Question about Echo Rapid Loader, Trimmer Head
I have a new echo trimmer with attachment series from home depot and the weed eater head turns counter clockwise, but the edger attachment turns the correct way. Is there a way to make the weed eater head turn clock wise or do I need to return to store?
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 183 Answers
There isnt anyway to turn the head the other way round as its ment to run that way just go round the edges the other way
Posted on Jul 31, 2010
How to check fuel needle setting in Echo 2100 weed eater
Jack, Check the attached links for trimmer carb. tuning,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Tune Up an Echo Trimmer
http://www.echo-usa.com/getattachment/e8f287f6-0f5c-4f36-b0fa-ea8fa4a550b9/SRM2400241025012501S2510es_120194
echo srm 2100 weed eater
May 07, 2016 | Echo Garden
To change the blade which way does the nut turn to get it off? Clock wise or counter clock wise?
Most weed eaters are opposite to conventional thread. So they are CLOCKWISE to take off
Apr 30, 2016 | Weed Eater PE550 8-1/2-Inch 22cc 2-Cycle...
Drive head rotates counter-clockwise. Can't get it back into position. Use to be able to simply turn it back around. Can't now.
Husqvarna 128 LD Weedeater Repair Questions,... - Fixya
www.fixya.com > Forum > Lawn Trimmers & Edgers > Husqvarna
Recent Husqvarna 128 LD Weedeater questions, problems & answers. Free expert DIY tips, ... Drive head rotates counter-clockwise. Can't get it back into ...
HOW TO CHANGE HEADS ON HUSQVARNA 128LD - Fixya
www.fixya.com/support/t20975899-change_heads_husqvarna_128ld
Oct 25, 2013 - Question about Husqvarna 128 LD Weedeater ... SOURCE: MyHusqvarna 128LD primer bulb .... Drive head rotates counter-clockwise.
Weed eater bogs out at full throttle - Fixya
Oct 07, 2015 | Husqvarna 128 LD Weedeater
I put brand new carb on weed eater snapper s31sst model runs wide open when should idle and close choke it idles down the way it should my cell changes the letters I type in
Check the the ldle screw play with it screwing counter clockwise or clockwise don't play with the high and lo adjusters
May 30, 2015 | Garden
Is there a diagram showing how carburetor gets fuel on echo 210 weed eater?
I found that the fuel line kit sold at "Home Depot" has a diagram showing how the fuel lines are routed. The kit includes a wire tool so that you can pull the new fuel lines thru those little holes in the fuel tank. Hope this helps.
Nov 06, 2014 | Garden
Weed Eater Straight Grass Trimmer, 25 CC, 17-in. The trimmer line releases too easily and wastes most of the line.
Some of the weedeater heads are known to be ineffective and quite troublesome. Try Home Depot maybe for a universal type head that will hold and feed line the way you want. They have strimmer parts.
Aug 30, 2010 | Garden
Ryobi weed eater head won't spin
Sounds like the clutch has taken a long trip south. If the clutch pads are not wore out, try some wd40 on the pad hinges.
Apr 27, 2010 | Ryobi Garden
Rapid Loader clogged
We fixed it ourselves. We first removed the rapid loader head from the weed eater, then loosened both sets of screws on the top of the loader, enabling my husband to unjamb the little slide, retightened everything, reinstalled the head and it seems to work fine.
Aug 15, 2009 | Echo Rapid Loader, Trimmer Head
Troy Bilt 4 cycle weed eater - trimmer head doesn't spin
rotate attatchment head slightly while inserting driveshaft
Jul 30, 2009 | Garden
Don't know how to install new string on Echo SRM 2400
Cut two separate pieces of string, about 7 ft. each.
Stick the end of the line in the hole on the inside of spool.
Wind clockwise onto spool, putting the line that is closest to the ground on first.
Once you have winded this piece on, lock the last 4 inches of line through the slits on spool.
Repeat process for second piece of line, locking the last 4 inches in slot opposite the other locked in piece.
Put the spool on the trimmer, feeding the end of lines through either hole on trimmer.
Before you push the spool all the way on, pull the strings out of the locked position.
Jim
Jun 29, 2009 | Echo Rapid Loader, Trimmer Head
Echo Rapid Loader, Trimmer Head Logo
247 people viewed this question
Top Echo Garden Experts
Jim Parker
Jim Parker
colesmowers
Phil Walker
Phil Walker
Are you an Echo Garden Expert? Answer questions, earn points and help others
