Question about HP P4014DN Laserjet Printer
Hp-p4014dn ....printing problem
My company has windows server 2003...now we upgarded the printers.Updated it to hp-p4014dn.When i try to print it prints fine.But to other people it says Load heavy paper and that datalight blinks.It is not a paper format problem as what my colleague says.new printer doesnot have that problem.Can anybody help..??
Most likely the paper type is set incorrectly in the printer settings in Windows for the users. The printer knows it does not have heavy paper, at least no one set it up that way which is why it's looking for it for the particular print job. Also, if you press the OK button it should allow the print job to run on whatever paper is available.
Posted on Jul 30, 2010
PCL XL error hp8150DN windows server 2003 for
Depending on what you are trying to print you might try updating the PCL driver or switching to a PostScript PS driver. the discrete drivers for that device were last updated in 2007.
HP LaserJet 8150dn Printer
Good luck
Aug 17, 2013 | HP LaserJet 8150dn Printer
Print spooler automatic it will stop
From Microsoft: http://support.microsoft.com/kb/934885
I dont know how your print server is configured but you may want to see if the manufacturer of the printers have any updated drivers or try older version of the drivers. If just printing you may want to set the printer to a TCP/IP port and use generic print protocols.
Dec 17, 2012 | Microsoft Windows Server Standard 2003 for...
Network Printing Issue. I'm running 2008 Domain Controller 2003 File and Print Server. Cisco 3560G switches No 3rd Party print management software User workstations are all Windows Xp Pro SP2 Printers are...
DNS errors then? can you map to the printer via hostname too? Are you sure you're not using SP3? When we upgraded to SP3, we had to use the new drivers. Try new drivers.Have you tried just rebuilding your print server? try sharing the printer off your computer in the data center and try t print to that. When you ping the data center from the user's computer... what is the delay?
Oct 13, 2009 | HP LaserJet 4250n Printer
All printers with HP hJetDirect 615n card not printing
Known failure with the jetdirect 615s, the more reliable cards are the 610 or the 620. According to HP tech support stay away from the 615.
Oct 27, 2008 | HP Jetdirect 615n Print Server
All printers with HP JetDirect 615n will not print
Is the 615n an internal print server not one in the EIO slot. From memory if so it has a really high failure rate. Try getting JetDirect cards for EIO slots and seeing if they work.
Cannot print on shared printer
I had the same problem with HP 1018 printer, when I had two computers connected to a domain and had Windows XP SP3 on them and when I shared the printer on one of them - I could only print from the network if the user belonged to the Local Administrators group on the host/server computer. Once the network user is removed from Administrators - the print jobs are stuck in print queue. I used the "HP LaserJet Host Based Print Driver Package" that is on HP web site for HP laserjet 1018 printer.
Then I tried to use a different driver for that printer and was successful with driver for HP LaserJet 1020. After forcing that printer to use the 1020 drivers, the regular users were able to print to that printer.
Oct 26, 2008 | HP LaserJet 1018 Printer
Not working on window 2003 server as a network printer
I have had a similar issue with both laserjet 3005N and 1320N machines setup as network printers on a windows 2003 print server. Both machines install correctly and print test pages but once you push to much of a print job to it (in my case it was a 12mb pdf file) the printer stops printing and never prints again for some reason. After a quick reboot a test page will print but what gives?? Buffer issues? Not enough ram? None of this makes sense since the printer displays nothing and just stops printNo test pages or anything. I tried re-installing it and rebooting it. Nothing.
Jul 12, 2008 | HP LaserJet 1320 Printer
Printing problem on Windows 2003 Standard (with SP2 R3)
Hi, FRND,
Let me tell u one thing that the PDF driver not gives you print on the printer !!! PDF driver gives print on the file no on the printer ...
which printer u are using.....
if you are not using any printer just want to see the print preview... then use the IBM pro printer....
The drivers are in build....
Or the problem for handling the PDF print then remove it & you better know that the which version of the PDF u are using on Win 2003 Std ok..
Best Luck....
Feb 27, 2008 | Microsoft Windows Server Standard 2003 for...
HP P4014DN Laserjet Printer Logo
91 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
