Question about Itech Clip IIe Wireless Headset
Clip II mini not turning on
Hi. I have the i tech clip II mini bt but i cannot get it turned on! Althougt it seems to be charging when i press the multifuction button it gives no response..please help me!
2 Suggested Answers
ejkudelka
  • 1188 Answers
SOURCE: I have been trying to connect my I tech clip R35 but the bluetooth no is not 0000
The password to access it is "8888"
This device is Bluetooth certified so it uses all the conventional ways of setting it up as any other device of its kind. Simply press the function button until it lights up red and blue intermittently. That will put the R35 on "Find Me" mode. After that just use your cell phone or Bluetooth dongle to find any devices and you will see it available.
Posted on Mar 21, 2012
My Toyota Sienna shows VSC light on the broad. What Should I do?
If you've had your vehicle computer codes read and determined no issue with the VSC circuit, then you just need to cancel the warning light.
I've made up the following instructions, on how to clear VSC & TRAC Warning lights:
Zero Point Calibration of Yaw Rate and Deceleration Sensors Using Paper Clips (or jumper wires).
First, locate the 16-pin ODB II connector under the steering wheel (beneath the dash). The pins are numbered sequentially backwards from right to left (from the wide side of the connector looking at it from underneath).
Take two normal-sized paper clips (or suitable jumper wires). If using paper clips, straighten one edge of one of the paper clips. For the other, bend it open to a 90-degree angle (like an elbow).
Insert one paper clip/wire into pin # 14 (Ts), and the other paper clip/wire into pin # 4 (CG) of the OBD II connector - DO NOT allow the paper clips/wires to make contact at this point.
Refer to diagram below:
1. Ensure the shift lever is in "P" range.
2. Turn the ignition switch to "ON" (not start).
3. Momentarily touch the two paper clips/wires together (short) and separate again (open) - Repeat this process 5 times (within 8 seconds of turning ignition on).
Verify that the VSC indicator light is illuminated, indicating the Recorded Zero point is erased.
4. Turn the ignition switch "OFF".
5. Remove both paper clips/jumper wires from the OBD II connector.
6. Turn the ignition switch "ON" (not start) - wait until VSC warning light turns off (approx. 20 seconds), then wait 2 seconds.
7. Turn the ignition switch "OFF".
9. Re-insert paper clips/jumper wires to terminals #4 & #14 of the OBD II connector (as per above diagram).
10. Turn the ignition switch "ON" (not start) - VSC warning light should remain illuminated for 4 seconds, then start flashing at 0.13 second intervals.
12. After VSC warning light flashes for 2 seconds, turn the ignition switch "OFF".
13. Remove paper clips/jumper wires from the OBD II connector.
Drive your vehicle to confirm VSC & TRAC warning lights have been reset and no longer illuminate.
"If this has helped you resolve your issue, please be kind enough to leave a testimonial"
Jun 10, 2011 | 2001 Toyota Sienna
How can i watch video from Samsung s1050 in my computer?
Hi, Here is the procedure on how to play the video clip on your camera. Play mode If you have turned on the camera by pressing the POWER button, you can press the PLAY MODE button once to switch to Play mode and press it again to switch to Recording mode. You can turn the power on with the play mode button. The camera is turned on in play mode. Press the play mode button again and the camera will be turned off. You can set up the PLAY mode function by using the camera buttons and LCD
monitor. Playing back a still image
1. Select the PLAY mode by pressing the play mode button.
2. The last image stored on the memory is displayed on the LCD monitor.
3. Select the recorded movie clip and press the Play & Pause button to play back.
- To pause a movie clip file while playing it back, press the play & pause button again. ac0dd93.png
- Pressing the play & pause button again will cause the movie clip file restart.
- To rewind the movie clip while it is playing, press the LEFT button. To fast forward the movie clip, press the RIGHT button.
