Question about Dryers
I have a GE dryer that heats up, but the drum will not turn. How do I take it apart to see if the belt is broken and what kind of belt do I get if that's the problem? Thanks,
    President:
  • 3,773 Answers
2 Screws underneath front door. (At the top of the door when it is closed) Pull up the top anel or pull out the front panel after you remove the two screws underneat the lip of the door opening.
Leo Ponder
imufo2@sbcglobal.net
Posted on Jul 29, 2010
Heat is blowing out but the drum is not spining
You broughtke the belt of drum wont turn you might take the dryer apart to make sure the idler pulley is spinning free also. They sometimes get tight and burn the belt up.
Apr 10, 2015 | Avanti D110 Electric Portable Dryer
Dbsr463eg7ww no heat
First check to see that the exhaust venting line is clear (not full of lint) as well as the path in the dryer to the line. This is the most common cause of no heat.
Second set the knob to heat turn on dryer with the lights off and the door open but the "open door" switch so that it still rotates with the door open. Look at the back of the rotating drum for a orange/red glow behind the drum (the heater coils). If there is no glow the heater coils are probably broken.
As the dryers age, the amount of thermal cycles the heater elements go through until the point when the coil wire breaks. There usually two heater coils behind the rotating drum (one hotter than the other and when combined the hottest heat temperature setting. You will need to pop open the top where you see the belt that turns the drum. The belt is removed from the spring loaded tensioner pulley at the base of the dryer. Then you can lift the drum out to get to the heater coils. Since no heat, both should be broken and will require replacement.
Nov 05, 2013 | GE DWSR463EG Electric Dryer
Dcvh660ghbb dryer wont heat
Sep 05, 2013 | GE Dryers
No high heat in dryer
This type of dryer has 2 rows of elements. If one is out then you will not have high heat.
Basically to get into ge dryers your start by popping the top then removing the front. Then the drum comes out.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 05, 2012 | GE Dryers
I HAVE A GE DRYER THE MOTOR SHUTS OFF WHEN YOU RELEASE THE START BUTTON AND THE DRUNM WONT ROTATE
there's a broken belt switch connected to the belt idler pulley,(when this belt breaks the switch opens) located down by the motor and it kills the power to the dryer when the belt breaks so the heating element cant get the clothes too hot to burn the clothes when the drum cannot rotate properly
Feb 25, 2012 | General Electric Dryers
How to replace ge dryer heating element
you will need to remove the drum for this one.  once it is out, the element is mounted on the back of the unit.  not a hard repair, just lay out the parts as you take it apart to give you some order as you re-assemble it.
Aug 03, 2010 | GE Profile Wizard DPSE592EAWW Electric...
DRUM WILL NOT TURN
Sounds like the drive belt is either broken, fallen off the pulleys, or is damaged.
Open the dryer and replace the belt.
Dec 09, 2009 | Cars & Trucks
Ge Cloths dryer will not stay running or turn drum
probably broken belt some dryers have broken belt switch that shut dryer off if belt broke
Nov 25, 2008 | GE Dryers
Dryers Logo
Top Dryers Experts
Marvin
Marvin
