How to change a Samsung DVD HD850 player from Region 1 to multi region?
  • 376 Answers
1. Turn on the Player with no disc on the tray. The tv screen and the dvd lcd will display "No Disk"
2. Press the "Repeat" key on the Samsung remote control
3. Press the keys: "5 7 5 3 8" on the remote. A number must appear n the screen. That is your player's current region.
4. Prss the number for the region you want to use next ( 1 , 2 , etc). If you want your dvd player to be unlocked for all the regions press "9". A number should appear in the screen.
5. Press the "Open/close" button in the remote. The tray will open. Leave it open for a few seconds.
6. Just press the "On/off" button in the remote.
Posted on Sep 11, 2008
Multi Region Code Support
SEE THE INSTRUCTION. GOD BLESS YOU
  • 1
    Turn on your DVD player.
  • 2
    Open the DVD player's main drive, also commonly called the DVD "tray." The region cannot be changed while a DVD is in the machine, so many DVD players require the tray to be open as an extra precaution.
  • Sponsored Links
  • 3
    Push "Info" or "Setup" on your remote.
  • 4
    Use the remote to select the "Region" option as indicated on your TV screen.
  • 5
    Select "Region 9" to change the system to multiregion formatting. Regions 1 through 8 represent specific geographic locations and will not allow multiregion playback.
Read more: How to Change a DVD Player to Multi Region ' eHow http://www.ehow.com/how_5121939_change-dvd-player-multi-region.html#ixzz2VzwQi6NL
Jun 07, 2013 | Pioneer DV2032K All Multi Region Code...
Want to unlock region codes on my Samsung vcr/dvd recorder model no dvd-vr375 so I can record here and it can be played in Canada
Do the following step to make your DVD player region free..
1.Turn machine on without disc inside
2.Press menu button
3.Enter region code (See below for list)
4.A highlighted 'region area number' will appear in the upper left corner (some players)
5.Press 9 to change the region number to multi-regional
6.Turn DVD off (remove power from mains)
next time when u power on the DVD ,it will be region free.
region 1 - 29334
2 - 38767 or, 5 7 5 3 8
3 - 56732
4 - 76884
5 - 53814
6 - 24462
ok
Jan 22, 2011 | Samsung DVD-VR375 DVD Recorder/VCR
I need the code for my dvd to play multi region
Hello J richard214
I have been trying to get the code for I could not find the exact code but here is a link
www.dvd365.net look along the top and click CODES then on the right hand side go down to Samsung.
There are several codes for different model just try some of those you may find that one of those will help you out.
Hope this helps you out.
Little Dish Fitter
Oct 08, 2009 | Samsung DVD-HD850 DVD Player
Problems changing region code on Samsung DVD player VR 375
HELLO!
Give these a try!
Power ON
Press MENU
Enter code 57538
The current region code appears
For codefree/multi-region press 9
Press Open DVD door button
Power OFF and power ON
You could also try this!
Turn player on without disc inside Press MENU button
Enter your region code (See list below)
Highlighted 'region area number' will appear in the upper-left corner (on some players)
Press 9 to multi-region the machine
Turn machine off
Region 1 - 29334
Region 2 - 38767 (or 5 7 5 3 8)
Region 3 - 56732
Region 4 - 76884
Region 5 - 53814
Region 6 - 24462
Have a go and good luck! (:-)
Sep 11, 2009 | Samsung DVD-VR375 DVD Recorder/VCR
Samsung DVD-VR375 - can't chage from region 1 to region free
I used this and it worked for me!:
1/Turn machine on without disc inside
2/Press menu button
3/Enter region code (See below for list)
4/A highlighted 'region area number' will appear in the upper left corner (some players)
5/Press 9 to change the region number to multi-regional
6/Turn machine off
R1 - 29334
R2 - 38767 or, 5 7 5 3 8
R3 - 56732
R4 - 76884
R5 - 53814
R6 - 24462
Jun 20, 2009 | Samsung DVD-VR375 DVD Recorder/VCR
Multi region code for samsung dvd 5500
um there is a reason why there is differ region dvd's...no player will play multi unless u buy it that way....best bet is to convert your wrong region dvd's to non region
Dec 02, 2008 | Samsung Televison & Video
Making dvd player region free
2/Press menu button
3/Enter region code (See below for list) eg if your present region code is R1 enter 29334
6/Turn machine off
R1 - 29334
R3 - 56732
R4 - 76884
R5 - 53814
R6 - 24462
Oct 16, 2008 | Televison & Video
Unlocking
Follow Carefully:-
1:- Power On Your Player.
2:- Press And hold Play And Stop On The Front Panel ( player )
3:- After a short While Options Will Appear To Change region Settings. Choose Between 1 And 6.
4:- Press The Play And Stop Buttons On The player.
Your Player Should Now Be The Region Of Your Choice.
Hope This Helps You Out.
Mike @ Compurepair.
** Please Do Not Rate This post Until your Problem Has Been Solved/Resolved.
We also offer Full Advice On Making The Player Multi-region Capable Or Region-Free, For A Small Fee.
Thankyou.
Feb 27, 2008 | Samsung DVD-V1000 DVD Player/VCR
Dvd recorder region codes
1. Press the Menu button on your remote control
2. Press the 5 button on your remote control
3. Press the 7 button on your remote control
4. Press the 5 button on your remote control
5. Press the 3 button on your remote control
6. Press the 8 button on your remote control
7. The currently selected region will be indicated on the TV.
8. Press the 1 button on your remote control for region 1, the 2 button for region 2, and so on, or the 9 button for multi-region playback
9. Press the Menu button on your remote control
10. Press the Menu button on your remote control
Tested with Region 1 DVD's on my UK player (Region 2 bought from Comet)
Jan 28, 2008 | Apex Digital AD-1110W DVD Player
Televison & Video Logo
124 people viewed this question
Top Televison & Video Experts
Electro Med Services...
