Question about Hardware & Accessories
Programming Utilitech Item # 0192773
Instructions are at best, vague. Can't set automatic sunrise/sunset function
  • 3 Answers
Go through the normal setup. Year, month, day, time, DST and the location (north, center, south).
Hit program and make sure all events are clear. Program the first (ON) event, press the TIME button and press /- (with the hour segment blinking) until you see the Sun/Moon symbol indicating the sunset time. Press PROG and program the (OFF) event. Press the /- buttons until you see the Sun/Moon symbol indicating the sunrise time.
Hitting resume clears events if you accidentally entered them.
Make sure you display shows AUTO and you're good to go.
Posted on Sep 19, 2010
  • 1 more comment
  • Phil Godfrey Sep 24, 2010
    I should also add that you will have to set the days of the week that you want when programming the timer. It's difficult to see them as they are small and at the top of the LCD. If you do not set them it won't work.
  • Larry A. Woodard Aug 23, 2012
    Phil, I am going to give this a shot, as soon as I have had enough coffee and my eyes are wide open. Yes, all is in very small letters and hard to see. If I had known it was going to be this much trouble, I would have left well enough alone with the manuel switch.
  • The Rev
    The Rev Aug 10, 2014
    nearly 4 years later, I want to thank Phil Godfrey for giving me the clue to getting mine (0141224) working correctly. I didn't realize the days needed to be set too - was going nuts trying to figure out why mine wasn't working.
DO YOU HAVE a manual for a woods e227659 TM-068-2 timer?
Woods TM-068-2
Indoor 7-Day Astronomic Timer
125V ac / 60Hz 15A / 1875W general purpose
8A / 1000W tungsten 500VA electronic ballast
15A / 1875W resistive 120V ac / 60Hz / 8,3A ballast
FEATURES:
• Up to 7 different programmable ON/OFF cycles, cycles repeat weekly.
• Programming fl8xibilify: u8hts fun on/off automatically at sunset/sunrise,
or at any programmed times you choose.
• ln Sunrise/Sunset programming mode, timer will automatically adjust the
programmed ON/OFF cycles to match current sunrise/sunset times.
• Timer automatically adjusts to daylight savings time
WARNING: TIMER IS INTENDED FOR INDOOR USE ONLY!
BEFORE YOU BEGIN PROGRAMMING THE TIMER:
This timer has in internal battery backup to save all programming.
  1. Plug the timer into wall outlet for 30 minutes to charge internal battery.
  2. After 30 minutes, unplug timer and press the RESET button with the tip of a toothpick or similar object to clear the memory.
TO SET THE CLOCK:
  1. Press SET. PRESS +/AUTO or -/RDM to set the current year.
  2. Press SET. PRESS +/AUTO or -/RDM to set the current month from 01 to 12.
  3. Press SET. PRESS +/AUTO or -/RDM to set the current date.
  4. Press SET. Daylight savings mode (DST) will appear on the bottom of the display. PRESS +/AUTO or -/RDM to set mode to either DST AUTO or DST OFF.
  5. Press SET. PRESS +/AUTO or -/RDM to set the current hour. To change between AM and PM, press +/AUTO or -/RDM 12 timers.
  6. Press SET. PRESS +/AUTO or -/RDM to set the current minute from 00 to 59.
  7. Press SET. PRESS +/AUTO or -/RDM to set the Astronomic function to your zone - North (nor), Central (cen), or South (sou).
  8. Press SET to view the sunrise time. To adjust sunrise time press +/AUTO or -/RDM. To go back to the default sunrise timer press ON/OFF.
  9. Press SET to view the sunset time. To adjust the sunset time press +/AUTO or -/RDM. To go back to the default sunrise timer press ON/OFF.
  10. Press and hold SET for 5 seconds to exit clock setting mode.
Note: The timer allows a maximum of 7 programmable ON/OFF cycles.
To program the first ON/OFF cycle: Press SET repeatedly to scroll through setting the clock mode.
  1. Press SET to display ON 1 setting.
  2. Press +/AUTO or -/RDM to select day or group of days you want for cycle 1. Scroll to select either every day, any individual day, weekdays only, or weekends only.
