other reason for this phenomenon. Any help or information would be appreciated.
2 Suggested Answers
SOURCE: Magnavox 42 LCD 42mf438b/f7 turns on/off by itself
I have exactly the same problem with a Magnavox LCD 42", very similar model 42MF437B/37. I don't have a solution. If you unplug the TV and plug it back it starts working, sometimes for hours, sometimes for less than 5 minutes, before it turns off again. Does anyone have any real solution?
Posted on Aug 01, 2009
Philips 42PFL3704D/F7. Why does it keep restarting?
Philips 42pfl3704d/f7 power reset when HDMI, USB, or cable ...
www.badcaps.net > ... > Troubleshooting TVs and Video Sources
Oct 9, 2012 - 5 posts - ‎2 authors
Philips 42pfl3704d/f7 power reset when HDMI, USB, or cable attached ... or Cable TV to unit the power resets, philips screen comes on and keeps on resetting. ... I tried a cable to the tv without the box and I do get picture.
Philips 42PFL3704D/F7 42-Inch 1080p LCD HDTV
www.amazon.com/Philips-42PFL3704D-F7.../B001LP...
Amazon.com, Inc.
Rating: 3.3 - ‎50 reviews
Amazon.com: Philips 42PFL3704D/F7 42-Inch 1080p LCD HDTV: Electronics. ... Will do all I can to prevent others from getting ripped off by Philips. ... came up every few weeks and would take an hour or so of reset before working properly.
Visit the support page for your Philips LCD TV 42PFL3704D ...
www.philips.ca > philips > Televisions > 3000 series
PhilipsFind support for your LCD TV 42PFL3704D/F7. ... How do I output sound from myPhilips TV to external audio devices such as Home Theaters, Soundbars, AV ...
42" Philips 42PFL3704D/F7 LCD TV WON'T COME ON - A
Dec 29, 2015 | Televison & Video
How to take base off magnavox tv 42MF438
Remove the machine screws that attach the base to the rear of the TV.
Jan 04, 2015 | Magnavox 42MF438B 42-inch 1080p LCD TV...
What is the best lcd tv (Samsung or LG) 42 inch ? And what is the differences?
Samsung LED Tv is cheaper and is more vibrant forget the LCD models they run hot anyway. the link below are the top selling models here in Australia LED TV is either 40' inch or 48'' why?....as most newer models now has the correct 16:9 1920x2160p screen ratio as compared to the previous 1360x768 old (35mm Cinema screen aspect widescreen size) ie: no more black cropped DVD movies watching on a widescreen Tv check the link and compare the prices and model number of the best of the best on LED TV's here >> http://loadedtrolley.com.au/costco-australia-price-lists/costco-australia-television-price-list/ but, i would take yourself down to a store as only you can judge for yourself in what your eyes tell you....;but i repeat....LED TV is the way to go Not LCD !!!
Jul 30, 2014 | Televison & Video
Need to find out a part # for my philips 52PFL7403/f7 for the ir sensor
Join Date: Nov 2011 I have a Philips 47PFL3603D/F7 with the same problem. It was the IR sensor board causing the problem. You can search online to find the board, which almost everyone will most likely not have in stock, and cant be ordered. The part you need is this: 313926859181 IR Remote Sensor.
Models it will fit are as follows: Substitute Parts 313926859182
Known Models
MAGNAVOX 42MF438B/27
MAGNAVOX 42MF438B/F7
MAGNAVOX 52MF438B/27
MAGNAVOX 52MF438B/F7
PHILIPS 32PFL3403D/85
PHILIPS 42PFL3403D/27
PHILIPS 42PFL3403D/F7
PHILIPS 42PFL3603D/27
PHILIPS 42PFL3603D/F7
PHILIPS 47PFL3603D/27
PHILIPS 47PFL3603D/F7
PHILIPS 52PFL3603D/27
PHILIPS 52PFL3603D/F7
If you can find the board, great! A replacement board costs about $12.00. If you can't... we'll there is something you can try ; )
Either way, if you know it's the board, what's the harm in trying?
Remove the back from the TV. You can actually leave it on your stand to do this if you can spin it around to gain access to the back of it. Be sure to unplug everything first!!!
Looking at the back of the tv, the board will be located in the lower left side by the speaker. It will have 2 cables attached to it. Remove them, and take out the screw or two that holds it in place. There will be a plastic tab that keeps it in place also.
Take your fingernail and bend the tab back, and the board should come free. After that you should be holding the board in your hands. The side of the board with the connectors on it is the side you want to manipulate. There will be a tiny surface mounted capacitor beside one of the wire connection sockets. Take a utility knife and scrape it off/ you could use a soldering iron but it should come off very easy with a knife.
Plug it back in, and give it a try! If it works... great! If not, find a replacement board, and try that.
May 30, 2011 | Philips 52PFL7403D 52 in. LCD HDTV
I have a Magnavox 32 inch flat screen, model # 32mf338b/f7. We used some generic universal remote, now it is stuck on 4:3 screen ratio. I cannot figure out how to get it back to the normal 16:9 ratio. ...
32MF338B F7 Magnavox
Go to above link and download the user's manual. Follow instructions to change to 16:9 setting.
You can also press the format button on your remote to change to 16:9 format.
Semper Fi,
Z
Jan 29, 2018 | Televison & Video
Magnavox 42 LCD 42mf438b/f7 turns on/off by itself sometimes screen goes blank tv unresponsive to remote
Jul 08, 2009 | SNK Magnavox 42MF438B/27 42 in. LCD TV
Mine was doing the same thing. Update the firmware and it fixes the problem. Updating the firmware is done by downloading the file to a thumb-drive from the phillips product support page then plugging in the drive into the side of your television and turning it on. See your manual for slightly better instructions.
Jul 08, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Need help with TV calibration for philips
Try these, Contrast: 53 Brightness: 56 Color: 45 Tint: 2 Sharpness: 2
Color temperature: Off
Dynamic contrast: Off
Digital Natural Motion: Off
DNR: Off
Color enhancement: Off
Active control: Off
Feb 14, 2009 | Philips 42PFL3603D 42 in. LCD TV
SNK Magnavox 42MF438B/27 42 in. LCD TV Logo
115 people viewed this question
Top SNK Televison & Video Experts
matt martin
matt martin
Are you a SNK Televison and Video Expert? Answer questions, earn points and help others
