Question about Bizfon BIZTouch 3 Corded Phone
One of our Biztouch 3 phones will work on Handsfree but the handset does not work. There is no dial tone coming through the handset. Thinking it was a fault with the phone, handset cord, etc., I switched to another phone but using the same extension (and same cord leading from the phone jack to the phone). Same problem! This leads me to believe there is something set in the Bizfon 680 PBX that is limiting this extension to Handsfree use. I ran a diagnostic on the PBX, but no luck.
  • rob8505 Jul 29, 2010
    Thanks, I solved the problem myself. If was a switch on the side of the phone.
    President:
  • 567 Answers
Hi that is a problem with your phone settings it seem as if the phones are configure to work as hand free and not both ways. you should change the settings of the phones.
Posted on Jul 29, 2010
    I assume that it is a problem with the phone configuration, but I don't know for sure, nor do I know what setting on the Biztouch 3 would configure the phones in this way. That's why I was asking for help!
    Since I wrote my request for help, I did more trouble shooting. I found that 2 of our phones act as described, in other words the handset doesn't work. But the handset works fine on a 3rd phone if it is plugged into the same wall jack. So my original supposition was wrong -- it's not something in how the extension is configured, it's something with the phones themselves.
    Do you know HOW to reconfigure the phones, if that is indeed the problem?
  • Hilton Bristol Jul 29, 2010
    Hi thanks for the reply i am please to know the phones are working fine now.
My BizTouch3s have not dial tones.
They need to be plugged in to work. Check the pbx.
Feb 04, 2015 | Bizfon BIZTouch 3 Corded Phone
Dial tone
You need to disconnect all the cables on each side of the handset and then reconnect. You can also reverse the cable and see if it will help
Nov 27, 2011 | Uniden Lands Phones
How do I activate the handsfree mute button on Norstar M7310? When I push outside line, then handsfree, I get dial tone, but cannot dial outside number. When call is incoming, after answering, I cannot...
familirize with devices user manual whether has feature functions requested. Second, ascertain that device was least malfunctioning since acquired. normally, familirising with innovative devices makes expertise in functionality.
Jul 20, 2011 | NorStar Meridian M7310 Phone
There is no dial tone or sound, but the calls go through
Does it work on handsfree or with the handset ? It should work for one of those. Make sure your handset isn't plugged into the headset port on the bottom of the telephone. If it's still not working, change the handset and curly cord with one from another phone to test if that's the issue. (but then the Handsfree should technically work)
May 24, 2011 | NorStar Meridian M7310 Phone
We have a meridian M7310 telephone system, and have just bought some headsets. Unfortunately we wish to use both headset, handset or speaker phone. Is this possible? Because at the moment we can only...
First of all, make sure you're plugged into the headset port of the telephone and not the handset port. Pressing the Handsfree button should change from handset to headset. You can't use the speaker phone with the headset plugged in.
May 13, 2011 | NorStar Meridian M7310 Phone
How do I programme the memory on an answercall sp100 phone?
1. Pick up handset OR press 'handsfree' and wait for dialling tone.
2. Press 'store'.
3. Dial number you wish to put in the memory.
4. Either press 'M1', 'M2' or 'M3' to save as one touch speed dial numbers OR press 'store' again and then press any number between 0 - 9 to save two touch speed dial.
5. Replace handset and you're done.
In future if you wish to dial a one touch number then so long as you remember which button you ascribed to it you can do so with M1, M2 or M3. If it was a two touch number then you will need to press 'memory' followed by whatever number you ascribed between 0 - 9.
Hope this helps!
D. Nisbet
Sep 12, 2010 | Cell Phones
Need to change phone back to tone dialing
Here's what the manual says: Changing the Dial Mode (Tone or Pulse Dialing) (HS1 only) Your phone can communicate with the telephone network in two different ways: tone dialing or pulse dialing. These days, most phone networks use a method called tone dialing, so your phone comes programmed for tone dialing. If your phone company uses pulse dialing, you need to change your phone's dial mode. If you don't get a dial tone or can't connect to the telephone network, follow the steps below to modify your phone?s settings: With the phone in standby, press and hold [cid/menu]. Press [vol/ / ] to move the pointer to select DIAL. Press [select/channel] to set the phone to pulse dialing. Press [end]. Return the handset to the base. The handset communicates the new setting to the base, and the base activates the setting on any other handsets. Hope this helps out. K
Jun 05, 2009 | Uniden 2.4 GHz Cordless Phone System
No dial tone in Clarity C4230 setup
if you can get dial tone with another phone, look into manual for any instructions, usually a toll free number for help. ( BEST ) otherwise take phone back for exchange. may be problem in the board.
Apr 16, 2009 | Clarity C4230 Cordless Phone
Bizfon BIZTouch 3 Corded Phone Logo
78 people viewed this question
Top Bizfon Lands Phones Experts
Marvin
Marvin
David Burbee
David Burbee
Are you a Bizfon Lands Phone Expert? Answer questions, earn points and help others
