Question about Element Electronics FLX-3211B 32 in. LCD HDTV
I have a model #FLX3211B-32, as we were watching TV today, the back of it started to make a sizzling noise, and started smoking, then the TV shut off. I let it cool for an hour or so and turned it back on and the power light goes to blue and the screen has a very faint "element electronics" logo for about 2 seconds before it goes totally blank. There was no source of moisture anywhere around the TV.
  • rromero427 Jul 29, 2010
    Yes it was, barring that it works after i get part. sounds like a pretty easy solution. thank you
  • 10,594 Answers
Back light inverter board generates high voltage for back light lamps (CCFL) and symptom shows that back light inverter board got problem as it is only part that can produce sizzling sound of high voltage leakage and smoke comes out.
Replace back light inverter board in tv, it would be located on left side if you see tv from rear and this board would be covered with shield.
Back light board is available in Shop Jimmy, local tv repair shop will do the job if you have no experience of board replacement in tv.
Thanks.
Posted on Jul 29, 2010
Sizzling,smoke,sparks ...horray.
Thats the Inverter board. Your model used several different types which are not interchangeable. You can get the correct Inverter Board for your model by contacting the guys over at www.tvrepairworld.com
Mar 13, 2013 | LG 32LD450 32 In. LCD HDTV
I own an 32 inch RCA TV Model No. F32444 one day
The TV has burned out.......Don't switch it back on again unless you want to get electrocuted, or burn your house down
Jan 19, 2010 | RCA F32444 32" TV
I go to turn it on and it sizzles and shuts itself off.
Replace the flyback. You need the 259296 flyback replacement kit which has the flyback related capacitors and the CD with detailed instructions. The kit is available at www.tvrepairworld.com
Sep 28, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Tv made sizzle pop sound and went out
All depending on the models, but i have seen and work on may units with this problem, there are a few large capacitors on the power supply that are sometimes doubly secured with glue, that in turn becomes conductive and causes faults like this. check all the large capacitors for any low or nil readings and with a fine point probe, carefully remove the glue on the and around the caos, and elsewhere if you see any. Good Luck.
Aug 27, 2009 | Apex Digital GB65HD09W 65" Rear Projection...
When I was watching the tv it suddenly started to flash off and on and then finally will not even turn on
Watching tv all of a sudden loud buzz noise,I shut off unit turned back on loud buzz came back about 30 seconds later loud pop pop then smoke came out of top of unit, i'm not please as this unit i bought about 17 months ago @ Canadian Tire Belleville & warranty is now not covered, pobably will never buy another Proscan product but am more concerned there could be a fire caused buy this than getting unit replaced
Apr 23, 2009 | Proscan 19LA20Q LCD TV
Turned on the tv, heard sizzling sound and it immediately shut itself off. Won't turn on now. It had been turning itself off periodically now and then for the last couple of weeks with no noise and then...
sounds like dust collected on the internal parts which after enough time can cause it to stop working. either have tv repair specialists replace the mother board, or replace tv
Oct 28, 2017 | RCA D52W20 52" Rear Projection HDTV-Ready...
Shuts off by itself, then makes weird noise in back of TV
have a tech check your flyback conection in side the set some times thay come loos during shipment.
regards
daniel.
Jan 05, 2009 | Sony KV-32S42 32" TV
Dead tv
That is typical with these units, The Horizontal output transistor and flyback go out in the RCA's 9 10ths of the time and causes this situation.
Sep 15, 2007 | RCA F32669 32" TV
TV screen wont turn on but just a loud noise coming from the tv
I think maybe the G-board needs to be replaced. A TV shop will have to repair it. They normally start around $200.00
Jul 02, 2007 | Panasonic CT-32G23 32" TV
Element Electronics FLX-3211B 32 in. LCD HDTV Logo
133 people viewed this question
Top Element Electronics Televison & Video Experts
LP
Are you an Element Electronics Televison and Video Expert? Answer questions, earn points and help others
