Question about Insignia IS-LCDTV32 32 in. Television
T.v flatscreen (INSIGNIA)
I bought this tv about a month and half ago and everything was great until the last 2 days i turn it on and there is sound but no picture. We don't have satalite only cable so why arent i getting a picture on this brand new tv....................
  • 2 more comments
  • montycristo May 01, 2008
    Followed steps on this blog, but I have sound and no picture.  I get purple and black vertical lines and that is all.  The audio works through the TV with both satellite and dvd, but no picture.
    Should I just kick it in and toss it on the street.
  • johnny25 May 02, 2008
    flashing screen
  • Anonymous Jun 11, 2008
    LCD/DVD COMBO HAVE IT FOR 3 MONTH TURN IT ON NO PICTURE SCREEN ALL WHITE (INSIGNIA 26")
  • arc871 Jun 26, 2008
    Had an isngia for two years. Try to power it up no sound or picture. The bluelight blinks and the screenitself blinks. Do I need a new power board?
    Problem Solver:
  • 6 Answers
I just found the replacment power bd. part# 667-L32K5-20C from partstore.com MFG. is advent works great $68.00
Posted on Jun 05, 2008
    President:
  • 2,712 Answers
This is most likely due to 2 problems -Temperature or a bust capacitor,
1. There is a simple trick...just warm the back of the TV with a hair dryer for 5-7 mins after you have unplugged the TV. Look for the little areas of holes in the back panel of TV. Use these as your guide at where to use hairdryer., but don't hold the dryer too close(say 5-6inches away). (Make sure the dryer is on High heat). If the TV doesn't turn on after you have heated it up (like it tries to come on but then turns off) you need to unplug the TV again, this resets it. And repeat those steps till it works. Reseting the TV after it fails to turn on is the key. Also, just leave the TV on. Don't turn in off. Since it is LCD, it doesn't take much power...only a few bucks extra a month for your utility bill.
2. You can also try this..if you unplug the TV, and hold in the power button while plugging it back in, this will reset the TV, and sometimes it comes on.
3. If you want to go in for a long term solution, you can easily replace the whole power board (should be about $20 or so), or just change the faulty capacitors. You can make out which are faulty, because their caps will be swollen on top. Here's a pic
Check the specifications of the faulty capacitors, and get the replacements from your local electronics shop. If you are comfortable with this, you can use a pair of needle nose pliers to G-E-N-T-L-Y pull out the defunct capacitors. Once that is done, solder in the new capacitors carefully. If are unsure how to do this, try to get a friend who knows how to do this kinda stuff do it for you.
PS. The capacitors are usually 680 - 1000 micro farad and 35V. however, if you dont find 35V, you could use a 50V as well. They will be slightly larger, but you should be able to get them to fit in.
You can buy the capacitors online from HERE or HERE if you wish..They cost $0.068 - $0.85 each depending on the model.
Hope that helps...Should you have any further questions, please feel free to post them here.
P.S. Before you assign a rating, please make sure that the issue is resolved or you are satisfied. If not, please post back as to what you did, and/or any other questions you may have, and I will try to assist you as best I can. Please do not assign an ‘Inappropriate’ or ‘Thanks for trying’ rating if your issue is not resolved after the first response itself, as sometimes a bit of to and fro dialogue may be necessary before we can find a fix or an answer to your query.
If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Posted on Apr 27, 2008
  • Swilin Sampson
    Swilin Sampson May 03, 2008
    Just wanted to inquire if your issue is resolved, or if there is anything
    further I can do to assist you…
    to, or resulted in a fix, please take a moment to close the ticket with a FixYa!
    rating under my solution.
    post them here.
    Cheers!
    IrishDruid
  • Swilin Sampson
    Swilin Sampson May 31, 2008
    P.S. -You can rate this solution with one of
    four votes, if you feel your issue is resolved.
    • "FixYa!"
      - The solution provides great advice on how to solve the problem.
      (Positive Rating)
    • "Helpful"
      - The solution provides useful leads that helps solve the problem.
      (Positive Rating)
    • "Thanks
      for Trying
      " - The solution does not solve the problem but the
      effort is appreciated. (Negative Rating)
    • "Inappropriate"
      - The solution has absolutely nothing to do with the problem.
      (Negative
      Rating)
    If your issue is not still not resolved, do not
    assign a rating just yet. Please post back as to what steps you took, results,
    etc, and I will try to assist you further as best I can.
    IrishDruid
86 Monte SS has me to my breaking point! Over last month have lived in garage upgrading cars motor. About a year ago I swapped an interceptor 350 for the 305 but due to budget kept the Quadrajets etc. and...
At
www.reliable-store.com
get
complete guide on whether to repair or not, service it, and how to repair etc, along with wiring diagrams, electrical diagrams, torque specs, error codes, everything.
Mar 01, 2018 | Chevrolet Monte Carlo Cars & Trucks
How do I set up a ps2 to a insignia 26" flat screen tv?
