Question about Samsung Office Equipment & Supplies
Paper feed problems with Samsung M-2010 printer
I have an ml-1740. i like it just fine. this week i had a prblem where the paper came out of the printer crinkled on the right side and the printed image was a little tilted. (if i feed through the manual feed it came out perfect) i was going to inspect all of my rubber wheels when i noticed small chunks of paper that had wedged themselves in the paper path from the tray. simple fix -- clear anything and everything from the path 1st! hope this helps someone out there.
Posted on Jul 25, 2008
My Samsung ML-2010 laser printer grabbed up 2 sheets of paper and now both are jammed. I can't pull them out. Now what could I do?
Removing paper jams from printers can be tricky. You'll want to be careful to not tear off the paper. Always try to pull the paper in the feed direction if you can. The Samsung should have a doo in the back or in the paper area that can be opened to assist in removing the jam. If this persists, you may need to replace the paper feed rollers.
Feb 03, 2011 | Samsung Monitors&Printers Monochrome Laser...
Paper stuck - Samsung ML2010
Clean the roller with 409/simple green or water. Use a cloth not paper towel. NO alcohol. Rub it up good and it should start feeding. steven 818-888-0006
Apr 27, 2010 | Samsung ML 2010 Laser Printer
Printer jammed - removed jam but paper guide not resetting and on line error remains.
Had the same problem. Make sure you have put enough paper in paper feed tray (more than 10 sheets) and lock paper from sides. Take out ink cartridge and reinsert it.
Hope this works for you ^_^
Jul 17, 2009 | Samsung ML 2010 Laser Printer
Samsung ML 2010 won't paper feed
Lift up the front of the machine a couple of inches. I put a small bo under it. The paper then feeds slightly downhill.
Worked for me.
Jan 30, 2009 | Samsung ML 2010 Laser Printer
Laser printer ml 2010, paper pull in problems
I also have the ML-2010R and I also had the paper feed problem. with warnings about paper jam around toner cartridge.
After a bit of reading and people mentioning the big roller that picks up the sheet of paper and that it needs replacement; I decided to carefully try to clean that rubber roller.
I used a brush and medical alcohol to clean the roller. After letting the roller dry I put in some paper and tried to print again and for me it works like a charm!
Jan 19, 2009 | Samsung ML 2010 Laser Printer
Not feed paper
it may be that the paper is too slick for the grabber to access...try a little heavier bond paper(not the same as copier paper, which is SLICK.
Jul 27, 2008 | Samsung ML 2010 Laser Printer
197 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