- To stop playback of the movie clip, press the play & pause button, and then press the LEFT or RIGHT button. 0e83d9c.png
Apr 13, 2010 | Samsung S1050 Digital Camera
My Sansa Clip won't turn on even thought the battery is full.
Unfortunately there was a manufacturing flaw with many Sansa Clips which caused one of the battery leads to detach from the battery. A symptom of this is that the Clip will turn on and charge when connected to an external power source, such as USB or an AC adapter, but will not actually turn on using the internal power source (eg, the battery).
If your Clip is still under warranty, you should return it for a refund or an exchange.
Feb 17, 2010 | SanDisk Sansa Clip MP3 Player
My sandisk sansa clip 1gb wont turn on
Make sure the player is fully charged. 1. Connect the player to the PC. 2. Make sure the computer detects the player.
NOTE: If needed, switch the player to MSC mode, 1. Turn device OFF. 2. Slide the Hold switch down to Lock (orange color showing). 3. Press and hold the center button while connecting the device to the PC.then connect it to the PC. Next Be sure the battery is charged 1. Leave the player connected for approximately 2 hours to charge. 2. Disconnect the player from the PC. 3. Verify if you can turn on the player. 4. Reset the player if necessary.
To reset the player: 1. Press and hold the Power/Menu button for approximately 20 seconds. 2. Release the Power/Menu button. 3. Press the Power/Menu button again to turn on the player.
If that does not do it, re-seat the battery: Here is how to get to the battery, 1. Press the battery compartment in while sliding to the right. 2. Remove old battery. 3. Insert new battery or reset the old battery. 4. Close the battery compartment. Then try and see if it will come on with out the battery hooked to your computer. 1. Remove the battery. 2. Connect the player to the PC to verify if it turns on. 3. Re-seat the battery to ensure proper connection. 4. Verify if the player turns on.
Jan 29, 2010 | SanDisk Sansa Clip MP3 Player
BT-710 headset clip mini II
Go to your bluetooth settings and make your phone discoverable, normally you need to hold the power button down on your headset until it flashes red and blue, then you will need to select the headset on your phone, the default code is usually 0000
Jul 30, 2009 | Nokia Cell Phones
Tom tom will not turn on, but charge light works.
Please connect your tom tom to the power adapter first.Get a paper clip and press the reset button under the SD card slot of your tom tom.Reset button is a very small small hole at the back near the sd card slot.Keep pressing the reset button for 2mins and also press the power button till the light comes on.
This should fix the issue.Let me know if you need any more help.
Jul 08, 2009 | GPS
Sansa Clip not holding charge
Locking the player will not allow the player to charge properly, no matter how long you have it plugged in.
Dec 17, 2008 | SanDisk Sansa Clip MP3 Player
It won't turn on!!
I had the problem on the controller not turning on and then just blinking a few times when plugged in to charge. I pressed the reset button (use a paper clip) on the back a couple of times. It didn't SEEM to work, but then I plugged it in to charge and the controller is working again. Maybe this can help some of you? Good luck!
Dec 03, 2008 | Sony Dual Shock 3 Controller for...
MY SANSA CLIP MP3 PLAYER 2 GB
please check on the backlight settings on the "system set" in the Menu, make sure you have a value in there, but if in case the Sansa itself does not seem to be turning on, the check on the battry if it is charged / overcharged. if you have checked on this area and you had the same issue, then you may want to check on the Backlight or the LEDs of your player, better if you consult the warranty of the player before opting to open theunit up by yourself.
hope this helps.
Aug 16, 2008 | SanDisk Sansa Clip MP3 Player
Sansa clip 2 gig computer doesnt find
This is the method that will force Windows to recognize the Sansa: Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
May 29, 2008 | SanDisk Sansa Clip MP3 Player
Itech Clip IIe Wireless Headset Logo
238 people viewed this question
Top Itech Radio Communications Experts
Vernon Taylor
Tom Chichester
Are you an Itech Radio Communication Expert? Answer questions, earn points and help others
