Question about Roper RGS7646KQ Gas Dryer
My gas dryer the heat cycles on & off - Roper RGS7646KQ Gas Dryer
  • Roper Master
  • 8,220 Answers
It is supposed to do that. If the fire stayed on the whole time the clothes would be burned. SERVICE MANUAL
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Jul 29, 2010
  • 7,365 Answers
Clothes not drying, but dryer runs & heats?
1.defective thermostat-----replace
2.fan or it's pully loose on shaft----tighten set screw
3.incorrect heat or timer setting---reset timer
4.clothes to wet to when placed in machine
5.clogged lint screen or duct---clean out
I have a gas dryer, model MDG7657AWW that will not stay heated. Every time I put it on, the flame comes on for about 21 seconds & then shuts off. I replaced the igniter, hi limit thermostat, cycling t
On a gas dryer the heat normally only comes on for 30 seconds or until the drum temp reaches 160f at which time the flame is shut down by the cycling thermostat. The drum temp then starts to drop. When the drum temp reaches 105f then another blast of heat is issued for 30 more seconds.That is how they work. Put it all back together and trow a load in there.
Oct 28, 2011 | Dryers
My Maytag dryer, MDG4658AWW, will turn on heat for one cycle then heat never comes on again. Also, when using permanent cycle the heat cycle comes on once, dryer continues to run then shuts down (cooling...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Sep 25, 2011 | Dryers
My dryer is tumbling & blowing & all the cycles seem to work but it won't heat.
heatman101
Sep 04, 2011 | Frigidaire AEQ8000FG Dryer
Dryer won't heat up & keeps running after cycle.
heatman101
Jul 03, 2011 | Dryers
Hello my 70 series kenemore is not getting warm and the timer is not completing the cycle to turn the dryer off it just keeps running for hours
I would need a model number to better narrow the problem down for you.
If this is a gas dryer
Remove the lower panel. With the lower toe panel removed, start the dryer & watch the igniter. If the igniter glows & cuts off without lighting the gas this would usually indicate the gas valve coils are weak & will need to be replaced. For this type of repair be sure to disconnect the electrical power & turn off the gas to the dryer. If the timer is set in the auto dry cycle, it will not advance if the dryer is not heating. Once you repair the dryer, the timer should start advancing. It is possible that your old timer is good. If you need further assistance please resubmit your question.
If this is a electric dryer
The timer not advancing from 50 minutes in time dryer & the unit not heating are not related unless 1 leg of the 240 volt supply is lost. Diagnosing a problem like this will require using a volt/ohm meter. With the timer set to time dry you should be getting 240volts to the timer motor & 240volts to the heating element. In the wiring diagram provided L1 comes from the timer on R & goes through the thermal cutoff, oper thermostat & the hi-limit to provide 120volts to 1 leg of the heating element. The L2 leg goes through the motor switch to the other side of the heating element. This is how the element gets 240volts. The timer motor gets its voltage on BK from L1 & OR from L2; this is what advances the timer.
Jan 12, 2011 | Kenmore 700 7973 Dryer
I have had a stackable hi efficent 7.3 cap. kenmore dryer for 2 months. Suddenly it doesn't heat. No sign of vent problems or electrical but on all cycles both the dry & cooling light up at the top...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Nov 22, 2010 | Kenmore Dryers
Was getting one heat cycle then ignitor woud glow but no call for gas. put in new cycling thermostat, thermostat boosting heater and heat sensor. I got two heat cycles before it went cold..?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Aug 08, 2010 | Amana DLG330RAW Gas Dryer
My dryer is not blowing hot air? I have a whirlpool, commercial quality, super capacity plus, 8 cycles & 4 temperatures. help.
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jun 10, 2010 | Dryers
GE DBSR453GB Gas Dryer doesn't dry on 1st cycle.
heatman101
May 30, 2010 | GE DBSR453GB Gas Dryer
Gas never ignites in any cycle in a 10yr old Kenmore dryer.
Chances are your igniter has gone bad. It must pull atleast 3.2 amps to open the gas valve and ignite the gas. A new igniter could probably purchased for 20 or 30 dollars.
Mar 13, 2009 | Dryers
Roper RGS7646KQ Gas Dryer Logo
113 people viewed this question
Top Roper Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Roper Dryer Expert? Answer questions, earn points and help others
