Question about Genie GSX8 Screw Drive Rail Extension Kit
We just installed a genie opener with an extension kit for an 8 foot door. The door will only close (using the opener) up to the point of the extension screw drive connection with the last rail/screw assembly. If we manually take it beyond that point then it will close all the way but then won't open beyond the extension connection with the last rail/screw assembly. Any advice?
    Scholar:
  • 143 Answers
This has happened to me a couple of times. You will need to return the product as defective and get a new one. This is what genie has told me to do. The problem is that the screw pattern is off just a little and the trolley locks up in a bind as it comes across the piece. Thanks BB
Posted on Sep 05, 2010
Genie garage door opener
Stop putting your wife's neck under where the door closes.
Oct 30, 2013 | Packard Bell Computers & Internet
I just installed a Sears Craftsman 1/2 HP Garage Door opener. As I was doing the adjustment to keep the door closed, it closed too tight. I disengaged and confirmed the door arm was set wrong so I fixed...
Use the emergency release handle to release the door. Run the opener to the open position until it stops. Close the door until it stops. Now re engage the the door.
May 04, 2017 | Sears Genie Garage Door Gpwk12 Wireless...
Why wont the carriage assembly go past the screw splice
I think the threads are different. I have the same problem and the threads in the small splice part are different. i must have the wrong splice.
Dec 30, 2010 | Genie Company Genie PowerLift Excelerator...
Looking for "kit" to install w/Genie garage door opened that would operate on battery if power is off
This is not available as a kit. The motor in the models that do have this function is special.
Sep 28, 2010 | Sears Craftsman LiftMaster Chamberlain...
Garage door wont close completely
There are a couple of reasons this might happen. First make sure it closes by hand all the way, if not there is something wrong with the door that will need attention first. If it does close then hook the opener back up. On the opener rail at the end by your header there is a little magnetic relay that is wired to the motor head. This can be moved farther up or down the rail. This sensor tells the opener when to stop in the downward direction. Loosen the set screw and move it toward the header 1/2 inch or so and try to lower the door. Do not move it too much at one time and if you do the door will hit the ground and come back up. Thanks BB
Jul 13, 2010 | Genie Company Genie PowerLift Excelerator...
Genie excelerator light won't turn off...
First unwire the wall button. If the light will go off now replace the wall button. If not then you will need to replace the logic board on this unit(genie.com for replacement). Protect this with a surge protector as well 900 joules or higher. Thanks BB
Jan 21, 2010 | Genie Company Genie PowerLift Excelerator...
The motor on my Genie Chain Glide garage door operator runs but the chain does not run or move.
If the chain does not move but the motor runs then you have stripped the internal gears. I would replace here. These chain glide units are not very strong. There might be a chance the chain is telescoping down the rail but the trolley is not hooked up. Pull the red cord back toward the motor to engage. Thanks BB
Dec 29, 2009 | Genie Company Genie PowerLift Excelerator...
Garage Door stuck open
IT COULD BE THE SAFETY EYES.
ARE THEY ALIGNED? BOTH LED'S LIT?
YOU MAY HAVE A CABLE OFF OR BENT TRACK.
IS THE SENSITIVITY SET TOO LIGHT?
IF YOU CAN'T SEE A PROBLEM, I WOULD CONSIDER CALLING A PRO THEY CAN NORMALLY FIX A MINOR PROBLEM FOR UNDER $ 100.00. CALL THEM. GIVE THEM A DESCRIPTION OF YOUR PROBLEM. ANSWER A FEW QUESTIONS FOR THEM AND GET A PHONE QUOTE
HOPE THIS HELPS
Dec 24, 2009 | Genie Company Genie Excelerator Down Limit...
We have a 7 ft 6 inch garage door and we want to purchase the Chamberlain Whisper Belt drive unit. Can we get by without the extension kit?
You seem to fall into a category that Chamberlain doesn't quite address. They say their openers will work on a standard 7 foot door and then when they list their extension kits they are for 8 or 10 foot doors. You can contact them with your question at:
http://www.chamberlain.com/corporate/en-us/contactUs/
Oct 17, 2009 | Liftmaster, Chamberlain, Sears Door...
Genie GSX8 Screw Drive Rail Extension Kit Logo
260 people viewed this question
Top Genie Home Security Experts
Marvin
Marvin
Lawrence Oravetz
Are you a Genie Home Security Expert? Answer questions, earn points and help others