  3. Press SET. Set ON hour by pressing +/AUTO or -/RDM to scroll through and choose hour AM or PM, or Sunrise/Sunset icon for first ON setting. Note: To select Sunset or Sunrise for the ON time, you must scroll through all the AM and PM hours first. If you select Sunrise/Sunset as the programmed ON time, press SET to continue programming OFF setting.
  4. Press SET. Press +/AUTO or -/RDM to set ON minute from 00 to 59.
  5. Press SET to display OFF 1 setting.
Repeat steps 2-4 to program desired OFF time.
To program additional ON/OFF cycles: Repeat steps to create additional ON/OFF cycles (ON 2-OFF 2, ON 3-OFF 3, etc.) up to a maximum of 7 different ON/OFF cycles.
Press and hold SET for 5 seconds to exit programming mode. Note: During programming, if no button is pushed for 30 seconds, the timer will automatically return to standby mode. Press ON/OFF to cancel any setting.
Sun tracking technology: Timer adjusts automatically to changing sunrise and sunset times in sunrise/sunset mode is chosen for any programmed ON or OFF time. For example, if you program a cycle to turn ON at sunset and OFF at 10:00 pm, the timer will automatically adjust ON (sunset) time as sunset time changes throughout the year (and will always turn off at 10:00 pm as programmed).
IMPORTANT! REVIEW PROGRAMMED ON/OFF CYCLES: Press SET to advance through all programmed ON and OFF settings. Make sure there are no overlapping ON or OFF times. Stop at any programmed setting you want to change.
To operate timer: Press +/AUTO until AUTO appears in display. Timer must be in AUTO mode for programmed settings to operate. Plug appliance (such as lamp) into timer and plug timer into wall receptacle.
IMPORTANT: Appliance must be turned ON or be in the ON position before plugging it into timer.
SECURITY (RANDOM) MODE: To operate a plugged-in appliance (such as a lamp) in a random pattern while you are away, to simulate actual use: press -/RDM until RDM appears in display. In Random mode, plugged-in appliance will turn on and off at random, approx. +/- 30 minutes from the programmed settings.
To cancel Random mode, press ON/OFF until RND disappears from display. Timer will now function using your previously programmed settings.
DAYLIGHT SAVINGS (DST) MODE: If timer is in DST AUTO mode, clock time (and sunrise and sunset time) will automatically increase 1 hour on the second Sunday in March at 02:00 am and decrease 1 hour on the first Sunday in November at 02:00 am.
TO OVERRIDE THE TIMER: Press ON/OFF until desired mode is displayed:
ON: Programmed settings will be overridden; the plugged-in appliance will remain on
OFF: Programmed settings will be overridden; the plugged-in appliance will remain off
AUTO ON: Turns plugged-in appliance on immediately until the next programmed OFF time. Press ON/OFF until ON displays on the screen, then press +/AUTO and AUTO will display on the screen.
AUTO OFF: Turns plugged-in appliance off immediately until the next programmed ON time. Press ON/OFF until OFF displays on the screen, then press +/AUTO and AUTO will display on the screen.
RDM ON (Random ON): Turns plugged-in appliance on immediately until the next random off. Press ON/OFF until ON displays on the screen, then press -/RDM and RDM will display on the screen.
RDM OFF (Random OFF): Turns plugged-in appliance off immediately until the next random on time. On/Off times will vary +/- 30 minutes from the programmed settings. Press ON/OFF until OFF displays on the screen, then press -/RDM and RDM will display on the screen.
Consumer Support (800) 561-4321
www.colemancable.com
Dec 12, 2017 | Woods Hardware & Accessories
Operating Utilitech #tm-029mitem #0192773 what is the button on right (next to on/off button)
The first press of the button to the right of the On/Off button on the Utilitech TM-029 will display the current Sunrise time. You can then adjust this time with the +/- buttons. A second press will display the Sunset time and allow you to adjust that.
This is useful if you want a light to come on at sunset (or a time near sunset) and go off at sunrise every day.
I found the manual for the TM-029 here: http://waterheatertimer.org/Program-wire-Utilitec-LW60419.html . Look in the right hand column under Resource. The direct link to the manual is http://waterheatertimer.org/pdf/Utilitec-TM-029-timer.pdf .
