Question about Samsung SyncMaster 150MP Monitor
Internal Speakers I have a Samsung SyncMaster 150MP and the speakers aren't working and I cant figure out how to get then to work now.
    Problem Solver:
  • 18 Answers
The speakers are fairly small and might be easy to replace if you surf the surplus sites.
If you are not comfortable disassembling the unit, I would call the manufacturer.
Otherwise, you can check the TDA7268 IC (amplifier for speakers) on the circuit board the speakers
plug into with a scope.
I recently fixed my monitor and noted how hot that chip gets (and it supposed to) with the possibly incorrect or inadequate heat sinking Samsung designed into the circuit board that cause my monitor to fail. (although differently)
You can email me too if you're still having problems with this. The design is pretty straightforward and could be tested to some degree with a multimeter.
Regards,
--Ben
Posted on Oct 17, 2008
  • 36 Answers
Your speakers might just have flat out died. You might want to send it back to the manufacturer for repairs. If you can't, just buy some speakers instead.
Posted on Apr 24, 2008
  • 117 Answers
Hai
make a call to the manufacturer and ask them to replace if it is in warrenty
Rear speakers aren;t working on my 2002 honda goldwing 1800
Sounds like the mute is stuck on. You need to figure out how to un-mute it.
Apr 18, 2014 | 2002 Honda GL 1800 Gold Wing
I have my syncmaster 2220wm hooked up to my laptop. How can I get the monitor sound? It is only using the speakers on my laptop...??
Hello a 2250wm is actually a Viewsonic monitor not a Samsung monitor. To get the built in speakers to work you will need to connect the audio cable from your laptop to the monitor audio jack. This cable should have come with your monitor, it will have a headphone 3.5mm plug on both ends of the cable. If you do not have this cable yo will need to get one before you can make the speakers work right. Here is a link so you can get the cable if you need one.
http://www.ccl-la.com/catalog/product_info.php?cPath=83_86&products_id=176
Dec 05, 2012 | Samsung SyncMaster 2220WM 22" LCD Monitor
I have a doubt ...which file format support in this tv becaus.. i want to see some videos .. which.. i downloaded in youtube...
Samsung SyncMaster 150MP Monitor does not have any usb connection or built in personal video player it is only tv and pc monitor. I recomend you watch your files over a pc connected to this device. you need a device that has DIVx capability to watch video files such as .avi.
I hope this was useful..
Sep 09, 2012 | Samsung SyncMaster 150MP Monitor
The volume has went off on my tv. its a samsung le26b450c4w
First verify that the mute is disengaged (toggle the mute button). Second, check the sound configuration to make sure the internal speakers are on, or check the sound output to make sure it is going to the inputs of an external audio amplifier (stereo receiver) and that the external amplifier is working. Try a different input source - perhaps the problem is your cable feed or DVD player.
If the internal speakers are on, the volume is up, and you still don't get any sound from a known-good source (TV channel, DVD player, etc.), then try running the sound to a stereo system as described above.
If that works, you may have a shorted speaker amplifier (depending on the set's design, this may blow a fuse supplying power to both left and right amplifiers or a speaker protection circuit will keep the speakers disconnected). These aren't usually hard to repair, but if you find a blown fuse, fix the amplifier before replacing the fuse or you'll just waste another fuse.
Jan 09, 2012 | Samsung Televison & Video
I dont have a clue where to turn up the volumen
I don't think your LCD has internal speakers. Does it have a small 3.5mm jack with a speaker symbol (like a headphone jack)? I was looking at a review of your model and there was no speakers listed on the specs.
Sep 19, 2011 | Samsung Syncmaster 730B 17" Flat Panel LCD...
Just hooked up computer and monitor and cant get any sound to play through moniter. do we need external speakers?
The Samsung SyncMaster 2233BW does not have built-in speakers, so yes, you need external speakers separately for sound.
Feb 06, 2010 | Samsung SyncMaster 2233BW 22" LCD Monitor
Popping static noise SyncMaster 150mp
Are you still having problems with this monitor?
I posted about a "clicking" sound that has to do with failed capacitors near the speakers' amplifier IC.
If this is your problem, let me know - it can be fixed.
Check this article: http://www.benjammin.net/www/pages/techtips/Samsung-150mp.html
-Ben
Mar 16, 2009 | Samsung SyncMaster 150MP Monitor
Rhythmic clicking sound when the monitor is on
I just recently posted about this and you might have the same issue with the TDA7268 Audio Amp chip used in the 150MP that I am and currently trying to resolve.
-Ben
Mar 25, 2008 | Samsung SyncMaster 150MP Monitor
Clicking sound
I found the problem.
I've written up a small article on my website detailing the fix but in summary here:
Electrolytic Capacitors C826 and C835 go bad because of the heat stress applied by the audio amplifier right below them. Replacing those capacitors fixed my 150MP.
For more information see:
Jul 06, 2007 | Samsung SyncMaster 150MP Monitor
Samsung SyncMaster 150MP Monitor Logo
190 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
