Question about KitchenAid KGRT607 Gas Kitchen Range
Oven will not reach desired temperature and slight gas smell
Oven is very slow or does not reach desired temperature.
Could this be the ignitor? This seemed to happen once before after using the self clean mode. Recently used self clean and problem started again. Unplugged stove from wall outlet to see if it is a reset problem then fired up oven and got to desired temp. Shut oven off and tried again and would not reach desired temp. Also has a gas smell when turned on only.
Just had same problem it was nice it waited until christmas dinner, all i did to resolve the problem was switch the upper broiler igniter with the lower one for the oven. I tuned on the oven & it fired right up i never use the broiler on my oven so itll buy me some time. So if you can get the broiler to light try that but i did have the same low temp. & the smell of gas. Good Luck
Posted on Dec 26, 2010
Oven not heating to desired temperature
You will have to place a amp meter over one ignitor wire and turn the oven on to bake.
If the amp draw is 3.3 amps or less,replace the ignitor.
Jul 11, 2010 | Amana ARGS7650SS Gas Kitchen Range
Oven ingniter lights , smell gas but oven doesnt turn on
Hello- Ignitors may 'light' yet not reach proper resistance and temperature, causing improper gas flow past valve. If resistance is below 4 ohms, ignitor is bad. Part is 40-75$ at local app. parts store. Fairly easy to replace. Hope this helps. -Thanks- ED
Mar 01, 2010 | Kenmore 71513 Gas Kitchen Range
Kitchenaid KGRT507FWHO gas range not firing or not getting hot
your ignitor is either cracked or bad
gotto sears type in your modle numbber and look for ignitor in parts search reletivley easy repair
Oct 07, 2009 | KitchenAid Cooktops
Matag gas oven won't or is slow in comming up to temperature.
Hello and welcome to FixYA!
You are 100% correct in your suspicion that the oven ignitor is at fault. If you want to know "for certain" you can check that ignitor in circuit using an amprobe and looking for at least 2.9 amps, however I would say all you need do is replace that ignitor and your oven should return to proper operation. The gas smell is a result of an ignitor being on the "ragged edge" of being able to open the warp switch in the gas valve. Instead of opening up, it is "burping" the valve enough for you to smell gas. Your part number is a
12400035 and sells for around $50 or so, depending where you buy it.
Thanks for using the FixYA! service!
Dec 14, 2008 | Maytag PGR5710 Performa Gas Kitchen Range
Burner flame shuts off during use and then you smell gas
all ovens, when they reach temperature they go off and on to kip the temperature, but if you smell gas the oven ignitor needs replacing, the ignitor gets red hot to ignite the burner ,but when ignitor does not get hot enough, it will have a delayed, that's the reason you smell gas.
Dec 10, 2008 | KitchenAid KGST307 Gas Kitchen Range
CRG9700 - OVEN TEMPERATURE BIG FLUCTUATIONS
biggest issue with any gas oven is a faulty ignitor, not maintaining oven temp, too long to preheat, taking too long to cook, possible slight gas smell during operation, all signs of a bad ( or going bad) ignitor
Nov 10, 2008 | Kitchen Ranges
Bake part of kenmore not working seems to take to long
Chances are the oven ignitor will need to be replaced.  Look and see if it glows.  If it does then it is weak and not opening the gas valve to lite.  Let me know what you find.
Comment by fridgetech, posted on Oct 20, 2007
Should be able to remove the bottom drawer and unplug the ignitor from below.  Or you can cut the wires on the old ignitor and splice the new one in using ceramic
Oct 20, 2007 | Hotpoint RGB745 Gas Kitchen Range
KitchenAid KGRT607 Gas Kitchen Range Logo
667 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
