Question about JVC TH-C40 System
I have a home theater JVC TH-C40. the stand bye red light is on, if I try to turn it on then it tries to power up but then it quits.. what could it be? the fuses are ok. thanks
  • wdguezv Jul 30, 2010
    funny enough.. if I put it on the radio it works perfect. but as sooon as I try to load a DVD or use the USB or even just the VRC audio in then it shuts down
  • 532 Answers
If cases like this occur, then the mechanism of the home theater is damage.
The mechanism is an IC which control the home theater is connected to the panel with a cord.
If the mechanism is replace with another one of the same model number, the home theater will work fine.
Thanks for contacting Fixya
Posted on Jul 30, 2010
  • wdguezv Jul 31, 2010
    what mechanism though? how come the radio works ok. but USB, any other input signal and the DVD part shuts down the system?.what IC could be damage? would it be in the main receiver? or could it be something with the board in the Bass?
    thanks
  • 3,083 Answers
Chances are the unit's trying to power up, but experiencing a current protection overload and shutting itself down before further damage is incurred. You might try the remote control to turn it on, as someone had luck doing that with a simliar problem. You can disconnect speakers and components, one at a time, to ensure nothing outside of the main unit is the problem. Once you isolate the unit as the problem, it will have to be troubleshot and serviced. Usually part of the power supply or amplifier circuit is faulty in these types of units, but that requires troubleshooting the circuit to isolate the bad component. Take it to a reputable shop, and get an estimate so you know what to expect for a charge.
Posted on Jul 29, 2010
  • wdguezv Jul 29, 2010
My subwoofer shuts off when I turn it up too loud. How do I fix it?
Don't turn it up so loud.
Or get a bigger subwoofer.
It's got a junk 6.5 inch speaker and the amp barely does 50 clean watts.
Claims 167 Watts at 10% distortion - impossible when it is drawing 160.
TOTAL BS.
Drive it too hard and protection circuit will cut in and shut it down.
Dec 31, 2010 | JVC TH-C40 System
Does anyone have the pinout for the subwoofer cable
PIN 1 L. PIN 2 R. PIN 3 SL. PIN 4 GRD. PIN 5 SR.PIN 6 SW.PIN 7 C. PIN 8 P.ON
Apr 15, 2010 | JVC TH-C40 System
COMPLETELY DAMAGED. WANT TO PURCHASE A NEW ONE. WHERE CAN I GET IT AND HOW.
If you want the same model check the web; Ebay, Craigs list or just google it.
Nov 28, 2009 | JVC TH-C40 System
Jvc th-c50 won't turn on-already changed the fuse even though the old one had very low resistance when tested w/my multimeter.if unplugged for several minutes the stand by light will flash once when...
i was having a simalar problem and was trying to replace the ceramic fuse with a glass one and it wasnt working. i have found the part number for jvc if you want to try and order the ceramic fuse from them and try that. QMFZ059-1R0-E its $8 after shipping.
Jun 11, 2009 | JVC TH-C50 System
Won't Turn On
Try reseting the system. Instructions below.
DVD reset procedure for TH-A10
1. Make sure there is no Disc in the tray.
2. Disconnect the power cord.
3. While Pressing "Stop" and "Open/Close" buttons together reconnect the power cord
4. Front display will show "TEST0".
5. Then the display will change to : "TEST1 JC2".
6. Press "Enter" button on the remote, display will show "EEPROM"
7. Press "Power" to shut unit off.
8. Reset is finished
Jun 01, 2008 | JVC TH-A10 System
DVD trays are stuck
Since it is unusable try this. It might help to have so\meone assist if the unit is heavy.
Raise unit and lower the tray end about 45 degrees down, while lightly shaking press the tray open, they might just fall out.
Nov 30, 2007 | JVC TH-C40 System
Bass of woofer in my system is not working
take it to a tech for repairs.good luck
May 02, 2007 | JVC TH-C40 System
No sound
If the set does not light up you are having a power supply problem have a tech repair your system.good luck
Apr 28, 2007 | JVC TH-C40 System
How do I get the sound from tv to play through when just watching tv?
If you don't have audio RCA output jacks on your TV then you will either have to open up your TV and add a "ground isolator" type device to the speakers and create an RCA output or else you could use a VCR tuned to the same channel as your TV and use it's RCA audio outputs to go to your stereo. If you don't know what you are doing, I wouldn't recomend you open up your TV and start changing anything though. Good Luck.
Jan 21, 2007 | JVC TH-C40 System
JVC TH-C40 System Logo
55 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
