Question about Tomtom GO GPS Receiver
Green light is on but will not switch on ??? - Tomtom GO GPS Receiver
  • 268 Answers
New battery is the solution. visit the solutions on my page and find one with instuction to change the battery.
thanks
Posted on Jul 30, 2010
I need a wiring diagram for a viper 5701 alarm/ remote start to 2000 celica. I got it used with no instructions
http://www.broadbandreports.com/r0/download/1719726~1dde657f739f4c4af788bc21302e8a8b/Viper-5701-NewStyle-Install.pdf
Constant 12V+ Black/Red and White Ignition Switch Harness Starter Black/White Thin Wire in Ignition Switch Harness Ignition Black/Orange Ignition Switch Harness Ignition 2 Blue/Red Ignition Switch Harness Accessory Gray Ignition Switch Harness Tach Brown/White ECM Brake Switch Green/White Brake Switch Trunk Pin Light Green (-) Switch or Dome Light in Trunk Parking Lights Dark Green (-) Parking Light Switch Head Lamp Red/Blue (-) Right Side of Center Console at ECU Factory Disarm n/a Door Trigger Red/White (-) Driver's Kick Panel Door Lock Purple/White (-) Switch in Center Console Door Unlock Pink/Black (-) Horn Wire Blue/Black(-) Steering Column Windows Up LF=Green, RF=Blue (passenger's switch main) Windows Down LF=Red, RF=White/Blue
I’m happy to help further over the phone at https://www.6ya.com/expert/chris_7f7f91eb941fb23f
Dec 30, 2014 | Vehicle Parts & Accessories
Green light wont come on
Is unit running? Orange switch - is that the fast freeze switch? If on and running, green light faulty. If nothing happening, start with fuse, test the switch and make sure power is to the thermostat.
Apr 04, 2014 | Freezers
My kobo wont turn on
How to Fix Kobo eReader Locked up Frozen or Not Responding
1)Slide power switch to right and hold for 15 seconds and release
    2)Slide power switch to right again and hold till green/blue button near switch lights up.
Dec 05, 2017 | iPhone Apps
Wiring diagram for 220 volt light with switch
ok here goes first what do you want to do? replace switch or what, all 220 volt lights have a switch, plug has 2 hots( one red-one black), then you have a white and a green, red and black are power, white is neutral and green is ground.whit goes all the way through to light, so does the green, switch controls power so red on one side of switch and black to other side, hopes this helps
Oct 15, 2011 | Home
What is the color code for replacing the light switch on a '94 Marquis with factory alarm and keyless entry?
Here you go. I think this may be what you are looking for. I hope this helps and good luck.
1994 Mercury Grand Marquis Alarm, Remote Starter, Keyless Entry Wiring Information Constant 12V+ Yellow Ignition Switch Harness Starter White/Pink Ignition Switch Harness Ignition Red/Light Green Ignition Switch Harness Accessory Gray/Yellow Ignition Switch Harness Tach Gray/Orange EDIS Module Brake Switch Light Green Brake Switch Trunk Release Purple/Yellow Driver's Kick Panel Trunk Pin Brown/White (-) Light in Trunk Parking Lights Brown Light Switch Head Lamp Red/Yellow Light Switch Hood Pin n/a Factory Disarm n/a Door Trigger Black/Light Blue Driver's Kick Panel Door Lock Pink/Yellow Behind Glove Compartment w/Keyless w/o Keyless (-) Door Unlock Pink/Light Green W/o Keyless Reverse Polarity Horn Wire Yellow/Light Green (-) Steering Column Windows Up LF=Yellow, RF=White/Yellow, Windows Down LF=White/BlackRF=Tan/Light Blue
Mar 26, 2011 | 1994 Mercury Grand Marquis
Would a bad Flasher relay cause the brake lights not to work?
The flasher does not stop the brake lights from working. Check # 18 fuse in fusebox under lower left side of dash. if it's ok, the brake light switch, on the brake pedal arm is next. light green wire with red stripe is hot if fuse 18 is ok. Depress brake pedal, light green with no stripe should have power. if not, replace brake light switch. If light green wire has power with pedal depressed, combination switch under the steering is next. Remove the cover from around the combo switch {under the steering wheel}. depress brake pedal, light green wire should have power. If it does, pedal still depressed, orange with light blue wire & wire with light green & orange should have power. Those 2 wires are brake & rear turn signal wires. { The turn signal switch should be in the middle, not right position or left. while checking for power in the last 2 wires. Good Luck drvolt.
