Question about Toshiba Satellite M45-S265 Notebook
Power loss Since last night my computer has been saying that it is losing power even though the cord is plugged into the socket and into my computer, I have tried re-plugging them all in and it is still losing power, can I buy a new power cord?
  • Anonymous May 20, 2008
    my laptop is plugged in and the light on the front of the machine indicates it is plugged in. but the machine still runs on battery power. is there a way to make the machine run on ac power?
    Scholar:
  • 61 Answers
Yes you will be able to replace the power cord and transformer (the black box).
Just to be sure thought. Shutdown your laptop and plug the cable into the laptop again. The laptop should show LED's on the front of it to show that the power is plugged in and is charging the battery. This is usually symbolised by a green or orange led.
The easiest thing to change for now would be the cable but if you continue to have issues you may have a larger problem with the power input module within the laptop itself.
Posted on Apr 24, 2008
My lg 50 pn45 made a loud pop sound last night and shut off when I tried to turn it back on makes a crackling sound in the back where the power cord plugs only stays second and shuts it self back off
Fault to the main power supply regulator section. Either it will be on a separate board, or on the part of its main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Sep 03, 2015 | LG Televison & Video
Magic Jack frequently loses connection even though it should stiil work when offline
To use without computer plug ethernet cord into magicjack otherend into router plug phone in to magicjack plus plug magic jack plus int power adapter plug power adapter into power outlet should work but does not no calls in or out in reverseorder and has to be online with internet conection .
Dec 27, 2013 | magicJack Plus Pc To Phone Adapter
My hp pavilion a430n is not turning on. even though i pressed the power button the light wont even turn on. it is truly annoying and the screen says something about the power supply and green, red, blue...
I suggest to open your computer and unplug your power supply and look for the color green and black cord which plugged from your motherboard. Then find a piece of wire and short the color green and black wire to test if your power supply is working and plug to your power socket. And check your electronic parts (capacitor) near at your processor, it might your capacitor blown out.
Nov 15, 2010 | HP Pavilion a430n PC Desktop
I left it on last night. This morning it was off
check your power cord to insure that you are getting power. make sure power cord is plug in the back.
look in back of computer. you will see a little orange switch. it says 115/220 click to 220. boot computer.
if computer boots up turn off and click back over to 115.
if it does not boot your power supply in your computer needs replacement.
Nov 14, 2009 | HP Pavilion a1410n (ER890AA) PC Desktop
I have a Gateway ml6720 and when I plugg it in to charge the light goes on and off now it will not even come on. Is it the cord or the peice in the back?
Most likely you have lost the charger "brick" itself. I have though seen an increase in the power cord that plugs into the wall socket go bad and that would be the last piece I would think of going bad but they do. The easiest way to test the cord is get another power cord that plugs into the power "brick", if the light comes on and stays on, then it was the actual power cord and not the adapter (brick) part. Less expensive "bricks" tend to run very hot and therefore do not last long. The cheaper "bricks" that are made in China, tend to last less than a year under normal load.
Nov 03, 2009 | Gateway ML6720 ML6721 ML6725 Keyboard...
Unit keeps losing power. Cord has power light and
I had the same problem. It was the pin inside the **** clamp that was broken. As I wiggled the plug in the unit the pin would dislodge. eventually the pin got lodged in the 12v power cord.
May 16, 2009 | Magellan RoadMate 700 GPS Receiver
Battery indicator flashes even when plugged in to electrical plug, computer recognizes plug-in. Computer will not run with power cord.
The battery indicator flashing when plugged in to electrical plug means your battery is completely dead and won't charge. You're computer should run with just the power cord. Your power cord most likely needs replacement.
If you know anyone with the same model of laptop ask if you can borrow their power cord and/or battery to test it out. It is rare for the problem to be the motherboard, though it does happen.
It may just be the power cord at fault as the computer should run without the battery, so you should replace the power cord, as it is probably the reason the battery is completely dead.
If the battery is at least a year old I would replace it since they generally don't last too much longer than a year.
Sep 09, 2008 | IBM ThinkPad T40 2373 Notebook
Computer power won't turn on
First thing to do is try to plug the pc in another wall socket to see if it goes on, If not, the MB could have gotten fried, even though the other plugs seem to work. Hopfully you just need another surge protector as that could have gotten damaged.
Jul 20, 2008 | Computers & Internet
Open Questions:
See all Toshiba Satellite M45-S265 Notebook Questions
Toshiba Satellite M45-S265 Notebook Logo
59 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
