REMOVE REPLACE KEY DOARD - Computers & Internet
  • 3,587 Answers
Just unplug it from the back of the computer..
Posted on Apr 24, 2008
Tv sharp 21r2 Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window.
Oct 28, 2013 | Televison & Video
Grundig YB400PE Tuning Failure
I has the same problem, could you fixed it?
Jul 03, 2013 | Grundig YB 400PE AM/FM/SW Radio
Dash lights not working on 2004 tahoe. Gauges and speedometer still work. Circuit board or replace bulbs? already checked fuses.
the is a problem with the servos in the dash doard i have a 2003 duramax i found on ebay some one to relplace all the servos wih up dated ones and put it back in its the cheepest and you can drive with it out use your gps for mph the dealer will fix it just more time and money
Nov 25, 2012 | 2004 Chevrolet Tahoe
How to replace ignition key battery
remove mettle key blade from you key, for remove key blade you have to slide lock witch is sitting in top of your key, near the mettle key you can see small sliding switch, remove mettle key, then have a look not in the deep hole witch is mettle key was insert but left of the mettle key remove sliding switch small grow witch is mettle key head ware sitting in, if you have a good look small gray sliding part is there, you have to use mettle key blade to press it and press it backward of key when you press it you can see it's moving, keep that moving part press by mettle key and pull out the key head, then you can see battery in that part witch is came out from key before remove the battery keep in mind negative and positive it have mention on battery replace battery and jest push key head in to the key til lock insert the right way , is this information helped you? please leave a comment.
Oct 16, 2010 | 2000 Mercedes-Benz S-Class
How do i open the key fob to replace the battery
For 2009 Cadillac CTS
Remove the hidden key by slipping a small screwdriver or knife under the metal endcap and lift. The key will come out. To replace the battery, pry the two halves of the main plastic housing apart, exposing the CR 2032 battery.
May 17, 2010 | Cars & Trucks
Timer buttons do not work....
look for line fuse (small fuse) near the doard connection
Feb 27, 2010 | Dacor MCD230 Millennia Electric Double...
How do I replace the climate control on 97 Buick Riviera? I have the replacement but I'm unsure of how to get the dash off?
i have a 95 and the way i took the dasy off is, under neath the lip of the dash there is a plastic plate that goes accross the whole dash there is plastic pins in there u have to remove i used a flat head screw driver but they might break. then there is several screws that connect the top of the dash to the front of the console remove them screws when u remove them there is 2 more screws one of them is on the drivers side u have to remove the the whole fuse panel and there is the same thing on the pass side once all the screws are out u have to lift the bash board to remove the console now this is were it gets trickey cause it is hard to lift the dash doard cause it only goes so far cause of the airbag but just work at it and lift the console out not the climate control is exposed. there is 2 screws at the bottom and then there is one way in the back top center. then the climate control will come out disconect the wires on the right side and insert the new one. i did not put top screw back in cause it was almost inpossibe with out a maginatic screwdriver. with the top screw out thereis no difference in operation and it does not move in the console. once u get that in its tome to put the console back on but the stering wheel all the way down and insert bottom first and take your time cause this is the hardest part but it will evently go back in and when it does make sure the taps on the console are behind the ones on the dash board screw in all the screws and put the plate back on with the plastic clips. and make sure the screws are tight other wise the dash board will make noise like mine does. and just so u know is seems harder then what it looks
Feb 01, 2010 | 1997 Buick Riviera
Broken water actuator
Hi this is tech crazy
the solution to the problem is
You should be able to replace this part yourself. Follow these steps to replace the water actuator:
  1. Unplug the refrigerator to completely disconnect electrical power. Turn off the water supply to the refrigerator.
  2. Remove the drip tray (Key 23 in the image below) from the bottom of the dispenser.
  3. Remove the screws (Key 43) from the bottom of the dispenser module cover (Key 4). NOTE: You model may not have screws at the bottom of the dispenser cover. If not, push down on the top of the dispenser cover and pry out on the bottom of the cover with a flat tip screw driver to remove it.
  4. Pull to dispenser module cover up to release the top clips and remove this cover and set it aside.
  5. Remove the screws (Key 17) that are on each side of the dispenser module (Key 8).
  6. Carefully pull the dispenser module out slightly from the door. It will have wires attached. Pay attention to how the water tube and the ice door assembly are positioned. Pull this module out far enough to remove and replace your water actuator (Key 24).
Reverse the above process for reassembly.
Jan 25, 2009 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Problem in install the lan drivers
i need biostar mother doard driver 945gz micro 775se download
Nov 24, 2008 | Biostar 945GC-M7 TE Motherboard - v6.0,...
Monitor light blinking
Some monitors blink 2 different collers and that means that their is no video signal and some monitors will blink real fast.This is caused by a power cap going bad.If this is happening you need to take appart the monitor and look for a power cap that has stuff leaking out of it or one that has a loose connection to the board or one that is bubeling on the top the power cap.The top of the power cap should be extremly flat.(here is the problem their could be a bad power cap and it might not be showing any signs of going bad).You will need to replace the cap.You can go to radio shack or fry's and they will usually have the parts for cheep.You will need to know the voltage and the pecofarrets.The voltage and the pecofarrets are usually listed on the cap.For example 350 voltage and Fu 4.5 (Fu standing for pecofarrets).You will need to remove the old power caps by applying heat with a soder gun to the under side of the board.Make sure you know which prong on the power cap is positive and which is negitive as the cap is polarity concious.(usually on the doard under the cap it will say + or -.The longest prong on the new cap will be positive).Once you have identified the bad cap or just replaced and removed them all you will need to use a soder gun and soder to atach the new power caps to the board.After sodering cut any acess langth of the prongs off and reasemble the monitor.Now hopfully the monitor works.
Oct 11, 2007 | LG Flatron 563LE 15.1" LCD Monitor
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