Feb 06, 2011 | 2004 Ford F250
Internet connection stopped suddenly
Switch off power to the modem, router and computer. Now switch on the modem first and let all lights on it to be stable.. Then switch on the router and let all lights on the router become stable. Once the lights on router are all stable, switch on the computer and then try to accerss sites.
May 07, 2010 | NetGear RangeMax NEXT WNR834B Wireless...
I need a wire dyogram to hook up my prostart remote start in my 94 masda b-3000
12 VOLT CONSTANT YELLOW (+) IGNITION SWITCH HARNESS STARTER RED/LIGHT BLUE (+) IGNITION SWITCH HARNESS STARTER 2 N/A IGNITION 1 RED/LIGHT GREEN (+) IGNITION SWITCH HARNESS IGNITION 2 N/A IGNITION 3 N/A ACCESSORY/HEATER BLOWER 1 GRAY/YELLOW (+) IGNITION SWITCH HARNESS ACCESSORY/HEATER BLOWER 2 N/A KEYSENSE N/A PARKING LIGHTS ( - ) N/A PARKING LIGHTS ( + ) BROWN (+) @ HEADLIGHT SWITCH or FUSEBOX POWER LOCK PINK/YELLOW (TYPE C) IN DRIVERS KICK PANEL POWER UNLOCK PINK/GREEN (TYPE C) IN DRIVERS KICK PANEL LOCK MOTOR WIRE N/A DOOR TRIGGER BLACK/LIGHT BLUE (+) @ UNDERDASH LIGHT DOMELIGHT SUPERVISION USE DOOR TRIGGER, Requires Part #775 Relay TRUNK RELEASE N/A SLIDING POWER DOOR N/A HORN YELLOW/LIGHT GREEN or BLUE, See NOTE *1 @ STEERING COLUMN HARNESS TACH GRAY/ORANGE @ ECM, in PASSENGER KICK PANEL WAIT TO START LIGHT N/A BRAKE LIGHT GREEN (+) @ SWITCH ABOVE BRAKE PEDAL FACTORY ALARM DISARM N/A ANTI-THEFT N/A NOTES NOTE *1 The YELLOW/LIGHT GREEN(-) is found on vehicles WITH FACTORY CRUISE CONTROL and the BLUE(+) is found on vehicles WITHOUT FACTORY CRUISE CONTROL.
Dec 30, 2009 | 1994 Mazda 2WD B Series Pickup
I have a 1998 Champion 181 bass boat. The navigation lights are not working properly. - When I plug in the front green/red light, it immediately comes on with control switches in the OFF position. (The...
Check the switch. It sounds like it has seen better days. Also check the wires on the back of the switch to see if they are shorting out. The problem is at the switch area. Good luck.
Apr 15, 2009 | RTO Oar Sockets
Wiring diagram to hook-up remote starter on 1996 dodge caravan
Constant 12V+ Red or Pink/Black - Ignition Switch Harness
Starter Yellow - Ignition Switch Harness
Ignition Dark Blue - Ignition Switch Harness
Ignition 2 Black/White - Ignition Switch Harness
Ignition 3 Dark Green/Red - Ignition Switch Harness
Accessory Black/Orange - Ignition Switch Harness
Tach Gray Or Blue/Tan PCM Coil 2.4 Liter - Engine
Neutral Safety Wire Black/White - Power Control Module
Brake Switch White/Tan - Brake Switch
Trunk Pin Tan/Black - 40 Pin Connector at Fuse Panel
Parking Lights Light Green/White (-) - Head Light Switch Harness left of Column
Head Lamp Green/Orange - Light Switch
Factory Disarm White/Dark Green - (665 Ohm) left Connector bottom of Fuse Panel
Door Trigger Brown/White (-) - Lower right Gray Connector at Fuse Panel
Door Lock White/Dark Green - BCM at Fuse Panel
Door Unlock White/Dark Green - White Connector B58 Connector
Horn Wire Black/Red - Steering Column
Windows Up LF=Light Green, RF=Brown/White, LR=Blue, RR=Gray
Windows Down LF=White, RF=Purple/White, LR=Red/White, RR=Dark Green
Your R/S instructions should tell you what goes where.
Thanks for using FixYa - a FixYa rating is appreciated!!
Jan 31, 2009 | Vehicle Parts & Accessories
Tomtom GO GPS Receiver Logo
164 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Marvin
Marvin
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
