Question about Nintendo 64 Console
Some game paks aren't fitting in my system! what should i do and why is it happening. they both say nintendo 64 and are the same shape!
    President:
  • 894 Answers
Well maybe the cartiage read is broken like its dented or the pieces have broken off of it or the gamepacks piece that allows the system to read it is broken or loose.
Posted on Jul 21, 2011
Can you transfer a pokemon with two different transfer paks
Although I don't have specific details on what you're referring to, I'll do my best to help.
This is referring to transferring Pokemon from one game to the other through a Nintendo 64, as far as I can tell. And, you should be able to do this by transferring the little guy into your Nintendo 64, then back out to the other game. I don't know exactly how this works, since I never used Transfer Paks, but I hope I helped in some way.
Jun 21, 2014 | Nintendo 64 Console
My Nintendo 64 Controller Pak is not working.
Well it might be an internal issue with the console then. Like the console might be confussed that would occur if you do not use offical Nintendo stuff more problems occur with unlicsened products.
Nov 21, 2011 | Nintendo 64 Console
When we change games, we have trouble getting some of them to come on. if we switch the system on and off a few times, it will come on. sometimes it doesn't come on at all and we give up. is this the...
Nintendo 64 - Game Pak Troubleshooting
Note: It is possible that the problem you have may be game play related. For example, if you cannot defeat a particular enemy, or are missing an item you need to complete an area, the problem is likely game play related and there is nothing wrong with your game. Please check our game play help for assistance.
Insert the Game Pak into the system. The Game Pak label should be facing the front of the Nintendo 64.
Make sure the Game Pak firmly clicks down into place.
Remove all accessories (with the exception of the N64 Expansion Pak) to see if the Game Pak works correctly without the accessory. If the game does work correctly once the accessory is removed, then the game pak and the accessory may not be compatible. Check the game pak instruction manual.
Check the instruction manual for the game to see if it requires any special accessories, such as the Expansion Pak, to operate.
Check the list of specific game issues to see if there are any known problems for the game you are playing.
Due to the age of the system, we no longer offer factory repairs directly from Nintendo. Please click here to find out what options are available for repair or replacement of your product.
Feb 12, 2011 | Nintendo 64 Console
I can't seem to get my nintendo 64 connected. I've tried 3 different tvs and I got it to work for a short period of time today but it was not the game I wanted to play. After I turned the game off, I...
Nintendo 64 Power Problems
Make sure you are using a licensed AC Adapter (the system's power cord). The name Nintendo should be molded into the actual AC Adapter unit. Unlicensed products are not fully compatible with Nintendo systems and may not work correctly. Also ensure all accessories connected to your system are licensed as well. (Expansion Pak, Controllers, Rumble Pak and Controller Pak.)
Make sure you are not using any game enhancing devices. Such devices are unlicensed and are not recommended by Nintendo, as they may not let your system function properly.
Firmly plug the AC Adapter into the AC Power Supply port on the back of the Control Deck and firmly plug the AC Adapter into the wall outlet.
Make sure your wall outlet works. To check it, try plugging a lamp into the same outlet where your system was plugged in. Turn the lamp on the verify the outlet works. Also, make sure you are not using an outlet that is operated from a wall switch. If you do, make sure the wall switch is in the ON position.
Slide the Power Switch on the Control Deck to the ON position.
If it still does not work, you'll need to RESET the AC Adapter. To do this, remove all the accessories (including the Game Pak and all controllers) from the deck. Unplug the power supply from the wall outlet for at least 30 seconds, then plug it back in. If your system works without the Game Pak and controllers plugged in, there may be something defective with either the Game Pak or one of the accessories. Turn the power off and plug ONE accessory into your system, then turn the system on to see if it still works. Repeat this process with ONE accessory at a time to see if you can figure out which accessory may be in need of repair.
If these steps do not resolve the symptoms you are experiencing with your system, your system may need to be replaced. For more information on what options are available, please click here.
Nov 27, 2010 | Nintendo 64 Console
Nintendo 64 Transfer Pak...
Try cleaing the contacts on the games and the transfer pak itself, look up how to clean games on youtube.
Jan 27, 2009 | Nintendo 64 Console
Kirby 64 won't hold a save file
The battery inside the game pak has died, thus, it can no longer hold a save.
Buy a special screwdriver for n64 Game Paks. Unscrew the casing, then find the battery inside the Pak. Take it (the battery) to any store that sells watches, then ask for a replacement for that battery. Plug the batery (+ side facing you) in the Pak, then screw it back together.
Your game should now save. :)
Nov 22, 2008 | Nintendo 64 Console
Donkey Kong 64 & Expansion or Jumper Pack
Search inside Nintendo 64 Console Knowledgebase
Apr 19, 2008 | Nintendo 64 Console
Memory pak for nintendo 64
I assume you are talking about the controller pak that plugs into the controller. Any game that uses a controller pak should have a pre-game menu with an option to delete or erase memory files. Just follow the on screen instructions.
Dec 04, 2007 | Nintendo 64 Console
Nintendo 64 console
Too many variables to answer this yet. Where did the expansion pak come from? Was it new or used? Was a jumper pak in place and the console working before you installed the expansion pak? Did you unplug the console before removing the jumper pak and installing the expansion pak?
Dec 02, 2007 | Nintendo 64 Console
N64 game Pak
It's not too hard, remove the "Do not remove" sticker first. Then take a flat head screwdriver and put it in the notch where the cover clicked in on the top and just pop it out. Here is a guide with pictures (although they have the official tool, a screw driver works just fine.) http://www.nintendo.com/consumer/systems/nintendo64/hook_expansionpak.jsp
Aug 30, 2007 | Nintendo 64 Console
Nintendo 64 Console Logo
29 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Zhenya Ogorodnikov
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
