Question about Lands Phones
Presidian 6.0 phone and answering machine book
I have a presidian 6.0 cordless phone and answering machine. I have forgotten how to access my messages from an outside phone and cannot find my instruction booklet. Please tell me the steps or range of codes necessary to access messages from an outside phone. Thank you. My email address is: dovgadolus@yahoo.com
cindystauart
SOURCE: How to retrieve messages from the answering machine ..remotely
Remotely Operating Your Answering Machine
Call your telephone number and wait for the answering machine to answer. If the answering machine is off, it will answer after about 10 rings and series of beeping sounds.
During the greeting message (or a series of beeps when the answering machine is off), press [0] and enter your PIN code within 2 seconds (see "Setting a Security Code or Personal Identification Number (PIN)" on page 54).
The answering machine announces the current time and the number of messages stored in memory. You hear "To play incoming messages, press zero-two. For help, press one-zero." You will hear a beep.
Enter a remote command within 15 seconds, each command there after must be entered within 2 seconds.
Posted on May 12, 2008
SOURCE: answer machine
I need a instruction book for 5.8GHz i6772 phone
Posted on Sep 16, 2008
SOURCE: ge dect 6.0 phone, model no. 28112EE2-A
My GE 28112EE2 phone that I have had for 1 year now started ringing last night and listing that line 1 is in use and it will not stop. also I have a lot of interference on the phone. I lost the manuel. can so one let me know way my phone is acting nuts, I can get calls in.
Thank you  Dana
Posted on Jan 25, 2009
axebro112
  • 56 Answers
SOURCE: How to access messages remotely
While you are away from your home or
office, you can use a touch-tone phone,
or a pulse (rotary) phone with a pocket
tone dialer (available through your local
RadioShack store) to enter your PIN and
do any of the following:
• set the phone to answer or not
answer calls
• listen to your messages
• record a new outgoing message
• erase messages
• monitor the room where the phone
is located
Notes:
• You cannot remotely operate the
phone using its handset or another
telephone on the same line as the
phone.
• You can also listen to the message
recorded on Line 2 by making a call
to Line 1’s number (or vice versa).
USING THE TOLL-SAVER
If RING TIME is set to TS (toll-saver),
(see “Setting the Number of Rings” on
Page 15), the phone answers after three
rings if you have new messages (ones
you have not listened to). If there are no
new messages, the phone answers after
five rings. This gives you time to hang
up before the phone answers so you
can avoid unnecessary long-distance
charges.
Note: Toll-saver works only on the line
you called. If Line 1 has no new messages,
but Line 2 has one, the telephone
answers after five rings when you
call Line 1.
USING REMOTE
COMMANDS
Follow these steps to operate the phone
from a remote location.
Note: If you wait more than 15 seconds
between keypresses, the phone sounds
a long beep and hangs up.
1. Dial your phone number and wait for
the phone to answer.
2. If the phone is not set to answer
calls, it answers after about 10 rings
and sounds a series of beeps.
3. When the outgoing message begins
(or the phone sounds a series of
beeps), press #, then enter your PIN
within 2 seconds.
If the PIN is correct, the phone announces
the day and time, then it announces
the number of new and old messages.
The phone plays all new messages,
then beeps about every two seconds to
let you know it is ready to accept remote
commands.
Notes:
• If the phone does not respond, try
entering your PIN again. If you enter
an incorrect PIN three times, the
phone beeps and hangs up.
Remote Operation 27
• When the phone is operating from a remote location, it stops all answering functions
and rC appears on the display on the base. The phone resumes answering
functions when it is no longer in remote operation, if you have not turned it off.
• The remote playback of incoming messages is limited to 4 minutes. If you have
more messages after 4 minutes have passed, you must press # 2 again to listen
to the rest of the messages.
• When using remote operation, you can only delete the current message during
playback. You cannot delete all the messages stored at one time.
The following table shows the remote commands you can use.
Note: Remote operation stops when someone picks up the handset and presses either
LINE 1 or LINE 2 (whichever is flashing), or any phone on the same phone line.
Remote Commands
Press #
then (within
2 seconds:
Function
Repeat current message during playback.