I hope this helps.
Nov 03, 2017 | Hardware & Accessories
How do I set the time?
S E T U P
SET UP is performed once during
installation to set the internal CLOCK, ASTRO (sunrise/sunset)
times and HOLIDAY references. After entering and okaying the
ASTRO Zone, the timer will display calculated "center of time
zone" times when prompting for sunrise and sunset entries. You
may OK these, enter actual sunrise/sunset times or enter offset
times for early or late ASTRO operation. Sunrise time must be
before noon; sunset time must be after noon. Sunset must not be
within 5 hours of sunrise. Both sunrise and sunset must be
entered, even if only one is used for switching. If neither is
required, you may skip ahead by pressing HLDY or PROG keys.
(See map pp. 24-25 for details.) Holidays are entered with 2-digit
reference numbers; a chart for recording the date(s) is located on
page 22. Leap years are preset through the year 2094
PROGRAM is used for entering or
changing the switching schedule for loads wired into the time
switch. You can program circuits separately or concurrently. Each
entry affects loads whose Enable switches are in the enable
position at the time of data entry (2 circuit models only). The
time switch is shipped in a 12-hr. AM/PM mode; you can change
to 24-hr. by removing a jumper on the circuit board (see Special
Instructions). It can store a minimum of 400 events, depending
on the data type entered.
The time switch prompts you through SET UP and PROGRAM
with LEDs that advance after each entry. There are five important
points to remember:
1) The RUN/SET switch must be in the SET position to enter,
review or change data.
2) You must press "OK" after each entry, before starting the next.
3) You must press AM or PM after entering time (unless
programming Sunrise and Sunset or in 24-hour mode).
4) When in PROGRAM you must select the loads you want to
control with the Enable switches (2 circuit models only).
5) RUN/SET switch must be returned to RUN position to enable
automatic control and to save changes to data.
KEYPAD
SUN
MON
TUE
WED
FRI
SAT
DY
ND
WK
WK
6
7
8
9
These keys are used for most data entry. Note dual functions,
numeric or day specific. Using the day group keys WKDY,
WKND and ALL (for all 7 days) greatly speeds the process.
The keypad keys are only functional when the RUN/SET switch is
in the SET position. Pressing keys when in the RUN position will
cause a message to scroll, explaining the function of that key. Press
any key once to stop any of the scrolling error or help messages
You must press AM or PM after entering time data (except Sunrise
or Sunset) unless in 24-hr. mode. Programming fixed times for
ON and OFF events does not require PULSE, INTVL or ASTRO
keys. Multiple ONs or OFFs can be entered by pressing OK
without programming the alternate OFF or ON. Multiple OFF
times are frequently used to "sweep" off loads which have been
manually switched on after normal occupancy hours.
PULSE and INTVL (Interval) are length-of-time based options.
Maximum Pulse is 127 sec.; minimum is 1 sec. Maximum Interval
is 6 days, 23 hrs., 59 min.; minimum is 1 min. To program Pulses
or Intervals, press the PULSE or INTVL key after entering a Switch
On or Switch Off time; then enter the required duration and press
OK. Note after ON Pulses or Intervals have timed out the load
will be OFF, and after OFF Pulses or Intervals have timed out the
load will be ON, regardless of the load state prior to the start of
the Pulse or Interval. The INTVL and PULSE keys include a
temporary override function with a maximum length of 6 days, 23
hrs. and 59 min. for the interval or 127 seconds for the pulse. To
program an interval or pulse for override, select SET, enable the
circuit, press PROG, press INTVL
or PULSE (without selecting a
day), key in the interval or pulse
Intermatic ET70115C User Manual Page 4
Mar 11, 2015 | Intermatic ET70115C Electronic Energy...
Utilitech #0192773 setting the timer for not working
I do not have repair for defective timer.
Open following link for clear large-print instructions.
http://waterheatertimer.org/Program-wire-Utilitec-0192773.html
Add a comment about part of manual that does not work, for possible additional help.
1) Timer replaces single-pole light switch only.
2) Timer does not have a battery and must be wired correctly before programming can take place.
