Question about Kenmore HE2 Plus Front Load Washer
Washer will not spin clothes dry...full of water and wont work. f-21 keeps flashing.
    Champion:
  • 274 Answers
Your drain pump is clogged,So the first thing you need to do is,Push the start button again you well hear the machine come on you well hear the pump its trying to drain after about 30 seconds,It well shut off,so push button again watch the machine when the water goes down a certain level.The clothes well start to spin. Now after they get done spinning,push the cancel button.you should be able to hear the door unlock,remove the clothes.Now put Draino Max gel or Rooto-Routor gel in tub of machine and let it set for about 1-2hrs.Now star cycle on heavy-duty wash hot water,it may take a couple of times but it well clean your machine don't mix any othe soaps or bleach during this time. then rinse machine out again to get rid of gel.see if this work for you,are machine does the same thing,its because of dog or cat hair,or something was in a pocket like tissue,or strings from clothes.thanks
Posted on Jul 29, 2010
Ho you can get the best services from your seller
Posted on Aug 02, 2010
Dryer is taking a longer time than normal to dry unless we switch it to timer. Replace sensors?
  • Remove and clean the lint filter each time it is used. The filter can be washed with warm soapy water to remove fabric softener residue from the screen.
  • Check the household fuses and circuit breakers. Most household dryers use two fuses or circuit breakers. It is possible for only one of them to trip and the dryer still tumble, but not heat.
  • The washer controls may have been improperly set. If the clothes are wetter than normal, coming from the washer, this could be the difficulty. If the gentle speed is selected for a normal load the washer will not spin adequately. High speed or extended spin removes more water from clothing decreasing drying time
A lint filter that is full of lint will restrict airflow and lengthen dry times. To keep your dryer working correctly, clean out the lint folder after each and every use. Check the lint filter for any buildup of fabric softener that will restrict airflow and wash with soapy water to clean. If the filter is damaged then replace it.
Nov 09, 2017 | Dryers
My washer has slow drain and won't spin out completely. What might be the problem?
Repairing a Washer That Won't Drain or Spin ' ThriftyFun
www.thriftyfun.com/Repairing-a-Washer-That-Wont-Drain-or-Spin.html
Did everything look at everything that has to do with slow water draining. ReplyWas ... My washer washes fine, but it won't drain the water out or spin on any cycle. The guy who .... My Kenmore 417 washer will not completely empty and spin.
my washer won't spin and empty? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jan 15, 2008 - If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing ... My Whirlpool washing machine won't empty all of the water after ...
Mar 21, 2013
Clothes washer won't spin clothes to drain water out?
Jun 11, 2008
More results from answers.yahoo.com
Why won't my washer spin or drain? - Kenmore 110 Series ...
https://www.ifixit.com/.../Why+won't+my+washer+spin+or+drain
iFixitMar 16, 2014 - Belt, Water Pump If the washer won't drain the pump belt might havebroken or might have worn ... It will fill with water but won't spin or drain on its own. ... Keep in mind that any water in the washer will pour out of the hoses when removed. ... I would have had to take apart entire washer to fix clogged pump.
My washing machine won't drain - LaundryDoc.com
www.laundrydoc.com/Washing-Machine.../My-washing-machine-wont-...
If your washing machine will spin but it won't pump water out, then the drain line is probably clogged up. In most washing machines, a small sock or small piece ..
Jan 05, 2016 | Washing Machines
2009 Kenmore Dryer. Wondering why it seems to only work on 1 drying cycle? Everytime I try to put it on another cycle all the lights flash and beep...and nothing...
sounds like the washer might not be spinning the water out of the clothes good enough . 1 60 minute cycle should dry them more than dry enough .
Oct 18, 2015 | Kenmore 8804 5.8 cu. ft. Electric Dryer
Washer-dryer # wm3677HW will not dry,heats up, run, on and on
You're a moron. This unit washes and dries. That's the whole point of it. Perhaps you should do some research before answering the question. the most likely cause is the water lever sensor.
Aug 09, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Code error problem
THIS IS TEMPORARY FIX, NOT A TOTAL SOLUTION. jUST TO GET WATER TO DRAIN AND RESET WASHER. , WITH WASHER POWERED OFF, PUSH AND HOLD START BUTTON FOR 4 SECONDS, RELEASE FOR 4, PUSH FOR 4 RELEASE FOR 4 UNTIL THE FRONT ALL LIGHTS UP AND DISPLAYS 88. sOON YOU WILL SEE YOUR CODES FLASHING, PRESS START BUTTON AS MANY TIMES NEEDED TIL NO MORE CODES FLASHING. tHEN WASHER WILL GO INTO DIAGNOSTIC TEST. aFTER THAT I DO NOT KNOW, BUT YOU CAN WASH 1 LOAD OF CLOTHES AND THEN PERFORM DIAGNOSTIC TEST AGAIN. THAT IS WHAT I AM DOING JUST TO HAVE A WORKING WASHER TOO MUCH TO FIX FROM WHAT I AM READING, SO GOING TO BU A NEW ONE ANYTHING BUT KENMORE. gOOD LUCK, HOPE THIS HELPS FOR IMMEDIATE RESCUE.
Jul 24, 2009 | Kenmore HE2 Plus Front Load Washer
Damp clothes at end of spin cycle
Time to check out and clean your filter...........
Mar 01, 2009 | Maytag Atlantis MAV8551 Top Load Washer
Washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Feb 21, 2009 | Roper RAS8445KQ Top Load Washer
Washer won't spin dry clothes
What model is in reference here? Please post back with model number.
Jul 02, 2008 | Whirlpool 3.2 cu. ft. Plus Washer
Kenmore HE2 Plus Front Load Washer Logo
321 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