What's great about it: Simple hookup, sound and picture are very good, wide picture is a must, and yes a good price and better protection What's not so great: None I have just bought this beautiful Insignia TV set earlier this afternoon. My uncle bought it for me, because my old Magnavox 19 inch television set is almost at its DOA. The old TV didn't get the picture immediately once I turned that on--I only waited like over three minutes or more for the picture to come back on. But this Insignia TV is really good. 26 inches, combined with a DVD Player, and it really has some cinematic quality. The hookup was quite simple, but the hardest part of all was to autoscan once I turned it on for the first time. But that was no longer a problem, because my landlord showed me how to autoscan. Just simply press the menu button, and select the autoscan. Once the autoscan is complete, the cable is like back on, and it looks better than my old TV I had for almost 14 years. I went to my local Best Buy in the mall, and one of the clerks recommended it to me. Ironically, my uncle has the same exact one that I have right now. It really fits in my living room on top of the TV Table. It's HD all the way, and I love it. Despite the price, it's an awesome TV and excellent quality to boot and it really delivered. Everything else was all set and it didn't require any unnecessary reinstallations with my VCRs, Playstation 2, cable converter, and of course, my other DVD Player. Great TV, for a not too bad of a price and since it's flatscreen, I would probably have enough room to put my Playstation 2 next to it, and like my new TV my PS2 can probably fit there without much incident. Nothing really bad. It seemed good enough for me and my twin sister, and it seemed good enough for my uncle who bought it for himself before he bought it for me. The price was too much for me--more if you can count an extra $70 for the extended warranty plan. But other than that, it was worth it. It was definitely worth it. SInce it's widescreen, I will want to keep it widescreen all the way--unless I can zoom in for the most important parts, especially if I can do it while playing a tape in my VCR (seperate from the TV). If you want a good quatlity TV with superior cinematic quality, and you can get closer views with everything you ever dreamed of getting for your house or apartment, or wherever else you live, then The Insignia 26 inch HDTV set is for you
Nov 27, 2012 | Televison & Video
22" flatscreen LCD Westinghouse TV.
try use a lowest resollucion 720p and after change to 1080
Sep 20, 2011 | Westinghouse 22" Widescreen LCD Flat Panel...
I have a 42 in Insignia LCD that I have only had
If a problem like this should develop within the retailer's return period, it is recommended that the TV be returned for an exchange.
Jan 19, 2010 | Insignia LCDTV26 26 in. Television
No sound on my 32'' Insignia LCD HDTV
Try to unplug the tv for a few seconds and then plug it back in again.
Jan 28, 2009 | Insignia LCDTV26 26 in. Television
INSIGNIA 32 IN FLATSCREEN MODEL NS 32LCD
check for capacitors on the power supply that are puffed up. Also the mai board can cause this but the power supply is where i would start.
Jan 08, 2009 | Televison & Video
you might try checking the sap (secondary audio programming) option in your tv if it has one make sure it is turned off. if it is off or does not have that option you will most likely have to take it to a repair shop. i would not try to fix it my self as you will do more harm than good.
Dec 09, 2008 | Insignia IS 20" TV040919 TV
SOUND BUT NO PICTURE 46 DAY OLD INSIGNIA.........
If you just bought it, take it back to Best Buy. It has a standard warranty, they should repair it.
Nothing works like they used to nowadays, in my experience Insignia is a good brand. You may have just gotten a bad apple.
Apr 24, 2008 | Insignia IS-LCDTV32 32 in. Television
I have a question? Do you move your Television frequently, OR do you unplug it frequently when it's not in use? I have found that doing either or both of those things can bring on problems, especially audio problems.
I've had the disappearing sound problem twice with my Element FLX-2610. This latest time I was stumped because the full scan didn't resolve the problem. And of course, the sparse manual that comes with the TV contains no troubleshooting advice at all.
But I did find a suggestion on another sveral other sites: Reset the TV. You might have a small reset button (like you would find on a DSL modem) somewhere on your TV but there is a manual way to do it two. Whichever way you do, MAKE SURE to disconnect every single device (yep, it's a pain) and UNPLUG the TV before doing this.
To reset with a reset button, disconnect devices and unplug the TV. Depress the reset button for 5 seconds. Reconnect devices, then plug in the TV.
Manual Procedure:
Disconnect all devices
Unplug the Television
Using the on/off button on the Television (NOT on the remote), depress and hold the button for 5 seconds.
Reconnect the devices, then plug in the TV.
Unless something has shorted out or burned up inside, this resetting, as a last resort, should fix the audio problem. Worked like a charm for me!
Good Luck!
Nena
Jan 19, 2008 | Insignia IS-LCDTV32 32 in. Television
Insignia
On a LCD TV either the lamps might not be coming on or there is a video problem. If unplugging it for 30 seconds then trying again doesn't bring it back then expert help is needed.
Apr 25, 2007 | Insignia IS-LCDTV32 32 in. Television
Insignia IS-LCDTV32 32 in. Television Logo
167 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
