Question about HP OfficeJet 6210 All-In-One InkJet Printer
HP 6210 has a carriage jam. the cartridges can't move all the way down the carriage. nothing seems to be jamming
    President:
  • 1,194 Answers
There's a small locking mechanism that holds the carriage in it's home position. This needs to be slightly sprayed with WD-40 or a similar lubrication (small amount).
If this doesn't solve then follow this.
Open the door, unplug, let the print cartridge move all the way to the left. Check where the cartridges usually sit on the right side and check for any glob of INK (that could have been leaked from the cartridge).
If you are still having the same problem then visit this link and follow all the steps. They are nearly same for your printer.
Posted on Jul 29, 2010
Carriage Jam for HP 6210 all in one printer
It a service faulty. you can batter replace it solved the problem.
Jun 12, 2013 | HP OfficeJet 6210 All-In-One InkJet...
Carriage jam when there isn't one
the carriage is not the CARTRIDGE ,
the carriage(the cartridge holder) stall at somewhere in the print area
i hope my answer is useful?
Dec 11, 2012 | HP OfficeJet 6210 All-In-One InkJet...
I just changed the (2) ink cartridges in my HP PCS 1610 All-in-One HP printer and now get an error message "CARRIAGE JAM - OPEN DOOR. CLEAR CARRIAGE JAM, AND THEN PRESS OK." I don't see any jam...
Have you tried moving the carriage to see if it really is jammed? Maybe you haven't put the levers down properly on your new cartridges....remove them, see if the carriage slides, then refit them and check the carriage again. You wont visually 'see' a carriage jam,; you have to try moving it. By the way, if it doesn't move, DONT force it to try and overcome the jam try and reason out why it doesn't move.
Hope this helps!
nicam49
Jan 18, 2011 | HP PSC 1610v All-in-One Printer
I get a message carriage jam and told to clear jam. However there is no paper jam. It tells me door open and it is not open. It seem the door does not go all the way up. I keep getting the message that...
It seems you mistook Carriage Jam as Paper Jam, but they are different issues. Carriage jam means the carriage that carries the cartridges is jammed which needs to be moved or be cleared manually after opening the door.
Please follow the instructions mentioned here (Click Here) [source HP Support].
Good Luck.
Let me know if you need further help.
Thanks for using FixYa.
Jan 14, 2011 | HP OfficeJet 6210 All-In-One InkJet...
Carriage jam print cartridge stalled HP 6210 Officejet. It started all of a sudden and I can't fix it
Press "ON" till green lite appears. The display will indicate "Initializing..." and then lift upper half of the printer to access cartridges. Cartridges should move all the way to the right. If they don't, inspect the carriage belt for any obstructions.
Nov 06, 2010 | HP OfficeJet 6210 All-In-One InkJet...
Hp officejet 6210 all in one, carriage jam
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Also clean The purge unit, called a spittoon assembly in an HP, Lexmark, Caonon and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
May 07, 2010 | HP OfficeJet 6210 All-In-One InkJet...
HP OfficeJet 210 All in one Carriage jam
Nothing you can service on the printer.
try unplugging the power cord and move the cartridges.
Jan 16, 2009 | HP OfficeJet 6210 All-In-One InkJet...
How to Clear carriage jam on HP PSC 1610 Printer? No obvious paper jam visible.
Dear it's the carriage jam error. so it mean that your carriage is jam not paper. so open the printer where you insert the cartridge. check whether it is jam or what . cartridge carrier is jam kindly turn off the printer and try to move the cartridge head by hand very gently and if seems to be stuck than check for anything which abort him to move freely so than might be anything like dust or else. when you get success in moving the head put some machine lubricant on the rod on which head moves and check it ok.
Dec 04, 2008 | HP Office Equipment & Supplies
HP PSC 2210 keeps complaining about paper jam. There is no paper jam!
For carriage jam try these steps
Remove both the ink cartridges from the All-In-One. also all the papars in the tray
Unplug the power cord from the All-In-One as well as the power outlet.
Now move the carriage (carriage is the one which holds the cartridge) Too and Fro till you feel the carriage is moving smoothly.
Then insert the cartridges close the access door.
Plug the power cord directly to a wall outlet without surg protector.
Before connecting the power cord to the All-In-One press and hold the # and no 6 button and then insert the power cord, do not release the keys
until you see a message a reset (if the screen goes blank then release the keys and turn the power on)
Now try printing a test page or make a copy
Good Luck
Sep 21, 2008 | HP PSC 2210 All-In-One InkJet Printer
HP OfficeJet 6210 All-In-One InkJet Printer Logo
mukhtar21 shaikh
mukhtar21 shaikh
