Question about RCA L32HD31 32 in. LCD HDTV
I have a Rca#L32HD31Yx12,Serial#I256CNo82. ok, whats wrong is that there are lines and its like the picture is flipping at a high speed and I checked all the cable and power cords. tv comes on, has sound and gets a picture,but the lines will not stop or go away.whats my problem?
  • 11,361 Answers
You may have bad T-CON board, see my guide here to see if you vae the same problem.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx
Please post back what you find.
Posted on Jul 30, 2010
I have a RCA L32HD31YX12 TV. The TV works fine for a half hour and then the screen flickers and goes black. The sound continues. If I turn the set off for a half hour, it works again for another half
You have answered your own question, someone needs to open it and find a loose plug or broken solder connection--if it reacts to being tapped on that is the issue- a physical problem inside.
Dec 05, 2012 | RCA Televison & Video
RCA l32HD31YX12 white vertical lines
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Mar 02, 2017 | RCA L32HD31 32 in. LCD HDTV
RCA D56W20, Works OK, so long as the "black level"
The green CRT has an issue and will need to be replaced. It could be the Green CRT drive board but doubtful as your describing the classic sign of a CRT thats developing a Short . You can get replacement green CRTs and CRT drive boards from www.tvrepairworld.com
Oct 14, 2011 | RCA D56W20 56" Rear Projection Television
HI, I have a RCA Model: L32HD31YX12 TV and when i plug the power and cable into it all I get is a black screen. The green light at the bottom of the TV is on but I'm not sure what to do. Also I do not have...
I have an RCA LCD TV Model#:L32hd31yx12. I have an issue with the settings staying in place when I shut it off then turn it back on I have to reset everything. Is there an update for the firmware for this particular tv???
Dec 26, 2010 | Televison & Video
I've had a rca model l32hd31yx12 and recently began to get white vertical lines after a minute they fade but certain screen changes like volume adjustments and the lines come back and fade again same thing...
Sounds like the power supply has filtering issues, in other words bad capacitors. its best to have a tv shop take a look at it. they shouldn't charge you. good luck
Nov 06, 2010 | RCA L32HD31 32 in. LCD HDTV
32'' RCA L32HD31YX12 Picture went out
Hi friend,,,
welcome to fixya
Commonly for RCA tv's if the screen went out,,the problem will be the CATHODE RAY TUBE,it is costly to buy.if you want you can buy it,,or it may be the D-board problem will be also,,,
but it is unusual,so check the tube.
if your satisfied with my solution PLEASE RATE IT
thank u...
Apr 09, 2010 | Televison & Video
RCA L32HD31YX12 only 9 months old and have vertical white lines random on the screen
your T-con board is failing you will need a tech to replace it if he can find the part try shop jimmy.com rca is in trouble and not helping alot
Sep 22, 2009 | RCA L32HD31 32 in. LCD HDTV
RCA HD TV MOD D52W19
ok 4 months was it brand new when you go it. it may still be under warrenty. but chances are you have shorted out some high voltage component. averge cost to repair at my shop is 350 to 500.
Apr 03, 2008 | RCA R52WH73 Projection Television
Picture flipping
The P52940 uses the 195 series chassis. The vert/hgt control is for vertical height. It adjusts the size of the picture from top to bottom. If your picture is flipping, it most likely means that something is wrong in the vertical circuits. I have seen fluid leak out of one of the CRTs and drip down on the vertical output IC, causeing the picture to go crazy vertically. The set should be serviced by a qualified tech experienced in the RCA 195 chassis.
Aug 18, 2007 | RCA P52940 52" Rear Projection Television
RCA L32HD31 32 in. LCD HDTV Logo
1,088 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
