Question about D-Link AirPlus G DI-524 Wireless Router - Wireless router + 4-port switch - EN, Fast EN, 802.11b, 80...
We have not used the wireless connection in a couple of years. We have lost the Security Key. How can we connect? D-Link D1-524. P/N B1524ANA.. C1. FCC ID KA2D1524C1. I need to get to the point that asks for user name and password.
  • 2,263 Answers
Your wireless network must be secured
You will need to check the wireless settings of the router.
Is there any computer online using the router.
check the IP address on that computer.
If yes then you can open the router set up page on that computer.
router set up page is the page where you can check all the router settings.
Click Here for more information about the routers and network
Posted on Jul 30, 2010
I want cancted my wirless i lost modem no
I assume you mean wireless network encryption key. if so, connect using a cable and open your browser to 192.168.0.1, the key is configured under Wireless --> Security Settings. get it or reset it from there
good luck,
Majdi
Dec 08, 2011 | D-Link DIR-615 Wireless Router
I have a desktop & a laptop with the Linksys router connecting the two. Everything is hooked up okay, but lost the security key on my laptop . Tried to set up my E Reader wireless & went into my...
Can you connect directly to your router using an ethernet cable?
Go into your settings on the router and choose a security key.
Set the same key for your laptops etc..
Dec 30, 2010 | Linksys WRT160N Wireless Router
Suddenly today after working for a couple of years all the lights are on solid and my wireless laptops can not find the router
To connect to your wireless network using Vista's WLAN Autoconfig, follow these steps:
Step 1:
Right-click this icon 5449-001.png at the bottom-right corner of the screen and select Connect to a network.
Step 2:
Select your Wireless Network Name or SSID then click Connect.
NOTE:
If the wireless network name or your SSID is not listed, the SSID Broadcast on the router might be disabled. For instructions on how to connect to the wireless network with the SSID broadcast being disabled, click here.
If the computer is not detecting any signal or is not seeing any wireless network, change the channel of the router. For instructions, click here.
If WEP/WPA is enabled on the router:
Step 3:
Enter your wireless network WEP/WPA Key on the field provided then click Connect.
NOTE: To learn more about WEP/WPA and other Wireless Settings, click here.
NOTE: Make sure Display characters is checked, to display the WEP/WPA key used by the router. You can get the passphrase or network key from the encryption that has been generated (if using WEP network security) from the router's web-based setup page. If you're using WPA network security, the network key is the key for passphrase.
Make sure you enter the wireless network's WEP or WPA key not the Passphrase.
It is also possible to make a wireless connection even if the wireless security is disabled on your router. If you don't see any network SSID from your network list, make sure your wireless adapter/device is ON and your router is in good condition. If your router shows any unstable occurrence, click here.
Related Article:
Configuring File and Printer Sharing Unable to connect to a wireless network using WEP in Windows Vista Windows Vista Articles Listing Encountering Difficulty Connecting a Wireless Computer/s to the Internet when Connected to a Linksys Router Setting-Up the Wireless Settings on a Router Assigning a Static IP Address on a Wired Computer
Nov 06, 2010 | Linksys WRT300N Wireless Router
My securty lock is on and i lost wireless netwert
Connect your computer to the router using an ethernet cable to allow you to access the setup page of the router and get the wireless key. Or if you already have another computer connected to the router then you may use that.
Open a browser and type 192.168.2.1 in the address bar. Then enter. By default the password field is empty.
Once in the setup page, go to Wireless -> Security. Take note of the Pre-shared key (for WPA security) or WEP key.
On your wireless computer, type the Security key to connect wirelessly.
I hope this helps!
Mar 04, 2010 | Belkin F5D8631-4 Router (F5D8631au4A)
Lost my key number
Connect your computer to the router via Ethernet cable. In that way, you will see the WEP key assigned in your Router's GUI/page. You will see it in the Wireless section of the Router. Once you get the WEP key, enter it to the new PC to gain access to the Wireless connection.
Oct 15, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
New HP laptop will not connect to wireless secure network
Problem solved. I disabled the security on my network. I connected the new laptop to the unsecure network. I saved the settings on the laptop for the unsecure network. I rebooted the laptop. I re-enabled security on the router. I tried to connect to the network. I got an error on the laptop saying the network saved settings did not match. I modified the settings to a secure network on the laptop and saved the 128 bit key. Rebooted everything. All works fine now.
Sep 06, 2008 | D-Link AirPlus DI-524 Wireless Router
Security key
ahh just reset the router u can see it at the back of router theres a small switch button there...then beware when u reset it, you must reconfigure it again
Sep 02, 2008 | D-Link DSL-G604T Wireless Router
Internect connecting
If the laptop was connecting wirelessly before and you didn't change the wireless security key on the router during your troubleshooting steps with the ISP then it should just reconnect. If it doesn't reconnect you should probably delete the wireless profile that's saved and try connecting again. When you delete the wireless profile you will have to enter the security key again. Make sure you have this information handy.
If you are uncertain what the wireless security key is use your desktop that is physically connected to the router to log into the router and reset the security key.
To log onto the router you need to know the routers IP Address. You can obtain that information through the following:
START MENU
RUN
Type CMD
Click OK
Type IPCONFIG
Hit Enter
Look for the default gateway. The default gateway is the IP Address of the router. By default the IP is 192.168.1.1.
Type whatever IP Address you discovered into the address bar of your web browser (Internet Explorer for most) and hit enter.
You will be prompted for a login. If you didn't change the default login information to the router it should be a blank username and the word: admin - as the password.
Navigate to the wireless settings and reset the security key.
From your laptop key in the new network key.
Hope this helps.
MO
Jul 18, 2008 | Linksys Wireless-G WRT54GS Router...
I have wireless router and my laptop will no longer connect to the internet. The computer says wireless networks are available, but when I try to connect it asks me for my security key or passphrase. It's...
Maybe provide the brand of router.. Anyway, I have lost my details as well, several times over the last couple of years.. It's just a case of accessing the router (via web browser, using the correct IP address for your brand of router).. Then you can delete the existing network & add a complete new one. You get to use a new key & passphrase. If you need further help, please provide your router brand & model. Rgds, dave
May 02, 2008 | Computers & Internet
D-Link AirPlus G DI-524 Wireless Router - Wireless router + 4-port switch - EN, Fast EN, 802.11b, 80... Logo
135 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
