Question about RELIANCE ELECTRIC WATER HEATER
Reliance water heater wont stay lite.
Reliance water heater will light when I press button, the minute I release the button the fire goes out.
  • 2,005 Answers
Replace your thermocouple
Posted on Jul 29, 2010
Hot water tank wont heat water, how do you relight or resat, its a reliance self cleaning 808
Reliance Water Heater Literature ' Owner's Manuals ...
www.reliancewaterheaters.com/resources/instruction-manuals
Welcome to the Reliance Water Heaters Owner's Manual and Installation ... 9 40 EKRT - 40 Gallon Tall Self-Cleaning Electric Water Heater - 9 Year Warranty . ..... 10 50 DHPST - 50 Gallon Electric Heat Pump Water Heater - 10 Year Warranty .
How to light the pilot on a Reliance 606 water heater ...
? 3:27
https://www.youtube.com/watch?v=VU2PsFVd2ug
Jul 12, 2011 - Uploaded by kilroywashere123
How to light the pilot on a Reliance 606 water heater ... How to fixwater heater, will not stay lit - sealed combustion no hot water - Duration: ...
Reliance Water Heaters - Consumer Affairs
www.consumeraffairs.com > Homeowners > Bath & Plumbing
Rating: 1.6 - ‎84 votes
I purchased a Reliance 606 water heater in 2010. ... That they don't TELL you there's areset button or that I'm having conspiracy thoughts ... After several attempts, I was able to relight it. ... It's heading to the junk pile and I will purchase a new reliable (NotReliance) ... Checked breaker and changed breaker still no hot water!
Dec 28, 2015 | Reliance Water Heaters
Pilot light goes out when i release the button
Question posted under Reliance gas water heater.
Add comment for different brand.
Age of heater is unknown.
Status light indicates one of the Honeywell electronic gas control valve.
Status light not blinking indicates that water heater gas control not receiving electrical power for power vent models.
Or thermocouple is bad on non-power vent models
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
Depending on model, and age, the thermocouple can be tested and replaced. Or entire burner assembly is replaced.
http://waterheatertimer.org/How-to-replace-thermocouple.html
If the gas control valve has gone bad because of power surge or other anomaly, then the power-vent type gas control is removed from tank and replaced, while the non-power-vent model is module and can be snapped off front of unit.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Oct 10, 2012 | Reliance & 30 Gal LP Gas Water Heater
Reset button will not reset, stuck in place
Best solution would be to change out the thermostat it could cause problems if by chance you do get it to reset. Something goes wrong and it want trip the reset it could cause a fire, so the safe thing to do change it out.
Oct 23, 2011 | RELIANCE ELECTRIC WATER HEATER
I light the piuolot button and when i let go of the pilot button the pilot goes out does not light burner wont stay lit
When you light the pilot lite you have to hold the button down until it gets the element hot enough to stay lit. If you hold down the button and lite the pilot and let it go right away it will go out. What to do is hold down the button and lite the pilot and continue to hold the buttn down for about 45 seconds to a minute then let it up very slowly and you will see if it is going to go out by the flame getting smaller as you let up on the button. If it does start to get smaller conitnue to hold it again for a few seconds and repeat the process of letting it up slowly. when the control element gets to the right temperature it will stay lit then turn your valve to "ON" and the fire will start up and continue to heat the water.
Mar 15, 2011 | RELIANCE ELECTRIC WATER HEATER
if the unit goes thru the cycle of heating the water and when temp is met pilot goes out you need to replace the entire temp control if pilot goes out as soon as you release the pilot button you need to replace the thermo couple little copper wire the goes from regulator to inside burner...check for 800 number on front of w/h for warranty info..as regulator can be expensive
Dec 09, 2010 | Reliance Natural Gas Water Heater Control
Reliance gas water heater 640ycrs pilot light will not stay after 1 heat period replaced thermal couple has gas thermal switch
if water heater will heat a tank of water before the pilot light goes out you need to replce the gas thermostat
Mar 04, 2010 | Reliance & 30 Gal LP Gas Water Heater
I have a reliance 501 electric hot water heater and i cant find the reset button. Where is it located?
it is located on the thermostat. Take the cover off the side and you will see a little red button in the side of the themostat.
Jan 10, 2010 | RELIANCE ELECTRIC WATER HEATER
We dont think our cylinder is on we have just moved in and have no hot water
The question is? I'll assume you cylinder is the water heater, right?
On the heater (water) you will find or see the red controls and a sheet metal cover over a hole. Remove the cover and this is where you light the pilot light. Press down on the red dial and turn it to pilot. In that position you will be able to press the red button . Geyt a long match or bbq lighter, then, holding down the red button dow for a minute or so and place a match or lighter into yhe area where the lines go The flame will catch the gas and lite the pilot if yo simply move your glame around. When the flame catch on the pilot, continue holding the button down for sveral minutes until the buld the flame isheating gets hot. Then release the buton and turn the main dial to on. The main burner should fire up. If not, and the pilot goes out, repeat the process. The bulb in the pilot flame is a thermocoupler that shuts all gas off if it doesn't detect a pilot flame, so hold the button down longer. If the pilot goes out when you release the button, The thermocoupler is no good and needs replacing. Good Luck_Ned_
Oct 31, 2009 | Rheem 80 GAL ELEC TALL Water Heater 6YR SC...
RELIANCE ELECTRIC WATER HEATER Logo
162 people viewed this question
Top Reliance Water Heaters Experts
Mack Baxter
Gil Shultz
Paul Nielson
Paul Nielson
Are you a Reliance Water Heater Expert? Answer questions, earn points and help others
