Question about Amana Washing Machines
Amana washer tub rotates counterclockwise during wash cycle.
Bought a used Amana LW4303W washer and found the tub rotates counterclockwise during wash cycle. If the lid is opened during the spin cycle the tub ''coasts'' to a stop. What causes this? Is the brake malfunctioning?
Does the brake need new pads or to be replaced?
Thanks for the help.
    Champion:
  • 274 Answers
The washer has a transmission.why are you openning the top it's a safety.the transmission may need to be replaced,You may be better off getting a new or new used washer,the transmissin is very expensive
Posted on Jul 29, 2010
Amana nav5805aww washing machine won't spin
You will need to replace the thrust bearing kit. Here is the part to order.
It comes with the instructions and is an easy fix.
Oct 30, 2012 | Amana NAV5805A Top Load Washer
How to add fabric softner to the amana washer with locking lid
Check and see if there is a cup in the top of the agitator. Some machines have you put it there, turning back and forth during wash doesn't bother it, but the spin to empty the wash water causes the softener to go out through slots in the top of the cup and be held in the agitator. when it stops the softener drains into the tub, ready for the rinse cycle.
May 30, 2012 | Amana Washing Machines
Amana Washer LW4303W. Tub spins much to freely while the agitator agitates. Could be coincidental but this problem seems like this all started after I replaced the drive belt. Washer cycles like it...
Yes, there is a brake that holds the tub while the machine is agitating. I don't have a manual handy for that model, but you probably have a plastic pulley in the center bottom of the machine. The brake is above that. There is a cam arrangement inside the pulley that will disengage the brake when in spin.
May 10, 2011 | Washing Machines
Noisey spin
The noise is from the transmission and is usually pretty expensive. You really are better off getting a new washing machine.
Feb 24, 2010 | Amana DLW330RA Top Load Washer
My Amana LW4303W washing made a loud bang noise,
Hi.
You have broken the drum bearing, it is the part located at the bottom of the tub, the drum bearing if fixed at the back of the drum.
Here all parts and diagrams for your model.
Regards,
Nov 14, 2009 | Washing Machines
Model alw480daw Amana Washer, belt siezed, idler pulley free spinning, pump still rotates and works, tub spins. White hex drive under tub pulley is partially raised. Prior to problem a howling noise...
you could have a transmission porblem are you might have something in the washer basket cause the noise check basket maker sure there notting like a nail are some thing in hole of the basket an due see any oil leaking out tranmission are call a appliance service
Dec 13, 2017 | Washing Machines
Loud and leaky
Tub bearing replacement on ANY Amana (Maytag) can be difficult. Even for experienced technicians, it can take 1 to 2 hours as long as there are no surprises (corrosion, stubborn bolt etc). Also, all Maytag washers require specialized tools for removing certain components of the machine.
May 28, 2008 | Amana NAV5800A Top Load Washer
Amana Washmachine (not all water removed during spin) ALW780QAW
you may have blockage in the drain pipe several feet from washer. if you can run spin cycle with hose in different location ex. tub,sink or outdoors. if this works run long snake down washer drain pipe to clean gypsum residual.
Jan 28, 2008 | Amana ALW780QA
Washing Machines Logo
151 people viewed this question
Top Amana Washing Machines Experts
Charles T Nevin
Charles T Nevin
Sal De
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
