Question about Nokia E51 Cellular Phone
I have a nokia e51 when i turn off the phone and take my sim out it automatically goes to offline mode when i turn it back on with the sim card out. how do i stop this to allow myself to put in the network unlock code
  • 35 Answers
It is suppose to behave like that because without SIM card inserted, the phone will never received any signal from your operator
Posted on Aug 20, 2010
Nokia nuron wont read my sim card
When the phone is in offline mode, press the power button and you will get the options in list view. Choose the option General and the phone will become online.
Aug 29, 2012 | Nokia 5230 Cell Phone
My nokia e7 stays offline mode while sim inserted
After inserting the sim card it goes restart and ask for changing the profile from offline,when i try to change the profile from offline to others it hang and restarts showing the offline while sim inserted!tried with different sim but no use.
Jul 08, 2012 | Nokia E Series E7-00 Touch Smartphone-...
OFFLINE MODE
Offline mode means that your phone aint getting any signal from your mobile service provider's BTS. You need to check it from your mobile service provider if there's an ongoing outage, you need to check as well if the sim card is properly inserted. Try powercycling your phone.
1. Turn off your device.
2. Remove the sim, memory card and battery.
3. Wait for at least 2minutes.
4. Plug back the SIM card, memory card and battery.
5. Turn on mobile phone.
6. Check if you are still getting offline mode.
7. If so, try to insert your SIM card to a different phone.
8. If using a different phone for your SIM displays offline mode still,then its your SIM card which is faulty. If it works fine make sure that you inserted the sim properly or the SIM card slot might be faulty.
Dec 05, 2011 | Nokia E52 Smartphone
How do i change my phone from offline to online??
Hi.
Your phone likely to be offline mode automatically when it might not have detected your SIM Card. the Sim may not have been place in well. off your phone and check the SIM if it was properly inserted. on it again and your nokia cell phone will ask you if you still want to continue in offline mode? click no. and the offline settings will change.
Hope this solution works for you.
May 18, 2011 | Nokia 6790 Surge Cell Phone
How to make nokia off to online mode
just go to profile and select general, it will automatically put your device back to online
Jan 09, 2011 | Nokia E71 Smartphone
PHONE IN OFFLINE MODE . hOW DO YOU CHANGE IT TO on line mode
Ok let me give you solution about this problem....
Offline mode is the mode in cell phones which barred your every calls sms and even your internet connection simply you can say that...
It stops all of your connection......and you can use only those things which do not need the connection or network.
So to deactivate this offline mode their is two way
1. You can restart your phone after inserting sim card and if the sim card is in good condition and readable then the cell phone will ask you wheather to continue in offline mode?
Just press no that is upper right button of your cell phone and it will be deactivated.
2. Just press on/off button gently and it will show you profile i.e. to select mode
General, silent, meeting etc. you can select any of them except offline mode.and again it will be in normal mode.i hope that it will help you,
By: Neuron
http://www.digixtream.blogspot.in
Jun 15, 2010 | Nokia E51 Cellular Phone
The mode will not change, itried reseting the pho...
do check your sim card that it is properly inserted or not...sometimes the sim card not properly inserted so the mode can'nt be changed
May 20, 2010 | Nokia E51 Cellular Phone
Nokia e65 stuck in offline mode.
step 1>switch off your phone and turn it on again
step2>you should get a respond <: continue in offline mode>: select no
finally, i believe that everything should be ok.
if it doesn't there is alternative 2???/////
ALTERNATIVE TWO: this is useful for those who got INSERT SIM CARD RESPONSE.
WHY INSERT SIM CARD PROBLEM ?
my phone is 1yr and 6 months now and i discovered that as you remove and replace your Sim card numerous times, there is a big possibility that Sim card port will get expanded.
SOLUTION is very simple:.>>:1. buy a black solo tape
2. place it at the outer part of the sim card and use blade to cut exactly the same shape as the sim card.
3. finally stick the tape.
WARNING>>?do not stick the tape on where you have the Sim card service sensors.make use of your brain.
Nov 05, 2008 | Nokia e65 Cellular Phone
Offline mode
take the sim card and put it bck again.restart it...there it will say "CONTINUE IN OFFLINE MODE?"....select no there...choose another profile and press ok...offline mode will b disabled....
Oct 23, 2007 | Nokia N73 Cellular Phone
Nokia offline
where did you bought your phone? if you bought it from a telecom's promo it means that your phone is locked to a single network provided only. you can ask a technician to have your phone OPENLINE for you to be able to use any kinds of sims.
if it's not the case, check the slot for sim and make sure that the sim is properly placed. restart it without the sim and then restart again but now with the sim.
Sep 23, 2007 | Nokia N70 Cellular Phone
Nokia E51 Cellular Phone Logo
333 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
