Question about Frigidaire FAC107P1A Wall/Window Air Conditioner
Frigidaire AC 10,000 btu-not cooling very well
Purchased in 2006 - running fine until this year - not cooling properly have set to 60 degrees - went thru all the troubleshooting and everything is ok. Just not cooling like it should. Any other things we can look at?
  • 674 Answers
Make sure the filter is clean. Take the unit outside and get some coil cleaner and cleant the coils. You'll have to remove the casing. Also,rinse it from the inside outwards.
Posted on Jul 30, 2010
Frigidaire model FFRE1033SI window airconditioner tilt problem.
Water going outside is the important part. The hole is not necessarily the drain, the angle at most is an eyesore!
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Aug 19, 2017 | Frigidaire Heating & Cooling
I purchased two Artic King 10,000 BTU Air Conditioners. The base of the units on the exterior of the building build up with water up to about 1 deep when it rains or running. Why is there no drain?
If you look inside the exterior part you should see a copper tube(part of the refrigeration tubing) that rests horizontally under this water. The water cools the freon inside that copper tube. That's why some models don't have a drain there.
Jul 30, 2015 | Heating & Cooling
Ac is not blowing as hard and it was but is still cold?
Have you checked the current supply going to the A/C? A simple voltmeter will work or you can try a KILL-A-WATT available online or from many local retailers. You should be looking for approximately 120VAC @60 Hz. 5 years does not seem very long but given the way manufacturer's are making A/Cs these days I suppose the fan motor or motor bearings could be going bad. I don't know the cost of your model but if it is not over 10,000 btu's or so just let it run until it dies and replace it. At some point the motor will most likely overheat and blow a fuse or trip your circuit breaker. I own 2 Frigidaire window units myself.
Aug 14, 2012 | Heating & Cooling
My frigidaire a/c is set 73fhrenheit after running for a time the temp. on the unite drops to 60 degrees by it self what is the problem ?
AC units, no matter if they are big/small, window or big central units. They will only cool the air in the room, or home, to about 15 degrees cooler than the outside air temperature. If you live in Georgia and it is 100?F+ outside, you will be lucky if the unit will reach 80?F even running all day.
Jul 22, 2012 | Frigidaire FRA186MT2 Window Air...
After my air conditioner is on for awhile it will automatically shut off completely then after a few minutes it comes back on. It is not set on the energy saver setting. Also it is and continues to do...
Debi, it;s not unusual for an AC unit to turn ON & OFF. Once it reaches the temperature that you have it set ON and holds the temperature for 4 or 5 minutes, it will shut OFF until the room temperature rises above it. Be sure all the doors and windows are closed and no hot air is infiltrating the area.
Also, a 10,000 BTU air conditioner is not designed to handle a large area. Generally, 10,000 BTU's will handle about 3200 Cubic Feet (20' x 20' x 8' = 3200 sq ft) or simply put, 400 square feet. Your A/C unit may be undersized for the area you're trying to cool.
Hope this helped you. Please let me know. Thanks.
Jun 07, 2011 | LG Electronic Window Air Conditioner
AC was cooling fine. Now, won't cool room even though cool air comes out. Exhaust hose is extremely hot.
Check filter, if you have a 5000BTU unit (small) and it is extremely hot, then it wont work great for a big room. BTU is the rate of what the AC will put out. 5000 BTU is good for a small single room. 10,000 will cool a bigger room and 18,000 btu is meant to cool a home.
Jul 07, 2010 | Whirlpool ACP102PS Portable Air...
My frigidaire side by side isn't cooling properly,
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Feb 21, 2010 | Frigidaire Freezer Refrigeration White...
579 series, 13.5K BTU Rooftop trips AC circuit breaker in hot weather...
Is your condensing unit located in a well ventilated area and have an ample space, atleast a foot, from the rooftop flooring? Just make a check that free flowing outside air properly ventilates the condensing unit specially on high ambient temperatures. Hope this would solve your problem
Sep 16, 2008 | Dometic Rooftop RV Air Conditioner
Heating & Cooling Logo
178 people viewed this question
Top Frigidaire Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
