Question about TallyGenicom 8008 Laser Printer
Where te find driver tallygenicom 8008 for win exp
    President:
  • 2,571 Answers
I don' t know de printer' s ip address. how I can learn it? the printer is tallygenicom 8008
You can print a configuration page this will show you the current IP Address set in the printer, this Can be printed in the follwoign way;
  • Place printer OFFLINE
  • Press MENU / ENTER button
  • The display should read TEST MENU (if it does not press > repeatedly until it does)
  • Press > until CONFIG PAGE is seen.
The printer will print out a configuration page this will show the network settings
Dec 01, 2010 | TallyGenicom 8008 Laser Printer
Printing only black in TallyGenicom 8108N
You can change the colour setting in the printer driver to Black Only, this means you will only print Black and White using only the black toner.
To make this change on Windows XP;
Open the Printers and Faxes Folder.
Right Click on the printer driver for the 8008.
Select Printing Preferences.
Click on the Color/Print Quality Tab.
In the Color Mode section select the B&W radio button.
Click on the APPLY button
This should change the pritner driver to print only black and white.
Mar 23, 2010 | TallyGenicom 8008 Laser Printer
TallyGenicom 8008 driver issue windows 7 x64
call the company Dascom they'll send you the x64 driver.
Mar 02, 2010 | TallyGenicom 8008 Laser Printer
SVC EL ERROR appears on the display
The SVC EL error on the 8008 indicates an 'ERASE LAMP' error.
The erase lamp in the 8008 is situated below the OPC belt in the printer, as a step to fixing the problem I would suggest removing the OPC belt from the printer, and taking suitable precautions to protect it from light and damage.
Then clean the area under the OPC belt in the printer to remove any stray toner.
Then test the printer, if the problem persists I would recommend having a suitably qualified engineer look at the printer. To check the Erase LED array is connected correctly and is functioning correctly.
Jun 21, 2009 | TallyGenicom 8008 Laser Printer
Tally Data Recovery
I suspect you do not have a problem with a TallyGenicom 8008 more likely with a the Tally Solutions ERP system check the following page for tallysolutions contacts and support
http://tallysolutions.com/newwebsite/html/index.html
May 30, 2009 | TallyGenicom 8008 Laser Printer
Tallygenicom 8008 not recognised in xp
I do not think there was a driver version 1.5 for the 8008 I believe only one version of driver was released for the 8008 for XP this was version 1.00
I think your search for later driver will be fruitless.TallyGenicom went Chapter 11 and are no more, I think thwy were taken over by dascom (www.dascom.com) who now sell Tally Dot Matrix printers.
I think your best option would be to check how the pritner is connected.
If connected via USB ensure the printer is correctly plugged in, make sure you have the USB cable connected to the USB port on the printer NOT the network port (it happens!!)
Plug the printer into a different USB port on the PC in case there is problem with the particular port.
Try a test page from the printer driver once you have installed it, see what errors you get.
If the printer is networked, ensure you can PING the IP Address, in the printer driver ADD A STANDARD TCP/IP port to print to the printers IP Address.
Post any errors or specific problems you see, how the pritner is connected we may be able to help some more.
May 04, 2009 | TallyGenicom 8008 Laser Printer
SVC E9 ERROR
butta via la stampante e prendi una hp
Jan 17, 2009 | TallyGenicom 8008 Laser Printer
Tally 8008 not printing mac OSX 10.5.6 leopard
Found a solution. We connected 8008 printer to imac running Tiger & we can now print via network on any of our emacs running Leopard. Not ideal but at least we can now use the printers. I would still love a dedicated driver to work direct but I suppose this will do for now.
Jan 13, 2009 | TallyGenicom 8008 Laser Printer
Tally 8008
SVC E2 error on the 8008 indicates a Main Motor Failure.
Jun 23, 2008 | TallyGenicom 8008 Laser Printer
TallyGenicom 8008 Laser Printer Logo
144 people viewed this question
Top TallyGenicom Office Equipment & Supplies Experts
Kolbrun...
none
Raj Patel
Are you a TallyGenicom Office Equipment and Supply Expert? Answer questions, earn points and help others
