Question about Maytag Washing Machines
My wonderful 20yr Maytag washer is suddenly making a horrible noise when started and had leaked a lot after last load. I found a washcloth jammed between basket and it's frame. Water comes into machine, it spins and drains. What do you think?
  • robin966 Jul 29, 2010
    Not sure yet......gonna try it.
  • Maytag Master
  • 8,220 Answers
Probably needs a new pump. The bearing separate in them. Tip the washer back and remove the belt(no tools needed. Try to turn the pump. To replace the pump (if that is it) Take 3, 3/8ths bolts out and disconnect the 2 hoses. Nothing to it. Manuals and more here
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Jul 29, 2010
  • Dan Webster
    Dan Webster Jul 30, 2010
    Thanks. Tip: spend some money and get your machine repaired. You do not want the nightmares that are with these new washers that require tiny amounts of soap an frequently go bonkers when you overdose them with soap suds; this cost tons of money to repair also. Go ahead and spend the money on repairing your washer.
My maytag MAH550BWW has recently started making a horrible howling noise. It is otherwise working perfectly. It is draining good and not leaking at all.I have taken both hoses off the pump and found...
Had the nd error and smelled like burning wires. Read a review here and removed drain pump and a piece of plastic stuck in the impeller. Removed,inspected and reinstalled. Worked perfect! Thanks
We were heading out next day to buy new washer and dryer at $2000! Yikes!
Apr 28, 2011 | Maytag Neptune MAH5500B Front Load Washer
Makes a horrible noise when spinning
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems
Washer noise when spinning
heatman101
Feb 11, 2011 | Hotpoint Aquarius WF000 Front Load Washer
The washer made a horrible noise and the tub seems to be loose from the machine. Can I fix it? The tub in my Frigidaire stacked washer all of a sudden with a fairly heavy load of jeans started making a...
you need to remove the agitator and check the bolts that hold the trunion to the shaft and make sure they are not broken.if one is just replace them make sure that the bracket is in the flat key way on the tub hope fully the tub seal is still good.
Oct 15, 2010 | Frigidaire FEX831CS Top Load Stacked...
Washing machine makes a horrible noise in spin cycle and turns itself off. When we hold the Start and Cancel button together we get code E23.
Washer Problems Washer noise when spinning
heatman101
Sep 04, 2010 | Frigidaire Affinity ATF6000F Front Load...
I have a leak under my maytag wadshing machine only when i do laundry what is the problem
the seal on the washer is leaking soon the bearings will start to make a lot of noise as the water leak will wash all the grease out of them
Aug 05, 2010 | Maytag Neptune MAH5500B Front Load Washer
WAsher BROKE!
lift the lid up and down,if you don't hear any clicking the lid switch broke,if that's not it check the motor coupling,take the two clips off that hold the pump in place,remove the two screws and the two clips that hold the motor in place and the coupling is on the back of the motor,if the washer is dead it's the lid switch,if it makes a grinding noise but doesn't move then it could be the coupling,let me know how you make out
Jul 17, 2010 | Kenmore 22422 Top Load Washer
Leaking washer
This is going to be the tub seal. Take the front off and check to see if the water is leaking right where the tub and the transmission meet and if so the seal is leaking. This also makes the washer noisy. This page should help http://appliance-repair-it.com/Maytag-tub-seal.html
Sep 15, 2009 | Maytag LAT3600A Top Load Washer
Loud noise thourghout the cycle
I would have the counter-balancing system checked for proper motion.
Jun 07, 2007 | Maytag Atlantis MAV6000 Top Load Washer
Washing Machines Logo
23 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