2 Play messages.
3 Skip current message during playback.
4 Delete current message during playback.
5 Stop playback, recording, and room monitoring.
6 Set the phone to answer or not answer calls.
7 Record or stop recording a new outgoing message.
8 Play the outgoing message.
9 Switch to the other line (Line 1 or Line 2).
0 Monitor the room where the phone is located for 15 seconds
Posted on Mar 19, 2009
  • 3 Answers
SOURCE: don't have instructions to record my message on the digital answering machine
I believe you use the "memo rec" In the silver color on the base, second line of buttons on far left.
Posted on Apr 20, 2009
No manual, don't now how to answer the answering machine?
Search Results
    Recovering deleted messages from a digital answering machine ...
    www.technibble.com > Forums > Other Discussions > General Chat
    Dec 9, 2013 - Recovering deleted messages from a digital answering machine ..... AT&T cordless phones - I don't know how similar that would be to Uniden.
    How to retrieve deleted messages from digital answering machines ...
    forums.verizon.com > ... > Home Phone (Landline or Digital Voice)
    Mar 16, 2015 - I have to say, though, I doubt you'll be able to recover the messages. Digital answering machines typically don't have an un-delete. Good Luck.
    How Do I Access Voice Mail? ' magicJack Check
    mjcheck.low.li/2013/12/how-do-i-access-voice-mail/
    Dec 14, 2013 - Delay needs to be at least 30 seconds because voicemail takes just over 30 ... If you don't know your four-digit pin, it's possible you haven't ...
Jan 05, 2016 | HQRP Phone Battery for VTech CS6529-2...
Answering machine turned off but voicemail message displaying on handsets
i have the same problem, looks like it is just a bad set up and taking it back. My guess is I had bluetooth setup at one point to sync my cell with the phone and the phone registered the mail queue of my cell phone and not the mail of the cordless phone unit, so despite clearing it from the cordless phone, it still thinks there is voicemail from when it last accessed my cell phone. Terrible...and I can't find a solution either and won't waste time doing so... returning it.
Nov 04, 2012 | Panasonic Kxtg155 Dect 6. Linktocell Via...
GE 21008GE2 2.4GHz Dual-Handset Cordless Telephone. Lost manual. Need to know how to access my answering machine messages from another phone out side of the house.
You can download the manual at
http://www.home-electronics.net/USER-GUIDES/21008_DOM_ES_CL_IB.pdf
The 21008GE2 is a phone, not an answering machine. It doesn't store messages that can be accessed from the phone or another phone.
If you want to access messages on an answering machine, you'll have to tell us the make and model of the answering machine.
Jul 29, 2011 | GE 21008GE2 Dual-Handset Cordless...
How to i check the messages when away from home on my presidian cordless 6.0 dect phone with answering machine
Since you neglected to specify the model of your Uniden DECT 6.0 system I can only suggest you select it from the list beginning here to download a copy of the manual.
May 11, 2010 | Uniden DECT 6.0 Cordless Phone ID
Callers cannot leave a message when I am on the phone.
caller id does not work when you are on the phone. You have to have teh line open, caller ID is only one line and only allows you to switch back and forth, the answering machine is not hearing teh call only you are.
May 05, 2010 | Lands Phones
User's Guide for a Presidian Corded and DECT 6.0 Cordless Phone
You might want to try http://www.radioshack.com/graphics/uc/rsk/Support/ProductManuals/4300259_QS_EN.pdf
Jul 24, 2009 | Lands Phones
GE PHONE/ANSWERING MACHINE MODEL 25952EE3-A
I am getting a "new voice mail " message on the receiver. I can't access it. I have had the phone for 6 months and never saw that before. I did however just get Verizon Vios installed.
Jul 06, 2008 | Uniden Cordless Phone
Uniden cordless phone 2.4 Ghz
I have a Uniden 900 MHz cordless phone and answering machine. Is there a way I can retrieve messages when away from the office / answering machine?
Robert Foley
(913) 232-7288
rjfoley@kc.rr.com
Jun 18, 2008 | Uniden Cordless phone EXS9950
Lands Phones Logo
117 people viewed this question
Top Lands Phones Experts
Marvin
Marvin
David Burbee
David Burbee
Are you a Lands Phone Expert? Answer questions, earn points and help others
