Question about HP DeskJet 6122 InkJet Printer
I have a HP ink jet printer 6122. The cartridge light is blinking when I replace both the color and black cartridge. How do I get the light to stop blinking and print my papers?
SOURCE: Black stopped printing out. Dell 922 all-in-one ink jet.
HI thanks for that and i will try it.
Posted on Jan 15, 2008
Tech Jenkins
  • 359 Answers
SOURCE: printing problems
Unfortunately there is little you can do to troubleshoot hardware malfunctions like this you describe. Especially on inkjet printers. You would be better off getting a replacement printer.
Make sure you take the plastic guards off the cartridges, other than that there really isn't much more you can do.
Posted on Aug 12, 2008
bobjrdns
  • 84 Answers
SOURCE: hp deskjet 6122
GO TO MAINTENCE IN THE PROGRAM AND CLEAN HEADS AND ANSWER THE QESTIONS
Posted on Oct 18, 2008
micromatikal
  • 2777 Answers
SOURCE: HP color laserjet 1600 - black spots on paper
It sounds like the toner drum may be having some issues, it can be replaced but it is not easy / inexpensive. It may be more cost effective to replace the unit. Otherwise it will need a replacement part for sure.
Posted on Aug 11, 2009
Danieldesmon
  • 56 Answers
SOURCE: Canon MP190 not printing using only black ink, color ink finished
hai there...you try press the reset and colour button in the same time...the printer will back to normallyl
Posted on Mar 01, 2010
How to turn off test print on a HP DJ 6122.
Yes.Tell it to print a dot short word and when it starts printing unplug the power cord so it stops with the printhead somewhere to the left. Then do your cart change. It won' t know you did anything.
The 6122 will print from the HP 920, 930, 932, 940 & 950 drivers also - (which are included with your Windows XP and Vista systems). If you chose the 970 driver it will want a second sheet of paper to print a test page, which you can ignore and it will stop trying. All drivers seem to be the same print quality in my systems. I do not use the 970 or 6122 driver at all so I don't have an ink level monitor or any possible related potential glitch. I wet and slap stubborn old ink cartridges to un-stick dry jets. sometimes I use a small clear silicone tube to suck a bit of ink to get them started as the jet holes need priming sometimes if they are old.
Feb 06, 2014 | HP Deskjet 5940 Photo InkJet Printer
Can I print on my hp 6122 deskjet with only a black ink cartridge? I have no color ink.
Yes, all HP Deskjet printer models feature a 'single cartridge print mode'. Just remove the cartridge you don't wish to print with; the printer will automatically revert into either greyscale printing (if color cartridge remains installed) or black only printing (if the black cartridge remains installed). However, if the installed ink cartridge is electrically damaged/defective the printer will display an alert message; it will need to be replaced with a new cartridge.
For more information on the use of refilled ink cartridges or advanced HP printer problem diagnosis please visit Inkjet411:
http://www.inkjet411.com
Sep 03, 2013 | HP Office Equipment & Supplies
My HP Inkjet 6122 has suddenly started printing color photos with stripes. I don't use it very often, only when I need color photos. I have replaced both the #45 black and #78 color cartridges with genuine...
Use the HP Printer Assistant software tools to run a "head-cleaning" cycle -- the problem is not with the ink (there is plenty of it) but with the print-heads (that **** the ink, and then spray it onto the paper). Some of the jets are clogged, and so you get "white-stripes".
Aug 19, 2010 | HP DeskJet 6122 InkJet Printer
Blinking teardrop light blinking
Blinking drop light on HP6122 signifies an ink cartridge is out of ink. There are two cartridges -- color (larger of two) and black (smaller of two). Blinking drop light only indicates either, but not which. HP6122 service software and print driver are available from HP website http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=83027&lc=en&cc=us&dlc=en&lang=en&cc=us. HP6122 service software has a printer maintenance utility which includes ink cartridge monitor. Use the maitenance service utility to determine which (or both) cartridge is out of ink. With cartridge replacement, printer should automatically print test page, then reset and be ready for printing from your computer. To clear printed documents from print que, open the HP6122 print que via control panel > printers > double-click on HP6122 driver to show que > select document tab > select cancel.
Mar 26, 2009 | HP DeskJet 6122 InkJet Printer
Color is wrong
Have you tried replacing the cartridges? Some programs such as Adobe Reader will generate a "black" equivalent from the color cartridge. In this case, if the color cartridge is low in red, the outcome will be blue. This would signify that the color cartridge needs to be replaced. HP supplied a utility program for the HP6122 to detect and report ink levels. If you have this utility, check the levels. The utility will only work if the computer is directly connected to the printer -- not thru a print server. If you don't have the utility, you should be able to get it at the HP website http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=83028&lang=en&cc=us&taskId=135&prodTypeId=18972&prodSeriesId=88749
You might find that both the black and the color cartridges are out of ink. Some print drivers can detect when the black cartridge is empty, then attempts to print a black equivalent using the color cartridge.
Mar 16, 2009 | HP DeskJet 6122 InkJet Printer
Hp desk jet 920c ink cartridge
hi,
i think your color ink cartridge is near to empty that's why you are experiencing a pause printing..
try to replace it and try to print again..
rey...
Oct 08, 2008 | HP DeskJet 920c InkJet Printer
HP 932 RED LIGHT STAYS ON
The light you describe is the ink light.
When that light is blinking, try this.
Turn on the printer. Open the front cover and look at the carrier for the ink cartridges. There is a white arrow right above the latch for the color cartridge.
Once the carrier stops moving, the white arrow should be pointing to a symbol which represents the problem (the reason the light is blinking.) Examples are low ink black, low ink color, sick black ( replace ) , sick color ( replace ).
IF you have just replaced your black cartridge, you might need to replace your color cartridge too.
This printer will not work without both ink cartridges installed and full.
You cant print with a full black and an empty color cartridge unfortunately, even if you only want to print black.
Hope this helps!
Aug 27, 2008 | HP DeskJet 932c InkJet Printer
Printing problems
Aug 12, 2008 | HP DeskJet 6122 InkJet Printer
HP DeskJet 6122 InkJet Printer Logo
76 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
