Question about LG 50PC1DRA 50 in. Plasma Television
NO picture --sound ok - LG 50PC1DRA 50 in. Plasma Television
  • LG Master
  • 11,800 Answers
Check the video final circuits, and the high tension powering them. If they are fine then the problem is in the image processor - the entire board will gonna have to be replaced.
Here it is http://cgi.ebay.com/LG-50PC1DRA-Logic-Main-Board-Part-6870QCC013A_W0QQitemZ380244264983QQcmdZViewItem
QQssPageNameZRSS:B:SRCH:US:102
Posted on Jul 29, 2010
  • 2 more comments
  • ssomundjian Jul 29, 2010
    I changed Z-sus board # 6871QZH044C maybe that was wrong but it didn't fix now you think it could be this. http://cgi.ebay.com/LG-50PC1DRA-Logic-Ma...
  • Azrael SRL Jul 29, 2010
    No, as i said the first thing you should check is the video final circuits. If they are functioning then you should check the logic board - if the signal isn't coming out of it then the processor is dead and the board must be replaced.
    Don't replace boards blindly ! Test them !
    How do you check video final curcits?
    You input the standard test signal then you measure the output with a oscilloscope.  If you have neither a simple voltmeter and the tv tuned on an average channel will give you a broad indication if it works or not - the output voltages should be around 200 volts on an average image.
Sound ok but no picture
Check the high voltage on the picture tube it should be around 26 thousand volts. Check the back of the picture tube to see if its lit.
Rich
Feb 04, 2015 | Televison & Video
In Samsung tv complaint<br/>in first time tv working in normal and after sometime picture is blinking and slowly no pictre. that time sound is also ok.<br/>after that am am change the capa
Check its solder terminal at the CRT board [Filament voltage]. It sounds like the filament do not glow after some time due to a loose contact at the CRT base connector sockets. Check it.
If this does not help, check the ABL circuit for any open resistor.
Oct 25, 2014 | Televison & Video
Toshiba 42hl167 no picture sound ok
It sounds that the lamp-On signal doesn't comes from the main board. Check it. For more information go to http://electronicshelponline.blogspot.com/
Dec 03, 2013 | Televison & Video
Akai tv picture no sound
If picture is OK, sound should be there. Check the settings to sound first, ie, 'system' 'mute' etc, by entering the sound menu. If an improper system is selected, the sound will be either absent or distorted. If all the other settings are OK, and still there is no sound, you have to check the audio output section circuit, speakers etc?
Jul 19, 2013 | Televison & Video
No picture sound ok,osd ok.
LG 42pj350r this led tv sound ok but not cume picture
May 25, 2010 | Panasonic VIERA TH-42PX80B 42 in. Plasma...
Philips 32pw9617 crt no picture on analog channels but sound ok
this is your tuner board faulty replace tuner board hope this helps
Mar 26, 2010 | Televison & Video
Picture is ok hissing sound in rf connectoin
Yes, change the tuner and make sure that all ground are well connected.
Jun 16, 2009 | Samsung SlimFit TX-S3082WH 30" TV
NO PICTURE SOUND OK PICTURE COMS SLOWLY AFTER 1 OUR PHILIPS 50PF9966/12"
what do you mean..? be clear, so that many can help you...sir
Apr 27, 2009 | Computers & Internet
SANYO TV MODEL CM20SP8S CHASSIS AC3-A20
try to fine tune your tv using the remote control, or, if you had knowleged in electronics adjust the sound IF transformer using a wood stick or plastic don't use a metal in adjusting the IF
Sep 01, 2008 | Sanyo AVM-3259S TV
TOSHIBA IC DATA DISGRAM NO IS 8873CSCNG6PR6
EHT OK BUT NOT FUCTION NOLIGHT AND NO SOUND NO DISPLY
Jun 18, 2008 | Televison & Video
LG 50PC1DRA 50 in. Plasma Television Logo
56 people viewed this question
