Question about Audiovox Bosch 718 World Cellular Phone
Dishwasher bosch classixx not cleaning all dishes
Our dishwaher is a bosch clsassixx it is not cleaning all dishes properlly i have cleaned all filters visable is there anything else i can check?
  • Audiovox Master
  • 43,501 Answers
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
nmwr34
Posted on Sep 29, 2010
There is a brown film all over inside of dishwasher. I have to put it on power scrub for my dishes to get clean.
I had a similar problem with my Whirlpool dishwaher, and it turned out that my water softener was not working. Once that was resolved, I found that I have to use a rinsing agent in the dishwaher to completely eliminate spots on the cleaned dishes.
Dec 03, 2010 | Dishwashers
My dishes aren't getting washed properley what should i do
There are many probable causes of failure .
To clean the dishes the water temperature is essential.It the water is not hot then the dishes will not be cleaned properly.So check the water temperature.The water temperature should be minimum of 140 degree Fahrenheit.
Also check the filter in your dishwasher for any debris accumulation.
If you are in an hard water zone , then try reducing the amount of detergent used and then try cleaning the dishes.
Nov 22, 2010 | Bosch 24 in. SGS43C12 Classixx...
Not fully cleaning dishes, the machine appears to be working ok regards heating up etc but when finished the dishes are only partially cleaned
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Sep 28, 2010 | Bosch 24 in. SGS43C12 Classixx...
Kenmore elite dishwaher 1646 not cleaning dishes.
heatman101
jklfryyr
Jul 06, 2010 | Kenmore 24 in. 16462 / 16464 / 16469...
Bosch Classixx Dishwasher -check water light keeps coming on
thanks i empied my dish wisher old water then it word again thanks Neil Spink
Apr 14, 2010 | Bosch 24 in. SGS43C12 Classixx...
Not cleaning dishes
If there is not enough water, the dishes would not get cleaned. This could be caused by a partially closed water shut-off valve (located under the sink), or a faulty dishwasher water valve (located at the bottom of the dishwasher, behind the kick panel, on either side).
Also, There is usually two, sometimes three spray arms in a dishwasher. Make sure there is no debris blocking the holes inside each spray arm.
**Water temperature Note***
To get the best results, the water has to be at 120 degrees Fahrenheit when entering the dishwasher.
Concerning the Film.(Disregard if this is not an issue)
This problem occurs due to excessive calcium build up inside the dishwasher. Try cleaning you dishwasher using a dishwasher cleaner. There are a few out there, Try Dishwasher Magic.
Nov 29, 2009 | Bosch 24 in. SGS43C12 Classixx...
Bosch Slimline Classixx,water cutting on/off during filling on any program, have changed inlet valve already, made no difference
Does it still have enough water to wash? Mine does this too. The float is very sensitive. If it gets the dishes clean don't worry about it.
Jun 30, 2008 | Bosch Dishwashers
Dishes are not coming out fully clean
first if the pump is running and you can hear it washing it should clean now hot water cleans dishes not the washer the hotter the better at least 130-135 degrees modern dish washers use less water than older models so if you don't get the water as hot as you can stand it at the sink before you turn the washer on you can fill it with cold water second its important that you use jet dry and if your dishes aren't dry at the end of the cycle then on most washers you can turn the disp up for more hope that helps let me know
Dec 01, 2007 | Bosch 24 in. SHU53 Built-in Dishwasher
Audiovox Bosch 718 World Cellular Phone Logo
144 people viewed this question
Top Audiovox Cell Phones Experts
Marvin
Marvin
svicari124
svicari124
Level 1 Expert
marty morrison
marty morrison
Are you an Audiovox Cell Phone Expert? Answer questions, earn points and help others
