Question about Lexmark Office Equipment & Supplies
How doyou change the ink catridge on a lexmark 2480
  • 906 Answers
Good day Sir, follow these procedure on how to change your cartridge on a lexmark 2480.
Note: Make sure your printer is properly installed.
click start - programs or all programs - Lexmark 2480 - Solution Center.
in Solution Center you will see how to install print cartridge.
have a nice day.
Posted on Jul 30, 2010
Hi I bought a lexmark S405 and when my ink finished, i decided to refill the black catridge but the print wont print unless i buy a new catridge which is expensive than buying a new printer. I wanna...
The Lexmark S405 printer requires all cartridges to have ink in them to continue printing.
The 100/100XL cartridges are not licensed to be refilled. You can, however, refill the 100A or 100XLA cartridges available on the Lexmark website at http://www.lexmark.com. You should be aware that a refilled cartridge will not be able to report its ink level, and you might not get the print quality you expect from ink that is specially formulated by Lexmark to pass through microscopic nozzles at extremely high temperatures.
Sep 20, 2011 | Lexmark Interpret S405 Wireless All-in-One...
MY LEXMARK X1270 PRINTER WILL NOT PRINT RED
U r ink catridge has gone bad change the color ink
Mar 23, 2010 | Lexmark X1270 All-In-One InkJet Printer
How do you reset printer chip in lexmark ink cartirdge for X 4650 printer
open the lexmar productivity center
activate the wizard and click on "change printer cartridge"
take the printer catridge out and wait 15 seconds
reinsert the refilled cartridge
confirm change
when asked if the inserted catridge is new, answer "yes"
sorry, I translated this from german..
Oct 07, 2009 | Lexmark X4650 InkJet Printer
Error 1203 how do I fix it?
try this solution:
It's mean your catridges overflow even from brand new catridges after a several prints or right after you refilled the catridges. Check to see if ink are smeared on the holder where the contact panel with the catridge. I have the same problem which I think lexmark have a proble and overlook.
Solution:
I use the klennex with a few drops of water to dampen and clean off those contact on the holder and my printer work again.
The refill ink work very well if you let it sit 24 hrs. Then before you print anything, you should run aligned the catridges a couple times then run clean catridges a couple times.
Print the test page to see how it's look and way you go.
Be sure not to leave any debris of klennex on those holder contact panel.
Too bad that I also cound not find out how to reset the ink indicator. It's annoying to hit the OK button every time you want to print.
Try and see if it's work for you. Good luck......
Jun 10, 2009 | Lexmark X4250 All-In-One InkJet Printer
Lexmark printer x6570 unable to allign after putting in new cartr
In this case what i would request u to do is....... Take out both the catridges from the Printer......... Take 2 Paper Towels one should be wet with Luke warm water and the other one should be dry........... Take the Colour catridge first turn it upside down and u will see a small copper plate on the catridge from where the ink comes out....... Place the wet paper towel using ur thumb on the Copper plate and press it a lit bit for 10 Seconds...... Now remove it and see whether u see any ink on the paper towel.......... U should see some ink on it now place the dry paper towel on the ink catridge in the same way........ Now do the same procedure again.......... Do the same procedure twice on the Black Catridge................. Now take the dry paper towel and turn the direction of the cartridge so that u can see a Copper plate on it with small boxes just clean that copper plate with the Dry Paper Towel.......... Know insert both the catridges inside the Printer the Colour Catridge should go in the right side and the black on the left........ Good Luck
Feb 01, 2009 | Lexmark X2470 All-In-One InkJet Printer
Lexmark 5400 Printer does not use the photo cartridge
First of all as this Catridges are Non Intelligent they will not be able to show u the exact Ink level on the catridge then too if thats really happening this Solution below will fix it: In this case what i would request u to do is....... Take out both the catridges from the Printer......... Take 2 Paper Towels one should be wet with Luke warm water and the other one should be dry........... Take the Colour catridge first turn it upside down and u will see a small copper plate on the catridge from where the ink comes out....... Place the wet paper towel using ur thumb on the Copper plate and press it a lit bit for 10 Seconds...... Now remove it and see whether u see any ink on the paper towel.......... U should see some ink on it now place the dry paper towel on the ink catridge in the same way........ Now do the same procedure again.......... Do the same procedure twice on the Black Catridge................. Now take the dry paper towel and turn the direction of the cartridge so that u can see a Copper plate on it with small boxes just clean that copper plate with the Dry Paper Towel.......... Know insert both the catridges inside the Printer the Colour Catridge should go in the right side and the Photo on the left........ Good Luck
Jan 28, 2009 | Lexmark X5470 All-In-One InkJet Printer
Ink cartridge supposidly missing?
try this and see if it works, shut down the printer and the computer then restart the computer first. you may try to uninstall the printer software, then reinstall it that way you are starting fresh, the software may have missed something on the install process. then when every thing is loaded, then turn on the printer. biigg53566
Jan 10, 2009 | Lexmark 2480 Matrix Printer
Lexmark 3470, new ink dosn't work.
In this case as u said u used this Catridges in 2 printers then check if u have removed the Transparent Strip from the catridges mand if it is removed and still u face this problem make sure u have inserted the Catridges in the right slot........ U need to insert the colour catridge on the right side and the black catridge should go on the left side.... If no go get the catridges replaced....... Good Luck.......
Apr 06, 2008 | Lexmark X7350 All-In-One InkJet Printer
Ink not printin on paper
I have had the same problem although my colour ink works beautifully but no black ink??
Mar 10, 2008 | Lexmark Z615 InkJet Printer
Lexmark z605 not printing colour
may be ur ink catridge is old or colours ower so change ur catridge
Dec 19, 2007 | Lexmark JetPrinter Z605 Color InkJet...
56 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