3) Choose either dawn-dusk or programmable on-off:
Timer can be set for dawn-dusk operation
-OR-
Timer can be set with 7-day on-off functions of your choice
Aug 18, 2011 | Intermatic Inc. ST01C Digital In-Wall...
Utilitech self-adjusting wall timer 0192773. I hooked up the timer (4 wires). The automatic modes does not work and will not turn on and off the lights on set times. All it will do is turn lights on and...
I have been testing the 0192773, and other timers, for wire and program difficulties.
Good news: your timer is wired correctly. This timer will not operated lights with incorrect wiring.
programming steps are long, but same as other programmable timers.
The 0192773 is a 7-day or sunrise/sunset timer
1) Most programmable timers will not 'work as expected' if there is a conflict in programming.
They suggest you make a schedule of times before programming
2) One of the things this timer offers are individual days -or- groups of days > for example weekend only -or- weekdays only -or- all days of week -plus- individual days. For me, it was a bit confusing keeping that straight while programming
3) Each Program has ON time and OFF time
So Program1 ON has to be set same days as Program1 OFF
4) The other difficulty was how fast the display shifted back to current time when I was programming. If I looked at the instructions for a moment, my display would change before I could catch up. So it's possible that an ON or OFF time could be missed easily.
5) Finally, if you are using the timer as a sunrise/sunset, you need to enter Sunrise or Sunset with program1 ON and program1 OFF
I think the problem is in your programs:
You can use paperclip and hold in reset button for a few seconds and start over
Or
You can press PROG button and and re-check and re-set each program.
By the way, when setting current time, I noticed the timer let you chose a year up to the year 2099. I thought that was an optimistic outlook for both operator and timer.
Oct 22, 2010 | Intermatic Inc. ST01C Digital In-Wall...
I have been trying to program my utilitech timer that controlls my front door lights. I have been able to program monday only. I did the same program for the other days but at dust the light will not come...
1) I am going to guess you have the Utilitec 0192773 in-wall timer that replaces a switch
I say this because you are controlling outdoor lights -and- because you have the dusk-to-dawn feature.
2) Short answer: I think you have selected your days incorrectly when programming timer
To review your programs:
Press PROG button once and program1 ON displays
Press PROG again and program1 OFF displays
Press PROG third time, program2 ON displays >> a fourth time progrom2 OFF displays
And so on..
3) I suggest you write out a schedule of your times
Press PROG button and then press TIME button to see your programming: Review the days carefully, review if you have sunrise-sunset selected for each program. You can change the setting while going by using the +- button.
4) As a general rule, programmable timers do not 'operate as expected' if there is a conflicting program. For example program1 says on at 7 and off at 8, and program2 says the opposite.
Suggested solution is make a chart of your settings before programming.
5) Long answer: write out the manual instructions that seem unclear to you
6) To reset everything and start over, push & hold reset button with a paperclip.
Here I am testing the Utilitec timers for wiring and programming difficulties
Oct 21, 2010 | Intermatic & Self-Adjusting Wall Switch...
Can i have programming instructions?
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
http://waterheatertimer.org/Aube-timers.html
http://www.aubetech.com/products/list.php?noLangue=2&noFamille=5&app=13
Links above shows 10 different Aube models
Select your model, click link next to your model, next page has instruction manuals at bottom of page
Each model has different instructions
4 models are 7-day timers
4 models are sunrise-sunset timers
2 models are combo sunrise-sunset
There are 2 exterior box-type timers with choice of sunrise-sunset or 7 day, depending on model
The instructions vary by model
Let us know if you have problems with specific instructions
Oct 19, 2010 | Aube Technologies Aube 7-Day Programmable...
I have a utilitech 0192773 self adjusting timer that will not program. Only works with manual on / off switch. How do you adjust to dusk to dawn
Do not go to Utilitech.com; it's a different company. It's actually at place called TheNCC and is in tiny, tiny print at the bottom of the instructions.
Instead, go to:
http://thencc.com/ncc/support_results.asp?criteria=192773&Submit=Go&SearchRun=RunGo
You should find a PDF for the product and then zoom in to be able to read the instructions. I was not able to read instructions that came in packaging.
Jan 27, 2010 | Intermatic Inc. ST01C Digital In-Wall...
Hardware & Accessories Logo
531 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
