Question about Janome Memorycraft 9700 Computerized Sewing Machine
My Janome mc9700 is giving me trouble. I think it may be a tension problem, but I'm not sure: trying to get some advice before taking it to the dealer. I am in the middle of an embroidery project, and my upper thread keeps getting cut somewhere inside the bobbin casing - which makes the machine stop and give me the 're-thread and re-start' msg. I have rethreaded the machine and retried about a dozen times and it is continuously breaking my upper thread down below. I am slowly changing tension settings and retrying but with no luck. HELP?!
  • Tammt Oct 28, 2012
    I have exactly the same problem with my machine. Did you find out how to fix it? If so, please post.
  • Janome Master
  • 7,365 Answers
1.check to see if needle is in backwards
2.the upper tension maybe to tight----check owner's manual for right tension
3.the needle may be bent--roll on flat surface to check
4.the thread maybe hanging up on the bobbin case
5.check this area for lint or fragments of old thread
6.check thread for knots, if notty replace
Posted on Jul 29, 2010
Can a Janome 300e take memory cards from 8000 model? Thank you.
No, the designs on a memory card for the Memory Craft 300e do not work in the MC8000, or vice versa. The designs on memory cards for the MC9500 will work in the MC300e. See http://janome.com/en/learn/software-lessons/transferring-designs/compact-flash-card-mc9700-mc9500-and-mc300e/ for some information. The physical cards appear to be the same. If you have extra space on an existing card, you could put another file onto the card with the appropriate format for the other machine.
The MC300e reads a .JEF file; the older MC8000 reads the .SEW file.
I hope this helps.
Nov 20, 2017 | Janome Sewing Machines
Thread keeps breaking
Here is the Manual see page 41 for trouble shooting
Pages 9 to 14 to ensure correct thread procedure
and check pages 17, 18 re correct thread tension
and make sure you have folled maintence guidlines on page 40
S.
Dec 30, 2007 | Janome Memory Craft 3000
MY MC 9000 is giving me a headacke . It is letting the top thread move to much and then it piles up under the cloth. I'v tryed ever thing . Help
Are you sure that the thread is into the take up lever fully and in the tension device correctly? Recheck your threading path carefully through both of these and make sure the top tension is set on the normal setting, probably 4 or 5. If you can access it, clean the tension discs out. Turn tension to zero and "Floss" between the discs with the selvage edge of a clean piece of cotton fabric and see if any gunk comes out. Often you'll get a build up of thread fibres and dye particles in the tension discs, especially if you are using cheaper dark coloured threads.
Lower the pressure foot and pull on the top thread from just above the needle thread loop: is if firm to pull on? If it isn't, your top tension is faulty and you'll need to take it to a Janome service centre.
Oct 09, 2011 | Janome Memory Craft 9000 Computerized...
My janome mc9700 mother board died. Where can I get a replacement?
Only from a Janome dealer or direct from the factory in your ountry
Aug 27, 2011 | Janome Memory Craft 9500 Computerized...
I need to check the tension on my Janome 534D, I think the upper and lower looper tensions are not right
Here's a couple of solutions to try.
* Re-thread your machine
It may be threaded incorrectly. And when you re-thread it, make sure your thread goes in between your tension disks. (If you don’t know where your tension disks are, consult your machine’s manual.)
* Check your tension disks for dirt or lint
Lint or dirt between your tension disks may be keeping your tension from working properly. Clean out any you find.
I hope this helps.
Sep 23, 2009 | Janome MyLock 644D
Sewing/embroidery machine janome mc9700 making ''noise'', sounds almost like ''metal-to-metal''. it is embroidering & sewing well, but does not sound too good...any suggestions? thank you
Please be more specific with the clicking noise that you are hearing- when does it make that noise, is the bobbin case in or out, where is it coming from,
Aug 26, 2009 | Janome Sewing Machines
Top seam normal but bottom one appears just straight and loose.
If the top thread looks normal and the bottom thread "loops", it means that the top thread does not have tension. Take out all the thread and re-thread the path, giving special attention to the path of the thread through the tension disks.
Thread the machine with the sewing foot up, it opens up the tension disks, and make sure you lower the foot before sewing.
This will close the tension disks.
Jun 22, 2009 | Janome L-344 Mechanical Sewing Machine
Janome Memorycraft 9700 Computerized Sewing Machine Logo
289 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
