Question about Fedders Q Chassis AEQ08F2E Air Conditioner
The unit is plugged in, and the timer digital light comes on with a beep, but nothing else on the unit works. Is there a fuse that I may need to replace? the unit worked beautifully one day, and the next day it was not working anymore.
I have a model 8100-0300-01 . The dte is H1612. My low voltage lights don't come on anymore. I have pressed the reset button but nothing happens. Can you help me?
Copy following link and scroll down to identify low voltage timer:
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
This particular line of Malibu timer has 1 year limited warranty.
Don't buy digital, photoeye timers for outdoors.
See if you can set timer so lights are ON all the time, then plug power pack into cheap wall timer.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Mar 26, 2013 | Hardware & Accessories
We were given an electric smooth top kenmore range. When it was initially plugged in, the digital panel came on. When the stove was pushed into place, the digital clock/timer went off and the oven won't...
The electronic timer/clock must be working and be in manual mode for the oven to work. Try turning the power off and on and see if it resets. If is doesn't you might need a new timer unit. If you don't need the timer and clock it can be easily by-passed at the rear by joining the active and load wires and the oven will work.
Feb 26, 2011 | Kenmore 9535 Electric Range
Maytag M7Y15F2A-D A/C - won't turn on -long beep then nothing
The beeping might be an alarm that indicates the coils are iced over by too much humidity in the air...and/or the unit is overheating etc.
shut off power to the unit for a few hours, go out somewhere if it is too stuffy inside.. see if the unit operates better when you return... I also suggest not running these things constantly, this causes some units to ice up and **** up the power..
hope the unit does get replaced, newer ones are more efficient.
Jun 02, 2010 | Maytag Heating & Cooling
2001 Jetta Tdi runs rough
Hi Whitneyford
Your priblem sounds more like the glow plug timer relay than the exhaust. White smoke after start up is a sign of diesel entering the exhaust before it has burned completly. This is as a result of the glow plugs switching off too early, which is usually caused by one or more faulty glow plugs or a faulty timer.With engine COLD, IGNITION ON... Check voltage with all 4 plugs connected. You should have a reading of 10--12 volts
If there is no power, check in-line fuse on loom coming to plugs.
If power is present, check for How Long. If only for a few seconds, the problem is with the timer. This unit (the larger of the relays and usually black in colour) is fitted on the fuse board, and there are a few different types. They come in 7 pin..8 pin..and even 9 pin units.
The glow plug light is often NOT accurate (even with a new timer unit fitted) as to the time of heating, and you will almost certainly find that power will flow to the plugs for quiet some time after the light goes out. This is not unusuall with The Jetta Tdi.
Good luck.
I hope this helps you sort out this problem
John
Aug 18, 2009 | 2001 Volkswagen Jetta TDI
Has power to unit but nothing works, ie. oven, clock, timers, etc
If you don't see any light in the display or from the light bulb inside it you probably need to replace the fuse inside the microwave, it should be by the place where the cord goes in the microwave.
Apr 08, 2009 | General Electric Microwave Oven
Kenmore catalyst electric dryer. about 3 yrs old.
You may only be receiving 110 volts, instead of the 240 volts needed to operate. (Thus, only the light coming on)
Did you reset the dryer circuit breakers?
Are you receiving 240v to the plug?
-Chad
Jan 21, 2009 | Kenmore 659 Electric Dryer
Jensen VM9311/ UV7i wont turn on!!?
Yo, I've got the perfect solution to your problem. Pull out the head unit from your dash. Then, remove the wiring harness carefully from the unit. Now, push in the yellow power wire (even jiggle it a little) making sure it's tightly snug the small port of the wiring harness. Then, plug the harness back into the unit and try turning it on. I've found that the wires come lose easily on this unit. hit me back up at Darkintel74@aol.com.
Mar 03, 2008 | Jensen VM9510 Car DVD Player
No power - Nothing happens
if you have power at the outlet and the internal fuse is okay, I would say you have a problem on the control board. We repair these nationwide for $32.50. Please see my profile for the Web address: http://tinyurl.com/yzjozk
Jan 08, 2007 | Emerson MW8107WA Microwave Oven
Fedders Q Chassis AEQ08F2E Air Conditioner Logo
18 people viewed this question
Top Fedders Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Mike
Are you a Fedders Heating and Cooling Expert? Answer questions, earn points and help others
