Question about Canon EOS Rebel K2 35mm SLR Camera
Aperture problem my camera is not working well. if the aperture is set to its max limit(4.0 or 4.5), it works, otherwise the screen just went blank and no picture taken. what could be the problem here and how can i fix this?
  • mmeynard Apr 26, 2008
    thank you very much sir. it really did not solve the problem but because of it i found the real problem.
    the circuit inside the lens was disconnected/loose connection. i need to have it repaired.
    again, thank you very much.
    Genius:
  • 1,554 Answers
You might have the lens on incorrectly .
or bent /jammed the small bar that inserts with the lens.
take off the lens and look at the little silver /black bar that sticks out the back does it move easily and look at he corresponding lever in the front to the camera
Posted on Apr 25, 2008
My Nikon coolpix l820 the screen doesn't work on camera setting but does on the video camera setting
hi,
when the still camera works the shutter of the aperture and iris is opening for a limited time, if it opens without limit the excess light will enter in and the result will be blurry picture, if the shutter is not opening the picture will be dark. in movie mode the shutter will be always in opened state, so I think there may be fault in shutter.
in some cases a slight jerk giving to cam when you depressing the snap button will reset the shutter and will work normally.
Nov 24, 2015 | Nikon COOLPIX Cameras
The shutter does not work. Fee appears on screen
This indicates that the aperture ring on the lens is not set properly. Turn the ring to its smallest setting (largest f/number). If the lens has a lock, set it. You can then control the aperture from the camera body, the same way as on a lens without an aperture ring.
Aug 05, 2012 | Nikon F65 35mm SLR Camera
Viewfinder is blank, but the camera works normally.
Iris or Aperture not working its all time off so that you can not see through camera.You need to change Iris cable.
Mar 31, 2010 | Canon PowerShot SD430 / Digital IXUS...
Where do I go to get simple manual focus instructions for my fujifilm s1500? I am trying to work my way throughusing fstop and Iso and shutter speed, but I am not sure which numbers refer to what when I...
The numbers in the left side of the screen is shutterspeed and aperture number.
125 means the shutterspeed is 1/125 sek.
F is the aperturenumber. The higher F number, the smaller aperture opening, the higher depth-of-field.
You can see these number in S, A and M mode.
S is shutter priority: You choose the shutter speed and the camera chooses the correct aperture (within limits)
A is aperture priority: You choose the aperture and the camera chooses the correct aperture (still within limits)
M is manual mode: You have to choose both aperture and shutterspeed. The ruler is an indicator, that tells you when the exposure is correct. The pointer should be in the middle of the ruler.
Mar 04, 2010 | Fuji Cameras
I have a d80 and while I have a Nikon AE lens, I also have a collection of older Nikon lens's. They work outside but don't work with a flash. Can you tell me if there is any way to fix this problem?...
I found this in my D80 manual regarding non-cpu lenses and their limitations:
The non-CPU lenses listed below may be used, but only when the camera is in mode M. Selecting
another mode disables the shutter release. Aperture must be adjusted manually via the lens aperture
ring and the camera autofocus system, metering, electronic analog exposure display,
** and TTL flash control can not be used. **
Except where otherwise noted, the electronic range fi nder can be used with
lenses that have a maximum aperture of f/5.6 or faster.
• AI-modifi ed, AI-, AI-S, or Series E Nikkor
• Medical Nikkor 120 mm f/4 (can only be used at
shutter speeds slower than 1/180 s)
• Refl ex Nikkor (electronic range fi nder can not be
used)
• PC Nikkor (electronic range fi nder can not be
used when shifting or tilting lens)
• AI-type teleconverter *
• PB-6 Bellows focusing attachment (attach in vertical
orientation; can be used in horizontal orientation
once attached) *
• Auto extension rings (PK 11A, 12, 13; PN-11) *
* Electronic range fi nder can be used if maximum effective
aperture is f/5.6 or faster.
There is a great deal of info in the manual about the use of other compatible Nikon devices. If you have lost your manual, you can view / download it here:
http://support.nikontech.com/app/answers/detail/a_id/14051/~/user%27s-manual---d80---guide-to-digital-photography
I hope this was helpful!
Oct 24, 2009 | Nikon SLR D80 Digital SLR Camera Digital...
I HAVE THE SAME PROBLEM.
If you're using the kit lens (17-85mm f/4-5.6), the maximum aperture achieveable when fully zoomed out (wide) is f/4 and when fully zoomed in, f/5.6 (that's what the f/4-5.6 stands for). The minimum aperture on this lens is not a problem since you're only making it smaller. i.e., f/22.
Try zooming back and turning the Aperture adjustment dial. You should be able to get f/4.
If you need bigger aperture to get a nice bokeh or to take portraits where the background is blurred while the subject in focus (aka shallow Depth of Field), try lens that are f/3.5 or f/2.8 max. The Canon 50mm f/1.8 is quite affordable (around US$100-120).
Sep 17, 2009 | Canon EOS 40D Digital Camera
Camera is fine except won't take pics!
1/30 is the camera speed setting which is very slow for a daylight shot.. and would possibly produce a blurry overexposed pic if it did take one
F3.5 is the aperture setting which is small.
an ideal aperture in daylight setting is F8 and a speed of 100 being relatively standard. Try changing both the speed and aperture settings on the wheel =to obtain the nearest or exactly this and then try. Otherwise it needs a service or a recharge Also try changing the battery in case there is something wriong with the one in the camera
Jul 30, 2009 | Olympus FE-340 Digital Camera
My Nikon N60 35 mm camera shows the fEE message
Your lens is not set to the smallest aperture (highest number). Turn the camera off, rotate the aperture ring so the largest number is lined up with the mark on the top, push the aperture lock tab, and turn the camera back on. The aperture ring is the one closest to the camrea body with numbers like 4, 5.6, 8, 11 etc on it. The largest number will be 16, 22, or 32 for most lenses.  If it still doesn't work, turn off, remove & replace the lens, and recheck the aperture ring setting.
Apr 10, 2009 | Nikon N60 35mm SLR Camera
Aperture priority malfunction
davidsucklin,
You can use the film lens with the D80, but it it not react to the same settings as it did with the film body, the multiplier factor for the focal length is going to be different and it may be stopped down a bit. When you are shooting in aperture mode are you adjusting your shutter and ISO? The camera and the lens have to be communicating the same info to one another inorder for it to work. First set the camera back to auto mode the check the shot to see the settings (f-stop, shutter speed) test them with different ISO's to see what the camera thinks the settings should be, then go back to manual on the camera and lens and try the shutter priority mode with the aperture ring set at the 2.8 to see if it works then change to Aperture mode with the same settings that can take the picture. If it doesn't work keep in mind som of the older D lenses will drop some functionality (like aperture) in certain configurations. You can verfify compatibilty of your specific lens on Nikon's support site.
randy320sgi
Jan 24, 2009 | Nikon D80 Digital Camera with 18-135mm...
FEE MESSAGE
Yes, on this camera you leave the aperture ring at f22 and use the camera's controls to set your f-stop. It won't work is you change the ring on the lens. You gain the control of the aperture in the 'M' and 'A' modes. The 'P' setting is for the camera to pick both speed and aperture for you. 'S' is shutter priority, etc
Jan 25, 2008 | Nikon N65 35mm SLR Camera
Canon EOS Rebel K2 35mm SLR Camera Logo
55 people viewed this question
Top Canon Photography Experts
old marine
old marine
pontelemon
pontelemon
Are you a Canon Photography Expert? Answer questions, earn points and help others
