Question about Westinghouse LTV-32w4 32.02 in. LCD HDTV
Westinghouse LCD TV makes loud noise
Westinghouse LCD TV, makes a loud noise, shows "no signal" then comes on again
SOURCE: Westinghouse 1080P 42" LCD TV - HDMI stopped working
Just reset the TV found out how here: http://www.danielcoburn.com/uncategorized/westinghouse-1080p-42-lcd-tv-hdmi-stopped-working-fix/
Hold the power button for 10 seconds.
Posted on Jul 26, 2009
SOURCE: Westinghouse LCD TV freeze
I have the same problem ..... i just give it a good whack on the top of screen and the picture comes back.
Posted on Sep 07, 2009
roety
  • 585 Answers
SOURCE: Westinghouse TV no stereo
Hi my name is Roety,
I can help you with your issue ,
Why don't you simply run the cable box and DVD stereo outputs direct to the receiver. Thats what most people do. TVs do not passthrough stereo signal very well do to DHCP compliance requirements .
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Posted on Nov 11, 2009
Testimonial: "A very good solution, right under my nose. Thanks!!!"
  • 12 Answers
SOURCE: I have a Westinghouse LCD TV that is 1.5 years
I'm willing to bet it's the main board. Its the board that all the video and audio inputs. What is the model number I could find the part for you. You could change it out yourself, Its not that hard. Let me know.
Posted on Dec 16, 2009
  • 29 Answers
SOURCE: westinghouse model tx-47f430s lcd tv wil not turn on
This is known as SLEEP MODE problem.
Simple solutions:
1. Get a power surge protector / strip.
2. Plug your TV power cord to the power surge.
3.Then turn-on your TV using the remote control. Just in case it won't go all the way to normal state.
4. Turn-off the switch of your power surge like 5 times with an interval of 3-5 seconds.
5. Then repeat step 3 and 4.
6. These step is done to over-ride the sleep mode.
Roan
Posted on Feb 18, 2010
How do i get my westinghouse to recieve signal it shows on the tv no signal and on the box it says that the tv does have a signal
Make sure you have the TV tuned to the proper source.
My TV has multiple input sources ranging from the cable box to various AV and gaming equipment and I must select the right input source in order for the TV to receive a signal.
On my controller, there is a button at the top for selecting the input source. I can cycle through all sources by pressing that button. If you're using a programmable universal controller, that function may not be programmed into the universal controller so you may need to use the original controller that came with the TV.
If, after you've cycled through all of your available sources and still get no signal, check and see if a wire has come loose between your cable box and TV, either at the cable box end or the TV end.
Hope this helps.
Sep 09, 2014 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
How do I convert a Westinghouse 22" LCM-22w3 DVI/VGA LCD Monitor into an HDTV?
Dear Amy,
Normally, monitors do not have tuning electronics for capturing TV signals.
Therefore, consider the monitor as a "dumb" unit that only displays information coming from your computer. Also, this unit does not have a HDMI input, but only VGA.
So, you are fated to have this monitor connected to your computer, always.
Now, you may find good software that will "tune" the TV signals from streaming at the Internet and show whatever is being broadcast. The same way you can access YouTube and watch videos these TV tuners will get the streaming signals the TV stations send via Internet (not all do that) and watch the channel in your PC/monitor
Since I do not have additional information about the computer you use I cannot give you other ideas
I hope I have helped you.
May 18, 2014 | Westinghouse 22" LCM-22w3 DVI/VGA LCD...
We have a Polaroid 37" HD tv that has a loud
You have weak capacitors in the power supply and the signal board. I have not repaired this particular unit, but have experienced this with other Polaroid TVs. You will need a TV tech to replace those capacitors. It is a very time consuming task and requires patience and much care to remove the capacitors. Tell a tech that they must be very careful when they remove a cap in the signal board, as they can peel off a pcb trace. In most cases they replace the signal board, but the capacitors can be replaced! Thanks for asking and show a few hands of support!
Jan 03, 2011 | Polaroid FLX-374 37 in. LCD TV
Loud static noise without warning
The audio may be randomly disconnecting or something. I know that when my TV has no signal coming in, that it makes a bunch of loud static.
Jun 04, 2010 | Tatung V20KQDX 20.1 in. LCD Television
Wanted to adjust quality of sound, such as treble
Go in ur menu pick the audio go down pick the reset the tv set back to factory setting will get the
Mar 24, 2010 | Westinghouse SK-26H520S 26 in. LCD HDTV
My dryer make a loud noise when its rotating
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
jkgjh
Feb 16, 2010 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
TV is making a buzzing noise coming from the back interior. We tried checking the cables and testing speakers, neither of which are the problem. Any thoughts?
This noise is coming from the Lamp ballast. The back light of your TV (to make your LCD picture light up) is a Florecent Light Array. It is powered by a lamp ballast. You can have a shop change this power supply out for you.
Jan 06, 2010 | Westinghouse W4207 42 in. HD-Ready LCD TV
The tv takes 25 minutes to turn on. it shows no signal, makes loud crackling noises and then turns on
i would look at the power supply as it sounds like the caps in it are getting weak
Oct 14, 2009 | LG Z37LC6D 37 in. HDTV LCD TV
Loud noise
When the motor bearings start to go bad, they will make a loud noise. Some motors if a piece broke off of the fan, then it also will make a loud noise. You may have to replace the motor.
Dec 25, 2007 | Westinghouse WST1500 Wired Special Edition...
Westinghouse LTV-32w4 32.02 in. LCD HDTV Logo
121 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
